Question about Adtran NetVanta 3200 Router
Setting timezones on Netvanta 3200 router
Need command to set Timezones on Netvanta 3200 router ??
Posted by bfaubert196 on
Anonymous
    New Friend:
Clock auto-correct-dst
clock timezone -5-Eastern-Time
clock set 23:58:00 05 May 2010
Posted on May 06, 2010
How do I factory default adtran netvanta 1224st?
Every router has a reset button on it.
Try to find that button and press it for 30 Second.
It will reset your router to factory setting.
I hope it will help you.
Thanks for using FixYa.
May 19, 2011 | Adtran NetVanta 1224ST PoE w/ UK power...
Is there a way to perform local password recovery on a Netvanta 3200 router?
can you not reset it, there should be a small hole at the back of the router
just push the point of a pen in the hole and that should reset it..
Nov 24, 2010 | Adtran NetVanta 3200 Router
I have an Adtran NetVanta 1335 Router that keeps shutting itself off everynight after my store does all it downloads. I have put it onto it own power supply, any assistance to help keep it up would be...
You need to enter maintenance mode (a web interface) and check the power settings from there as some of these have the ability to sleep etc at preset times.
sort of added security and green all in one function
Aug 31, 2010 | Adtran NetVanta 1335 Router (1700515E2)
Can't connect Dell TrueMobile 1184 with Adtran NetVanta 3200
It sounds like you need to "crossover" the connection.
Using a crossover patch cable to connect the two devices is the first thing that comes to mind. (http://en.wikipedia.org/wiki/Ethernet_crossover_cable)
However, some routers/switches have physical buttons on ports to cross them over or you can use their web-based management to change port settings.
I hope this helps.
Jan 27, 2010 | Adtran NetVanta 3305 Router
Can not ping our netvanta 3200 from behind a Linksys nat router
The switch between the NAT routers and the Netvanta had some faulty ports ... the physical connection was broken. Once the switch was replaced, the internet connection was restored.
Dec 29, 2009 | Adtran NetVanta 3200 Router
Password apparently lost on Netvana 3200 - any hidden reset?
http://kb.adtran.com/display/2n/articleDirect/index.asp?aid=1786&r=0.6352198
connect console cable
Bootstrap# bypass passwords
Bootstrap# boot
Oct 20, 2009 | Adtran NetVanta 3200 Router
Netvanta reset password
Enter admin as the username, enter your admin password, and click the OK button. (The default password is
password.) Here is a link to your manual:
http://www.wedophones.com/Manuals/Adtran/NetVanta%202000%20Series%20Quick%20Start%20Guide%20(Rev%20B)%202nd%20gen.pdf
May 25, 2009 | Adtran NetVanta 3200 Router
Forgot password of Adtran NetVanta 1224R Switch
  1. Recovering passwords requires direct physical access to a unit. This procedure cannot be performed remotely over Telnet, SSH, or the Web GUI.
  2. Connect a straight through serial cable to the console port of the unit.
  3. Configure a VT100 session (i.e. HyperTerminal or ProComm) using the following settings: 9600 bps, 8 bits, no parity, 1 stop bit and no flow control.
  4. Reboot the unit by removing the power.
  5. As the unit boots, you will be given the opportunity to break into bootstrap mode by pressing the ESC key within 5 seconds.
  6. While in the monitor mode issue the following commands:
Bootstrap# boot
Notice that you are issuing the boot command not the reload command following the bypass passwords command. Once the unit has finished booting up, you can issue the enable command and you will not be required to enter the privileged (i.e. enable) password. Once you are in privileged mode, you can view the configured passwords by using the show run command. A new password can also be entered by going into global configuration mode by using config terminal command and issuing the enable password <word> command where <word> is the new password. Also remember to change any Telnet, SSH or Web GUI passwords if necessary.
Below is a sample output of these steps:
Router (1200990L1)
Executing bootstrap...
ram: 268435456 bytes of RAM detected.
Serial Number: LBADTNXXXXXXXXX
Bootstrap version: 11.03.00, checksum: 0F3C, Thu Feb 09 17:40:34 2006
vfs: NONVOL: 120 tracks, 128 sectors/track, 1024 bytes/sector.
eth0/1: initializing...
eth0/1: MAC address is 00:A0:C8:XX:XX:XX
bootstrap: Checking boot configuration...
bootstrap: Primary image is 'NONVOL:/NV5305A-12-01-07b-E.biz'.
bootstrap: User escaped to command line interface.
cli: starting command line interface...
cli: starting user interface
Press '?' for help.
bootstrap#bypass passwords
bootstrap#boot
Mar 20, 2009 | Adtran NetVanta 1224R 24-Port Ethernet...
Configuring remote access
Here is a document which describes this.
Please download, it then:
1. Connect the console.
2. Configure ip address of the router
3. Enable telnet access.
Here is the document location:
http://www.adtran.com/adtranpx/Doc/0/UL9SGGEDF2I4D51F3K4IIEE2FC/61202860L1-13B.pdf
Jan 09, 2009 | Adtran NetVanta 3200 Router
Adtran NetVanta 3200 Router Logo
187 people viewed this question
Top Adtran Computers & Internet Experts
Vincent G
Vincent G
matt
matt
gary433
Are you an Adtran Computer and Internet Expert? Answer questions, earn points and help others
