Question about Haier Heating & Cooling
I have Haier portable air conditioner with an upper and lower drain..my manual doesn't give instructions on which one to use my model #HPD10XCR-LW portable
Posted by Theresa Lee on
5 Related Answers
Anonymous
SOURCE: 9000btu Haier portable air conditioner
I own the Haier 9,000-BTU Portable Air Conditioner - White. This is the second day that my unit has blow out air that smells really bad. I went to check my unit to find that there was a leak of some sort of chemical that smells like what is blowing from my unit. What should I do?
Posted on Jul 18, 2008
Richard Z
  • 5 Answers
SOURCE: Everstar portable air conditioner
IF ANYONE NEED TO SEE THE OWNERS MANUAL FOR THE
EVERSTAR PORTABLE AIR CONDITIONER MPM2 , MPM210CEBB6,
MODELS # MPM2 - 10CE - BB6
MODELS # MPM2 - 10EE - BB6
MODELS # MPM2 - 10CR - BB6
MODELS # MPM2 - 12CE - BB4
MODELS # MPM2 - 12EE - BB4
MODELS # MPM2 - 12CR - BB4
YOU CAN E-MAIL ME AT - [email protected]
I'LL SEND IT TO YOU IN A PDF FILE
(AS LONG AS I DON'T LOOSE IT IN MY COMPUTER )
Posted on Sep 12, 2008
kaycee71
Kerry C
  • 37 Answers
SOURCE: I have HAIER HPAC 99ER Portable air conditioner
Make sure your filter & the coils (area under the filter) are clean or that the evaporated water is not overfilled by draining it manually by pulling the plug on the lower rear of the unit (into a bucket of course.) I'm hoping you had gotten an answer sooner...
Posted on Aug 28, 2009
Anonymous
SOURCE: beaumark portable air conditioner operation
Beaumark air conditioners are made by GE…head over to their site and download a manual for their air conditioners - they are very similar.
http://products.geappliances.com/ApplProducts/html/GEAResults.htm#Category=Window_Room_Air_Conditioners
Posted on Jul 06, 2010
Martial Cote
  • 3 Answers
SOURCE: Leaking Haier Commercial Cool air conditioner.
there are 3 drain holes in the primary pan right underneath the evaporator that need to be clean with a pipe cleaner or a wire of somekind and there is also a secondary drain behind it that will work only if the unit is 100% level. To access the primary drain pan you have to take all the screws of the back cover 5 on each side and 3 in the center above the electric cord and behind the air filter and only then will you be able to see these very small holes. Use a flashlight to make sure. Have fun!Reply
Posted on Jul 07, 2010
ZCF/LW-17-2 Remote Control AC-5620-36
Following amazon item link can be compatible for your Haier ZCF/LW-17-2
What's important is that it display in Fahrenheit.
Other ebay or amazon sellers sell replacement in Celsius
Amazon com Replacement for Haier HRRM Air Conditioner Remote Control Model...
Jul 28, 2013 | Haier ZCF/LW-17-2 Remote Control...
Fan is making rubbing noise
Time to have an expert look at it as it might be a fan about to fail or something worse.
Aug 30, 2012 | Haier 8,000-BTU Commercial Cool Portable...
Need to obtain a operations manual.
To download the Owner's Manual for your Model Haier Portable AC. Go to the following link and oat Product Support and Downloads and click on your model in the lower left of the page.
http://www.haieramerica.com/12-000-btu-cooling-11-000-btu-heat-capacity-115-volt-portable-air-conditioner-cpn12xh9
I hope this information was helpful. Thanks for choosing FixYa.
Aug 26, 2011 | Haier CPN12XH9 Portable Air Conditioner
How do i change the time? I'm trying to program the remote.... Haier ZHF/LW-17-2
Open battery compartment. Use a paper clip to press the little button marked "CLK". Set hours and minutes with buttons on front. Press button again with paperclip to save the settings.
Jul 06, 2010 | Haier HWR12XCB Air conditioner
My portable air conditioner Haier started linking
Hi. Check the drain hose and look for kinks and partial blockage. Even algae can often block these tubes. J.
Jul 06, 2010 | Haier HPR09XH7 Portable Air Conditioner
I have HAIER HPAC 99ER Portable air conditioner and just quit working. There is a red flashing light blinking.
Jul 19, 2009 | Haier HPAC99ER Air Conditioner
Instruction manual
Click on the link below type in your model number then hit enter. It will display your product manual
http://www.haieramerica.com/en/support/modelsearch
Aug 19, 2008 | Haier HPM09XC5 Portable Air Conditioner
Heating & Cooling Logo
66 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Larry Blais
Larry Blais
Peter Schmidt
Peter Schmidt
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
