Question about Casio FX-115ES Scientific Calculator
How do i plug in algebra problems on my casio fx-115 es calculator.
Posted by gabby72006 on
  • k24674 May 11, 2010
    Hello, What do you mean by PLUG in. Give us a simple calculation you want to perform.
k24674
  • Casio Master
  • 8,091 Answers
Tell us what you want to do and we will be happy to help you. Algebra is a very wide subjetct.
Here is the link to your manual and its appendix. They will tell you what the calculator can do.
http://support.casio.com/manualfile.php?rgn=1&cid=004001004
Hope it helps
Posted on Sep 06, 2009
Anonymous
    New Friend:
Y=3X
Posted on Mar 08, 2010
1 Related Answer
Anonymous
SOURCE: Factoring polynomials "Algebra"
Mode>choose "5"
choose equation format "4"
input the coefficient for a which is "1" and hit "="
input the coefficient for b which is "4" and hit "="
input the coefficient for c which is "3" and hit "="
input the coefficient for d which is "12" and hit "="
Hit "=" for X1
Hit "=" again for X2
Hit "=" again for X3
Posted on Oct 20, 2008
Is it possible to solve eqn in this 82ms calculator
Sorry, It is not possible to solve equations on the Casio FX-82 ms. Try the Casio FX-115 ES/ FX-115 ES Plus, FX-991ES/ FX-881 ES Plus C.
Oct 29, 2013 | Casio FX82MS Scientific Calculator
Which model of casio csn do integration in limits
The Casios FX-115 ES , FX-115 ES PLus, FX-991 ES, FX-991 ES Plus C can perfom numerical differentiation at a point, and numerical integration between two given limits.
Aug 12, 2013 | Casio FX991ES Scientific Calculator
How we can multiply two algebraic equation in 991 ES CASIO calculators
The Calculator does not have a Computer Algebra System (CAS), and cannot perform algebraic operations with variables. However if you enter some expression with variables, it can solve for one unknown after it prompts you for the values of the others
Oct 05, 2012 | Casio Fx-991es Scientific Calculator
How do I factor using the fx-115 ES calculator? would a problem like 9x^2+24x+16-Z^2 be solvable on this calculator? If not, does Casio sell any calculators that would help me factor this equation?
No, your calculator cannot factor polynomials. You need a calculator that has a CAS (computer Algebra System)
Yes Casio sells calculators with CAS: The FX-Algebra 2.0 and 1.0, the FX-9860GPLUS/GII SD, the GRAPH85 or 80 and the Graph 100+. You also have the CLASSPAD Series 300PLUS and 330.
TI and HP also have CAS calculators.
Texas Instruments
TI 89 /Titanium, Voyage 200PLT, TI92PLUS (discontinued), TI Inspire CAS.
Hewlet-Packard
HP 48G/G+/GX, HP40G, HP49G/G+ and the top of the line HP50G
Oct 28, 2010 | Casio FX-115ES Scientific Calculator
How do I compute binomial Probability distribution on a casio fx 115 es
Go to link below and download the manual it is all in that. support.casio.com/pdf/004/fx-5800P_E.pdf
Mar 07, 2010 | Casio FX-115ES Scientific Calculator
Casio FX-115 ES: SIN,COS,TAN (answer isnt correct)
It may be due to the angle unit used. You can have angles in degrees, in radians, and in grads. You should set the default angle unit to waht you problem calls for.
To set degree as default SHIFT MODE 3
To set radians as default SHIFT MODE 4
To set grads as default SHIFT MODE 5
The values of angles calculated by the inverse trigonometric functions are in the default unit that is set . This may be the source of the wrong answers that you get.
Hope it helps.
Sep 16, 2009 | Casio FX-115ES Scientific Calculator
Casio fx-115 es ---- turning decimal answers into radical form
Sorry to disappoint you but you cannot do it due to the fact that the representation of irrational (SQRT(2), ..) and transcendental (e, pi, etc.) numbers on a calculator or even a computer is approximative : a number like sqrt(2) has an infinite number of decimal digits while the number of internal digits a calculator uses to store results is limited (10, 12, 15 or even 24).
Once an irrational or a transcendental number has been evaluated numerically it generally ceases to be exact.
If you want to manipulate algebraic expressions, you need a calculator that has a CAS (computer algebra system) operating system and a symbolic algebra option.
Some exemples of calculators with a CAS are The TI nspire CAS, the HP 48 series, HP 49, HP 50, Casio ClassPad3xx, the TI 89titatium, the TI Voyager 200PLT, the TI 92 and Ti 92Plus. The ones with a fullblown keyboard might not be accepted on certain standardized test.
You may also try to get some emulators on the Internet for the HPs or the TI 8xx and play with them on the computer.
Hope that helps.
Jul 05, 2009 | Casio FX-115ES Scientific Calculator
Math book for the fx-115-es
Use your internet seach engine or go to the casio worldwide web site. A google search returned this link to the New-Zealand site.
http://casionz.co.nz/Site/Pronto/Files/user_manuals/FX-115ES%20991ES.PDF
Hope it helps
Mar 09, 2009 | Casio FX-115ES Scientific Calculator
Mode>choose "5"
Hit "=" for X1
Nov 18, 2007 | Casio Office Equipment & Supplies
Casio FX-115ES Scientific Calculator Logo
483 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Colin Stickland
Colin Stickland
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
