could you mention the name of the program you are trying to install on windows vista. You can search your program on the following webiste . Then there is Vista compatible version available if not. There would be no way to make it to work on vista
http://www.microsoft.com/windows/compatibility/
Thanks for using fixya
proton
Check the program's website for compatibility issues. see the "system requirements", and also check if your windows vista is 32 or 64 bits.
Right click on the program then click properties. Then click the tab Compatibility. Then tic "Run this program in compatibility mode for:" The select operating system form drop down box. Then click OK
