I have seen this caused by having a mouse plugged into mine. I have removed the mouse and touch the touchpad and it has come up from sleep.
That very well may not be your problem.
Here is the procedure that is recommend from Apple to help with the not waking from sleep problem. I included both methods as it is not clear which macbook you have. I also included the link to the article at the bottom.
The System Management Controller is an integrated circuit (computer
chip) that is on the logic board of the computer. As the name implies,
it is responsible for power management of the computer. It controls
backlighting, hard disk spin down, sleep and wake, some charging
aspects, trackpad control, and some input/output as it relates to the
computer sleeping.
Over time, the settings in the System Management Controller may
become unusable, which can result in operational anomalies with the
computer. Examples include not turning on, not waking from sleep, not
charging the battery, or not recognizing the AC Adapter, among others.
MacBook (13 inch, Late 2008), MacBook Pro (15-inch, Early 2008), and MacBook Pro (17-inch, Early 2008)
Note: Starting with MacBook Pro (Late 2008) and
MacBook (Late 2008) models, you may instead use the reset method for
MacBook Air (below) to reset the SMC. All earlier models of MacBook
and MacBook Pro must use the method described above, which involves
removing the battery.
MacBook Air and MacBook Pro (Late 2008 and later)
Note: You must use the keys on the left side of the built-in keyboard.
Here is the link to the article at the Apple support site.
http://support.apple.com/kb/HT1411
