Question about Fuji FinePix F40fd Digital Camera
Zoom error showing on display screen of my daughters fuji finepix f40fd digital camera. Unable to press button to take photos and when I try to turn camera off the zoom lens goes in and out twice before turning off. Help - my daughter goes on holiday next week and needs her camera!
Posted by alisonhamilt on
david
  • 244 Answers
The lens Is trying to close properly but the focus mechanism has a problem, most likely jammed, so the lens cannot correctly close or work properly.
It will need to be opened up and reset.
Please email me. My email address is listed in my tips section on my profile.
Posted on Aug 28, 2009
I bought FUJI FINEPIX AX650 6 months ago.Now After taking pics when i press play button to view , it shows READ ERROR.another problem after taking a snap, the LCD display shows blank (color black) for few...
when having a problem with your digital camera. switch it of, remove the battery and charge the battery. When you replace the battery, the error should be gone. If not, you should contact the service centre closest to you.
Jan 22, 2014 | Fuji FinePix AX650 16MP, 5X Optical Zoom...
Fujifilm finepix f40fd
The lens needs to be dismantled and reset.
If your camera is under warranty then fuji will replace for free. If not then it may cost around £90 to have the lens unit replaced.
Cost of repair will depend on where you take it to get it repaired and will undoubtedly be more than the cost of a new camera.
However.....
It can be repaired for as little as £30 if you look hard enough ;-)
Nov 13, 2009 | Fuji FinePix F40fd Digital Camera
Hi my lens is stuck in the out position and zoom error is on the screen can you help finepix f40fd
Lens needs to be removed, carefully stripped and re-assembled. If the three small plastic guide luggs on the inside slide ring are broken sell for spares. Very hard to repair.
Dec 01, 2008 | Fuji FinePix F40fd Digital Camera
Zoom error
The lens got out of track. Try to have them back by forcing gently the lens in ou out with your fingers. If they are bent, force them straight. Hope it helps.
Nov 21, 2008 | Fuji FinePix A600 Digital Camera
Re- fuji finepix s5000 digital camera
when the camera is turned on the screen says zoom error and whem pressing the zoom button the camera makes a noise and the lens does not move
Oct 12, 2008 | Fuji FinePix S5000 Digital Camera
Fuji FinePix F40fd-Zoom error
Unfortunately this is one of the hardest cameras I have come across to repair. The plastic guide lugs inside the lens which keep it stable are so small that once they get damaged they are virtually impossible to repair and only a replacement part seems to rectify the problem. Source a donor camera on ebay for a cheaper option than sending to fuji. F45fd and F47fd use the same lens so these are an option for a donor if F40fd is not available.
Jun 07, 2008 | Fuji FinePix F40fd Digital Camera
Fuji FinePix S7000 Digital... Problem: Zoom Error
The manual describes all warnings the camera displays. Check the manual or go here for the manual online in pdf format.
http://www.fujifilmusa.com/JSP/fuji/epartners/bin/S7000Manual.pdf
Dec 13, 2007 | Fuji FinePix S7000 Digital Camera
Fuji FinePix F40fd aoto focus
Camera fault sounds like make sure the A/F sensor window is not obscured Fuji Tech Support will know more.
Jul 12, 2007 | Fuji FinePix F40fd Digital Camera
Fuji FinePix F40fd Digital Camera Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Rob Hill
Rob Hill
Are you a Fuji Camera Expert? Answer questions, earn points and help others
