Question about Camping, Backpacking & Hiking
Does the Uberhaus Outdoor Wall Lantern Model 03005007 work okay with an LED bulb in it? Seems to continually glow very faintly.
Posted by Graham Humphrey on
4 Related Answers
mohammed387
mohammed marika thambi
  • 1952 Answers
SOURCE: cookworks microwave not working
replace the fuse see if it blows again you can get those at radio shack 250 volt either 15 or 20 amp get 3 or 4 of em
Posted on Jul 29, 2009
SANTOSH KUMAR
  • 115 Answers
SOURCE: my cpu green led is glowing but monitor screen is
There are No display in your system .Pls remove Power cable from CPU and again plug it and start your system.If display still not comes then pls remove RAM chip from slot in the Motherboard and re-install goods one and check it.if still display not come then issue with Motherboard .Its detter call vendor for repair the Motherboard.
Posted on Nov 19, 2009
aquaman987
Gary Nigro
  • 927 Answers
SOURCE: I need to change a
That would probably work. I have this problem with my kitchen fixture & I have had to break the bulb (when twisting) then use a pliers to remove the base.
If you use oil, make sure the fixture is OFF and wipe out the socket thoroughly before installing the new bulb.
Gary
Posted on Sep 04, 2011
jeicrash
Jeff richtman
  • 324 Answers
SOURCE: How do I set my uberhaus digital outdoor timer(TM064)? I use for my outdoor Xmas lights and have misplaced the manual. Thanks Steve
I was able to find this, It's not much, but perhaps it's enough.
http://pdf.lowes.com/operatingguides/827214003012_oper.pdf
Posted on Dec 02, 2014
Can I get a battery compartment for Innovage outdoor Lantern
Find the exact model number and try: https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR0.TRC0.H0.Xinnovage+outdoor+lantern+parts.TRS5&_nkw=innovage+outdoor+lantern+parts&_sacat=0
Nov 09, 2017 | Innovage Camping, Backpacking & Hiking
I received a 21 LED lantern for Christmas and got the 3 "D" batteries and the thing glows at what should be shut off point. They only way to shut it off is to remove the bottom plate. Is this normal
Turn clockwise and counter clockwise the lantern.(The upper side leds)
If not check the pin of switch that makes the contact to the upside.
Jan 01, 2015 | Ovens
How to turn on threshold solar table lantern
Were you able to figure out how to get it to work? I have two that I can't get on either. Thanks!
Mar 23, 2014 | Threshold outdoor lantern: Tabletop Light...
I purchased a lantern model # jasco 17300 and the light quit working after 6mos use
You may get it repaired but the cost will be the same as buy a new one or much more than get a new lambp. So I suggest you purchase one from online store:
http://www.aurabuy.com/outdoors-76-led-ultra-bright-waterproof-headlamp-with-adjustable-band-black-silver-4-aa.html
Mar 26, 2013 | Camping, Backpacking & Hiking
Projector cp-sx635 lamp indicator glows red (RED). intimate trouble shoot pl
sounds like the bulb will not fire up. most likely cause is the bulb needs replacing
Jan 03, 2013 | Hitachi CPSX635 4000 Lumens LCD Projector...
I need to change a bulb in an outdoor lantern. It will not come out. Can I oil it?
Gary
Sep 04, 2011 | Garden
Coleman rechargable lantern Model 5327A750. Have not used it in a while have left it on charge for over 24 hours. the night light works but the main light does not go on. Replaced the bulb and still...
just read the charging instructions. Charge for 16-18 hours. If stored for more than 6 months recharge for the full 16 hours. Do not leave the lantern on after the battery has stopped, has overdischarging the battery can cause problems in recharging to a full charge. If this does happen, switch lantern to off and recharge for 40 hours.YES 40 hours. Only the LED is the only light to be used while charging. If you hane the other light on hi or low the battery does not charge.
Hope this helps
Oct 24, 2010 | Sport & Outdoor - Others
Camping, Backpacking & Hiking Logo
173 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Kardoc
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
