Toshiba 57H82 57" Rear Projection Television Logo
Posted on Aug 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Distorted & Wavy Picture
We have the exact same problem, but also have an additional problem. We can no longer use our DVD or VCR players on this TV. We disconnected the players and tried them on another TV and they worked just fine so it has something to do with the TV.
Is our TV just worn out or do you think it can be repaired?
Tareq Bin Mostaq Mostaq
Level 3:
President:
  • Toshiba Master 1,449 Answers
  • Posted on Aug 28, 2009
Toshiba Master
Level 3:
President:
Answers
1449
Questions
31
Helped
614568
Points
3628
Yes you repaire an authorised service centre
I think it's the av channel but not sure
Make a reset to this set. Refer its user manual for details about how to do this.
I have a Sylvania SRD3900 DVD Player / VCR Combo that I purchased about 6 years ago. The VCR part is causing problems. When I try to play movies the picture is distorted with no sound, but it plays back...
The tracking needs to be adjusted. Sometimes it's a knob on the VCR, and sometimes it's a control on the remote. Adjust it for the best picture, and the sound shoud be restored.
Good luck, and hope this helps..
1helpful
How can I get ride of the pscan split screen view on my memerex vcr-dvd player without the remote control and no manual
I'm not sure what is model number of your VCR-DVD combo so providing you general info to turn off pscan.
Put disc in player, press play to have distorted picture then press stop button to stop playback.
Now press and hold Stop button on unit for 6 seconds that will turn off pscan mode.
Or let me know exact model number of your player to find out solution.
Thanks.
Have Samsung HLN567W and recently started having
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Adding vcr & rec to a '93
Please hook up VCR with TV through RF cable and check picture of VCR playback in TV.
Now you can hook DVD player video-audio out in VCR input and can have dvd playback picture in TV via VCR modulator.
If you want to listen sound via receiver then hook audio red-white cable between VCR audio out and receiver audio in terminals.
Let me know exact model numbers of units to help you out more.
Thank you.
3answers
Dvw-7200: no picture on the dvd
My dear friend I think you maybe by mistake put the function progresive scan on the dvd check on the remote control for that function and try to deactivate.Good luck
Dvd/vcr
It could be a bad cable between your vcr and the TV. See if you can use another cable.
Playback problem on SP Tapes - Top 1/3 of screen wavy lines
there are guide posts that the tape goes around, they need to be adjusted if your good at that stuff take off cover and while playing tape be careful you could damage video head.with flat srew drive . adjust right post buy turning clockwise or counter clockwise. this could be hard i hope i helped , When i first started ny video shop 1987 we started doing only vcrs.
The video head also could be bad. thanks doctor video
Dvd/vcr sylvania combo
did a few google searches and suggestions were made to buy a**ther vcr...** way to fix the vcr heads. thanks anyways!
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
