Linksys Wireless-G WRT54G Router Logo
Anonymous Posted on Aug 28, 2009
I need to set up a secure location for my wireless internet. How do I do so?
Anonymous
Level 1:
Problem Solver:
  • Contributor 16 Answers
  • Posted on Aug 28, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
16
Questions
0
Helped
2484
Points
29
2answers
How should I respond to error code:51332 unable to connect to internet?
You need to enter the router's password.
How should you respond? That depends on your mood.
Forgotten password for wifi network
Which operating system ??
Your wireless Internet password is the encrypted security pass phrase that was set up when you installed your wireless router.
Your router allows you to access the Internet.
If you have access to more than one wireless network, you may need to remember multiple passwords.
If you happen to forget one password, you have two options: reset your password or locate the current password.
Windows 7 allows you to view the security characters of all your wireless network passwords.
Click the "Wi-Fi" network icon located on the Window's taskbar.
Right-click the name of your network's "SSID" name and select "Properties" from the drop-down menu.
Click the "Security Tab." The network security key is now visible but unreadable.
Click the "Show Characters" check box and this will reveal your wireless password.
http://www.thewindowsplanet.com/939/how-to-recover-wi-fi-network-key-in-windows-7.htm
or
Reset My WiFi Password
Wireless networking is a common feature in homes and offices.
Wireless routers provide access to a single Internet source, and wireless passwords ensure that only select users can access the network.
If a password is forgotten or lost, the password can be recovered or reset by accessing the router's Web-based settings menu.
Most wireless routers also have a reset button, which is capable of returning the router to its default settings which includes resetting the password.
Connect to your Wi-Fi or attach your computer directly to the router with an Ethernet cable.
Open your Web browser.
Enter the default address of your router.
The default address is listed in your user manual or on the product website.
Linksys and 3Com routers typically use "192.168.1.1" while Netgear routers use "192.168.0.1."
Enter your username and password.
Many routers use "admin" for the username and password by default.
Locate the wireless security settings. Disable the wireless security.
Reset to Factory Defaults
Locate the reset button on your router.
Typically the reset button is a small indented hole on the back of the device.
Insert a long thin object such as a paperclip and hold down the reset button for 30 seconds to revert the router to its factory default settings.
Locate the wireless security settings and add security as necessary.
How To Reset Your Router's Password
http://www.lostintechnology.com/how-to/how-to-reset-your-routers-password
1helpful
Why can't my dell inspiron 530s desktop install
With a wireless connection, your PC can connect wirelessly to a network printer. In addition, you can set up your PC in a location where no phone line or cable connection exists. Outfitting your desktop to a wireless Internet connection is very easy. Just follow these simple steps and you'll be surfing the net wirelessly in a matter of minutes.
Find out if wireless Internet reception exists where your computer is located. If you're located very close to a W-iFi hotspot, like a coffee shop, you may be able to use this network to get wireless Internet for desktop PCs. Also, some apartment complexes and college dorms have free wireless Internet. Your neighbors may have wireless Internet too, which you can ask them if you can use. Buy a wireless network adapter for your desktop. You can obtain an adapter from most electronic stores. Be sure to get a wireless adapter with the proper strength, which depends on how far you are from the wireless hotspot. The easiest adapters to install are those that just plug into an available USB port. Set up your wireless Internet for your desktop PC according to the instructions that came with the wireless adapter. The usual procedure is to plug the wireless adapter into an available USB port. Windows will install the appropriate driver. After your PC recognizes the wireless adapter, select the "Connections" icon in the taskbar (represented by vertical bars). A list of available connections will appear. Select the desired connection. If you are prompted for a password, enter the appropriate password. Click "Connect." You are subsequently connected to a wireless network. Launch your browser and enjoy surfing the Internet wirelessly. If you are the owner of the wireless network, secure your wireless network with a password. To do so, navigate to the "Start" menu and select the "Control Panel." Then select "Network and Internet" and "Network and Sharing Center." Click "Change adapter settings" in the left pane. Double-click the icon of the appropriate wireless connection. The Wireless Network Connection status window appears. Click the "Wireless Properties" button. Select the "Security" tab and select an encryption type from the drop-down selection. Enter a password in the Network security key field. Make sure that the password matches the router settings. Press "OK" when done. Get a wireless internet router for your Internet connection if there is no wireless Internet already in your area. You can buy these online, or at electronic stores. You'll need to set up your router using the accompanying instructions and your own Internet service provider. This is best in a home with multiple computers. Hope this helps
2answers
I am trying to connect a Nook to a cicco wireless router and need the SSID number. Where do I locate this?
The SSID is the Identification of the Wireless network, you set it up in your router settings.
Some routers got a static SSID, you can view it also in your router settings.
4answers
Trying to connect wii to internet....its asking me for a security key
Maybe you set the WEP security in you WiFi Router, if you hace access to console http://192.168.0.1 you can look at it.
Hope will help
Regards,
How to conect with wireless internet
The Network and Sharing Center in Microsoft* Windows Vista* can be used to set up a secure wireless connection to the Internet.
Note: If an Internet connection is not automatically made by the operating system, you may need to contact your access point (AP), broadband wireless router manufacturer, or Internet Service Provider (ISP).
Set Up a Secure Wireless Connection to the Internet
These steps assume that your network adapter; AP or router; and cable, DSL or another type of modem have already been physically connected and configured. They allow you to create a new connection and configure it accordingly.
Follow these steps to set up a secure wireless connection to the Internet.
Note: If a wireless profile does not exist, you will need to create a secure wireless profile before you can set up a wireless connection to the Internet.
1. Access the Network and Sharing Center.
2. Select Set up a connection or network.
3. Click Connect to the Internet.
4. Click Next.
5. Select Wireless. At this point, if the network(s) that are listed say that the network settings do not match the network requirements, as shown in Figure 1, create a secure wireless profile and then follow the steps again.
6. Select a network and click Connect. If you are not connected to the Internet, you may need to contact your AP/router manufacturer or ISP.
To access the Network and Sharing Center, use one of the following methods:
  • Start » Control Panel » Network and Internet » Network and Sharing Center
  • Start » Network » Network and Sharing Center
  • Right-click the network system tray icon (the icon that displays two computer monitors) » Network and Sharing Center
I hooked up my D'link to modem and computer and connection is good. But i can't find it when i search on laptop wireless connection. I think you need i driver but i can't find one. Thank You
4. Click Next.
B52Computers
Can't get my lap top to connect wirelessly to my router. Model # WRT54G2. The laptop says it is reaquiring the network address, but nothing happens.
4. Click Next.
Cant locate it on th internet to secure it with wep
You cannot secure the wireless router over the Internet. Basically the wireless router is secured by opening a browser and entering the wireless router's URL configuration address.
To secure and set up encryption on your wireless router please follow my instructions - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
The configuration URL for the Linksys is http://192.168.1.1 and the default login = admin and the default PW = admin
I was able to connect my router to my wireless laptop successfully. Then I applied security settings to it using my laptop. And down went my internet. The router is working perfectly, but my laptop wont...
what you need to do is go to your wireless settings on you computer and remove the wireless network that you connected to before.
then go and reconnect to your network any wireless security settings that need to be entered should be asked for if not then you will have to reset router and the best way tto do that is to locate small reset hole on rear of router and push and hold for 10 seconds, router must be powered on
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
