Please can u tell how to record from dvd to [email protected]
Did u find a answer to this....i would also like to [email protected]
LG HDD/DVD RECORDER RH399H
Insert an empty DVD + R. The system asks whether to format - Format.
Select a recording on the HDD to copy to DVD.
Enter
Select dubbing
with arrows select type of recording to make (XP, SP, EP etc)
The system show the duration you can copy to you DVD. If small enough the FAST option also appears.
If big copies while playing the orriginal (I.e. playback speed)
Hi Jacques,
As die DVD deur die rh399h opgeneem is speel mens terug deur die dvd instede van die HDD te kies en weer via Dubbing oor te kopie.
My stel is nou by Lg se agent in Centurion (VHF electronics) omdat hy ophou aanskakel het en ek het weer gevra waarom die stel nie buite leesbare dvd's maak nie. Ek sal berig wat die antwoord en hopelik oplossing is. Ek het nog nie probeer of die stel standaard (komersiele) dvd speel nie want ek het 'n ander multi dvd speler.
Sal probeer sodra die stel terugkom.
Wonder of die probleem net in die RSA voorkom?
Why do my copied DVD's copied from LG RH399H recorder don't want to play on my PC or any other device exept the recorder itself?
