Question about RCA DRC8295 DVD Recorder/VCR Combo
RCA 8295n dvd-vcr combo starts recording from VHS tape to disk and then stops.
    Scholar:
  • 106 Answers
Is the VHS tape a store bought movie or show?
MacroVision and other copy protection systems are put into store bought tapes and discs of movies and shows, and are read by your recording equipment. Once it reads this, it stops recording.
Does the screen turn red before it stops? This is one of the indications that MacroVision is stopping you.
Posted on Aug 29, 2009
How do you record dvd to vhs and from vhs to dvd
For VHS to DVD, put the tape to dub in the VHS slot and a blank DVD in the DVD tray. Make sure the DVD is compatible with the DVD recorder (see the recommended disc list) and is unfinalized if you are using a R/W disc. Close the tray. Set the unit to VCR mode with the DVD/VCR button. Advance the tape to the place that you want the recording to start. Then press the Dubbing button (either on the remote or the unit itself). Select the recording mode (SP, LP etc), highlight Dubbing then press Enter or Dubbing. Press Stop to interrupt the recording.
For DVD to VHS, put a blank tape in the VCR (make sure the protection tab has not been broken off) and the DVD to duplicate in the DVD tray and close the tray. Put the unit in DVD mode by pressing the DVD/VCR button. Find the point at which you want to start recording the DVD. Again press Dubbing and set up the recording mode and highlight Dubbing and press Enter or Dubbing.
Note that copyprotected content can not be recorded.
The manual for this recorder is on the right side of the page here: http://www.lg.com/us/tv-audio-video/video/LG-dvd-recorder-RC897T.jsp . See page 48 for the screen captures of setting the recording mode part of the dubbing procedure.
I hope this helps.
Mar 19, 2011 | LG RC897T DVD Recorder/VCR Combo
MY RCA DRC 8320n DVD Recorder/VCR Combo will not accept tapes. DVD works fine. RCA help line is a joke. I will never buy another RCA product.
Yah, you're going to be taking that in for repair. I worked for couple of years at RCA / Sony / Panasonic / ... and 60 more names - service center. When a VHS Cassette loading mechanism doesn't work - it probably needs loading motor or loading gear, something repaired. At the cost of DVD and VHS combos these days I'd call it Not Worth Repair (NWR) out of the starting gate. At least $50 an hour, at least 2 hours ... that's beyond the cost of a new one.
Nov 22, 2009 | RCA DRC8320 DVD Recorder/VCR
I need help converting vhs tapes to dvd+r
If you have both a VCR and DVD recorder there is no problem. Just connect the A/V output from the VCR to the A/V input of the DVD recorder. Start the tape and press record on the DVD recorder. (these connection are RCA type ans coloured white, red, abd yellow. Just connecxt them colour to colour. Couldn't be simpler. When the recording finishes, transfer to an optical disk. After finalizing, the VOB files from the optical disk can be converted to mpeg4 or any other format you desire using your PC.
Jul 10, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
How do I record my vhs tapes to Disk
I have done a lot of dubbing on my machine. First make sure the DVD is formatted. When you put in a new disc it should ask you if you want to initialize. Once that is done, switch to VCR mode. push play on the VCR then push the DUB button on the front of the machine. I hope it helps.
Mar 02, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Jan 27, 2009 | RCA DRC8300N DVD Recorder/VCR
Dvd/vcr/recorder
sounds like it's not set up for more than a quick record...check the settings..
Mar 17, 2008 | RCA DRC8300N DVD Recorder/VCR
I cannot watch my dvd's i taped on the philips on any other dvd player
YOU MUST FINALIZE THEM BEFORE YOU PLAY IN OTHER DECKS, CHECK YOUR MANUAL
ON FINALIZING THE DISK
Dec 17, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
RCA DRC-8295N
It sounds like you got the old electrical surge blowout going on there bud. It could be as simple as a bad regulator transistor or IC. the onlt real way to tell is to troubleshoot this unit by getting a service manual and a meter and checking your standby and switched power supply. Now since this is a recorder maybe it is wort a look at by your local repair depot or is there any warrantee left on it at as my book says it has a 1 year warrantee but just dont volenter any info how it went out if ya get my drift. Good Luck
May 22, 2006 | RCA DRC8300N DVD Recorder/VCR
RCA DRC8295 DVD Recorder/VCR Combo Logo
257 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
