Question about Sony XM-2002GTR Car Audio Amplifier
Amp goes into protect when turned up.
I have 2 Rockford Fosgate RFD2210 10 Inch subs, running with the Sony XM-2002GTR Amp ... I switched to 4gauge wire thinking this would fix the problem samething still occurs.
When turned up the amp will go into safe mode, i had the subs bridged .. then un-bridged samething still occured.
I've double checked my ground, and power wire ... both are tight, and connected well.  Im not sure if i just didnt purchase a good enough amp or what the problem is... any help or input would be much appreciated.
Thanks.
Posted by xxjon43xx on
SHAN BAILEY
  • 67 Answers
That amp is only stable 2 about 4 omhs mono the powersupply shut dowm drawing t much current it supposed 2 2 fix this u need a 4omh load mono change speaker config so u get 4 omh or buy amp stable down 2 1omh can be expensive
Posted on Aug 29, 2009
Does anybody know what watt this is. it's sosed to be a 2400 watt and why does it have 2 ports on each side to hook up speaker wire And what's the best way to run it with a 800 watt Rockford fosgate
dual voice coil subs hook up mono on amp, from amp - from right side + from left side of amp run to sub n then jumper wires from one side of sub to the other side goes negative jumps on positive and positive jumps on negative
Xm-2002gtr amp keeps kicking protect light on
check your amp and speakers and make sure their both hooked up 4 ohm instead of 2 ohm because if you have 1 set of voice coils on your speakers they can only be hooked up four ohm and not bridged to your amp because if you keep trying this you will lock up your speakers if the speakers are only 4 ohm than just hook them up regular to each channel on your amp if your trying to brigde four ohm speakers to your amp it will keep going into protect or worst case scenario you will fry your speakers and you can check your ohm with a ohmmeter trust me my brother owns a stereo shop
I have a rockford fosgate 501bd amp the protect light comes on when my deck turns on even with no speakers connected
un hook the subs and let the amp sit there on if the protect light shuts off you wired your subs wrong if it doesnt go off tun it off then back on with no sub music all the way down then slowly turn the music up if the light is off then comes on you need new rcas
My Amp
sounds like the sub that throws it into protect mode is cross wired pull sub out and make sure they are wired right make sure ground from sub goes to ground on box and do same for power wire
1helpful
Power on/off
solidus- Your amp is going into protection mode, try disconnecting the sub and see if the power will stay on then.If yhe power stays on,it is your sub-blown or shorted ect. But if it does the same as before,its to the repair shop. cooltek Mar,4/08
1helpful
2answers
Rockford Fosgate 800a2 To 2 SVC 2ohm subs
Ok.. Bridge the two sub into 4ohm than bridge to amp.
So. this how it goes.
sub1 + -
to      | |
sub2 - +
=      4ohm
           From Sub
                Two
amp (L) - + (R)- +
This will use the full potiental of RF 800a2 amp. I believe it like 1153 watts max out.
2answers
Protection light
You cannot parallel two subs AND run them on the Bridge. You must have at LEAST a 4 ohm load on the bridge, and 2 4 ohm subs in parallel equals TWO OHMS. BAD!!! Move each sub to it's own channel or your amp will soon fry.
2answers
Amp protection light
Hi again, Looks like you posted twice, in any case pls have a look at your other post @ http://www.fixya.com/support/t182326-amp_protection
2answers
Amp shuts off when music turned up
try adding a capacitor to feed the amp. these are large in capacity (farads)and dims (about 6' x3' dia.)...what wire size are you using?
Sony XM-2002GTR Car Audio Amplifier Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
 Grubhead
Grubhead
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
