Question about Refrigerators
Hello I need the door seal, door trays for both freeeze and fridge and a replacement fruit and veggie drawer can someone refer me to a place of business where I can find these items. Thank you
Posted by Janice Freeman on
  • Janice Freeman
    Janice Freeman Jul 14, 2019
    I have a Sanyo refrigerator SR-1031 10.3 cubic ft
Andrew Taylor
    Top Expert:
  • Refrigerators Master
  • 33,014 Answers
Whoaaa, pretty lady, handsome man :>)
The Google search query is
make model replacement parts
The 1030 may fit
https://www.appliancepartspros.com/search.aspx?model=sanyo%20sr-1030%20refrigerator
https://encompass.com/model/MSCSR1031W
You could also Google Search by part number. The list is here
https://www.manualslib.com/manual/402545/Sanyo-Sr1031w-Refrigerator-10-3cf-2door-Frost-Free.html
Posted on Jul 16, 2019
5 Related Answers
Anonymous
  • 42 Answers
SOURCE: kenmore elite fridge crisper drawer freezing stuff
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
Posted on Apr 06, 2008
Anonymous
SOURCE: My Whirlpool refrigerator leaks water
I also could not find the drain plug that everyone is saying to clean out. The only obvious things were styrofoam coated vents that went down to the fridge.
I have the same fridge with the sheet metal and cardboard in the back. My mfg. date is 6-04. That date is found near the ser. # and model #. My Whirlpool model # is ET1chmxkb03 THERE IS NO DRAIN TUBE RUNNING DOWN THE BACK!! It is all internal. Here is how I fixed the problem.
First, unplug the fridge. Empty all contents from the freezer and remove the shelf. Your food will be fine. Tell your wife not to worry!! You're going to need to remove the entire back panel of the freezer. Not hard. Remove the ice maker by unscrewing the single bottom screw and LOOSENING the two screws located above the ice slots. No need to remove them. they simply hang the icemaker in place. unplug the wiring assembly from the ice maker. set ice maker in sink if it has ice in it.
I had a lot of ice in the bottom and back of the freezer so i carefully chiseled and cleaned as i went. try using some hard plastic pointy thing to chisel. if that doesn't work use a screwdriver VERY CAREFULLY. I am not responsible for damages. ha.
the plastic "Y" shaped piece that covers the fan needs to come off. gently push down from the top to undo the two tabs that are holding the top to the wall. any resistance you feel is ice holding everything together. a hair dryer can also be useful to loosen things up. its going to get watery so keep towlels ready to sop up.
After the "Y" piece is off, you should only have two nuts or screws at the top of the panel. undo these and work off the panel. careful to push the wiring harness through the hole and the ground wire simply clips on the metal panel.
if you have a lot of ice at the bottom you'll feel resistance getting the panel off. scrape off as much ice as you can from the bottom and work the panel back and forth until it comes free. there is nothing holdin the panel in place at the bottom. it's just the ice.
when the panel is off you'll seea thin aluminum pan at the bottom probably covered in ice. keep chiseling (carefully) and you'll come across the drain hole everyone keeps telling you to unplug. this is the start of the tube that comes out into the pan under the fridge. i kept chiseling until there was no ice left anywhere in the freezer. always wiping and cleaning with the towels. there is also ice under the thin aluminum sheet. try to find a way to get this ice out too.
i tried several ways to get the ice out from inside the drain tube. even a little salt. boiling water from a turkey baster worked the best. my ice was frozen down about an inch so it took a few tries.
my drain pan was bone dry at the beginning of all this so i kept looking for water down there. finally it showed up.
pour little extra hot water down there for good measure and if you have some kind af flexible tubing to snake down there to clean it out it would be a good idea. 1/4 inch fish tank air tubing woorks pretty good. there are some bends in the drain tube so you might have to work it down.
hopefully this will fix the problem. reverse the steps to put everything back together being sure to reclip the groundwire to the icemaker. put the food back in the freezer and tell your wife instead of griping about the food being left out, maybe she should thank you for being a he-man and saving the family $500 by fixing the friggin thing yourself!!
Posted on Jan 16, 2009
Anonymous
SOURCE: Vegetable and fruit crisper drawers freezing foods
I had the same problem. Apparently the problem is the main control board. According to the technician that came out to fix mine there is a design flaw and these boards are very sensitive and can blow a circuit or malfunction from the slightest power surge. What happens then is that the control board doesn't "tell" the fan to turn on and off at the right time so the fridge and freezer warm up too much before the fan kicks in and then it cools everything down but since the fan isn't running at the correct intervals and circulating the air all of the cold air settles to the bottom which causes the produce in the drawers to freeze while the top shelves get warmer. I had done a fair bit of research before calling GE and came to the conclusion that this was a common problem. So I pressed them and was able to get the fee for the part waived (before I made the service call appointment) which was around $150. The part now has a 5 year waranty which I find funny, because I'm not sure why it wouldn't have that upfront as my refridgerator is only 2 years old. Whatever!! Unfortunately, unless you have indepth knowledge of refridgerator repair there is no way around the service call and labor. Anyone buying a new model of refridgerator (any company) should consider an extended waranty. The service tech also told me that all refridgerators made after 2001 are required, by law, to have an electronic mother board which in all likelyhood will fail at somepoint prior to when you are ready to buy a new fridge!
Good Lucak!
Posted on Feb 11, 2009
bradgreen
  • 166 Answers
SOURCE: How to fit a Zanussi fridge door seal
You mean you have a door gasket. A good, step-by-step article on this pesky concept of "panel-screw" gasket installation is found on this handy page:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Appliance_Zone_Refrigerator_Install_A_Refrigerator_Door_Gasket.htm
This should help!
Brad
Posted on May 25, 2009
mfraitag271
SOURCE: Square toilet seat made by American Standard Model TL 235.
This guy Allen in NY has lots of odd seats. Try him 914-963-6895
Posted on Nov 09, 2009
I have the admiral designer series HMG21149 refrigerator and I need the glass that goes on the bottom shelf over the veggie and fruit trays.
go to the service dealer spares for one
if it is no longer available go to appliance repair shops and ask if there is one from a fridge unit going to the dump
Jun 22, 2016 | Admiral Refrigerators
Freezing fresh strawberries
wash. take off stems cut them into halves or quarters , place into zip lock bags or a sealed container. pop into freezer. easy !
you can blend them and put into a ice cube tray as a great way to add flavour to a fruit smoothie - keeps it cold without watering it down.
Mar 25, 2014 | Cooking
Fridge keeps FREEZING food in my fresh food pullout drawer!
temperature sensor is not working
this part to control the temperature in the fridge
Nov 28, 2017 | Whirlpool Gold GI0FSAXVY 19.8 cu. ft....
Model RB215LABP water acumulates in veggie bins & on the bottom of refrigerator and freeezes
The drain tube that runs down the back of the fridge into the tray that sits on top of the compressor is blocked, you need to clear this, you can either use compressed air and blow back up into the fridge of find a soft but stiff wire to carefully slide up the tube.
Mar 06, 2012 | Samsung Refrigerators
My freezer occassionally freezes over. Ice and frost consume the compartments. I have to remove all of the food content and hose out the freezer parts. What is the issue here and what needs to be...
I would guess that the doors are not sealing properly. They have gaskets (seals) that can get brittle or damaged. If these leak air, you will build up water on the fridge side and ice on the freezer side. Or is someone not closing the doors well?
Oct 13, 2017 | Samsung RB215LASH
Purchased in 2002 and is starting to freeze in the
Check the back of the fruit and vegi drawers. If theres a slot for an intake port try closeing it (if adjustable) Check thermostat setting for fridge and adjust to a lower setting.
Finally make sure door closes and seals closed, clean gasket with mixture of white vinegar and water (1 cup vinegar to 1 gallon warm water). If this fails internal thermostat may need replacing.
Dec 17, 2009 | Amana ARS2464B Side by Side Refrigerator
Refrigerator crisper drawers are freezing veggies
Shut the air flow into the crispers if you can. If not, turn the refrigerator temperature warmer by just a few degrees. The air into the fridge from the freezer is channeled into the crispers.
Jul 01, 2009 | GE PFS22SISSS Stainless Steel French Door...
Ref. Whirlpool model ED25DQ/ water in meat drawer
You seem to have conflicting information here.
If you turn the therostat DOWN it is setting it to defrost that will not help the food in the door to get cold it gets it warmer. The water is possibly from the fridge being in defrost mode and the tube that usually direcfts it to a tray beneath the fridge to waste tray that evaporates the water from the heater coil has somehow been directed back into the crisper draw.
tfry turning the fridge to colder not warmer. Hope i interpreted this correctly, language is a wonderful tool when facial expression and visuals are available otherwise its a handicap
Jun 21, 2009 | Frigidaire Refrigerator Light Switch -...
Kenmore elite fridge crisper drawer freezing stuff
Apr 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
66 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
