Delta 2402 Classic Single Handle Kitchen Faucet with Side Spray Chrome... Logo
Sandra Gray Posted on Aug 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a delta single handle kitchen faucet. It has shifted and is not centered. It is hard to move the handle to the left for hot water. How do I center it and tighten it back?
Anonymous
Level 2:
Scholar:
  • Expert 44 Answers
  • Posted on Sep 09, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
44
Questions
0
Helped
24649
Points
108
Loosen the retaining nut holding the faucet to the underside of the countertop/sink. Use a deep socket or basin wrench (http://images.lowes.com/general/b/bwrench.gif)
Straighten out the faucet and have someone hold it straight
while you tighten the retaining nut.
This problem may be a sign that the faucet needs some maintenance. You may want to read this as well:
http://www.fixya.com/support/t2480325-delta_single_handle_kitchen_faucet_pull
Why no water thru delta single lever kitchen faucet
can be a number of issues: clogged aerator, water supply is turned off, or supply lines are kinked, debris behind cartridge blocking flow, rubber seats out of place.... What has changed to cause problems?
1helpful
I"m removing and replacing a
Since you are replacing the Delta Faucet Delta 470-BL-DST Signature Single Handle Pull-Out Kitchen Faucet With Spray faucet, bend the water supply lines out of the way, and then use a standard basin wrench to remove the nut.
We have a Delta 172 single handle faucet. We had our hot water heater replaced. Now it takes longer for hot water to get to the faucet. Could debris (calcium build up, etc.) from the replacement get in...
Yes, debris from water heater replacements often breaks lose and gets stuck. The problem could potentially be anywhere between water heater and the faucet. The faucets shut off valves or the Delta faucet cartridge itself. Turn the hot and cold water valves off under the sink and disconnect the water supply lines from the faucet. aim the water supply lines into a bucket and turn the valves on one at a time. If there is a significant reduction in the water pressure and volume on the hot water side, you need to replace the shut off valve. If there is no reduction in water pressure, you need to clean and/or replace the Delta faucet cartridge. Contact Delta to receive free replacement parts.
1helpful
Poor hot water pressure form Delta single lever faucet
it can be adjust take handle off and remove locking collar first turn water off,
it has a metal or plastic ball with a shaft for the handle it may have spun or a washer may be bad under it,
you can get a replacement at lowes or Home depot to replace it if this is the problem .
2helpful
Moen single handle kitchen faucet, Hot water and
Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
7helpful
2answers
Single handel kitchen faucet: Over time the
shut-off the water, pull the handle and the spout. change the 2 "O"ring and make sure the spout body has no dirt in them. apply some the plumbing grease bewteen the spout body. put everything back.
2helpful
Sprayer loosing presure
If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)
Here are the instructions:
  1. Turn off water to faucet.
  2. Remove handle.
  3. Remove top cap.
  4. Turning spout back and forth gently lift and remove.
  5. Remove and replace diverter.
Hope this helps and please remember to rate this!
Top Delta Plumbing Experts
john h
vince
Paul Carew
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
