Toshiba e-Studio 232 Black and White Copier Logo
Anonymous Posted on Aug 28, 2009
Keeps on coming up with install new toner
Replaced toner with genuine e studio 350 and compatible e studio 350 and replaced toner motor assy and still keeps saying install new toner
any suggestions
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 31, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
344
Points
It was a e studio 350 not a 232 that I was looking at , but that doesnt matter the problem is the same and it ended being the toner sensor in the dev unit, so I replaced it and now its working fine.
Stan Marciniak
Level 1:
  • Contributor 29 Answers
  • Posted on Aug 28, 2009
Stan Marciniak
Contributor
Level 1:
Answers
29
Questions
0
Helped
8735
Points
51
The toner detection sensor in the toner hopper is either fouled or defective. This is why that no matter what you've done thusfar, it's still saying it needs new toner. Not an easy repair. Recommend a certified Toshiba tech to do the work.
1helpful
I have a kyocera ecosys m2540dn printer and i get the screen message "replace toner"!
The error message "replace toner" indicates that the printer's toner cartridge needs to be replaced. However, since you mentioned that you already replaced it with a new one, there may be a few reasons why the error message is still appearing:
  1. The toner cartridge may be defective. Even though it is new, it may have a defect that is preventing it from being recognized by the printer. Try replacing it with a different toner cartridge.
  2. The toner cartridge may not be compatible with your printer. If you are using a non-genuine toner cartridge, it may not be compatible with your printer. Try using a genuine Kyocera toner cartridge.
  3. The toner sensor or other hardware may be malfunctioning. In some cases, the error message may be caused by a malfunctioning toner sensor or other hardware issue. In this case, you may need to contact a Kyocera service technician for further assistance.
I hope this helps!
"kyocera ecosys m6026cdn unknown toner"
If you're getting an "unknown toner" error when trying to use non-genuine cartridges, it's likely that the chips on those cartridges are not compatible with your printer. In some cases, you may be able to reset the printer to get it to work with the non-genuine cartridges, but it's not always successful. The best bet is to use genuine Kyocera cartridges to avoid any issues.
Hi. i have bizhub 350. my problem is the toner hopper is not spinning/rotating. hv already changed the developer,the toner replenishing box and the drum assy, whole unit. what seems to be my problem here....
Sir, the toner bottle motor assy. needs to be replaced. will take quite a bit of work to get to, recommended a service tech qualified on Biz hub 350. This series is well known for the toner bottle assy. fault as is the di3510 series prior to the Bizhub 200/300 series.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sc28-03 minolta di 650
Pull out the middle assy. you will see a section that has a grill over it inside there are two/three very thin wires. They carry a very HV during the copy process not with the section out. There is a clean device on them that goes from one end to the other, your code deals with the motor that drive the cleaning device. Remove the assy., two screws front rear whole assy. comes out remove the tiny gear bring the cleaning device to the rear re-install gear re install assy. if the code comes back burn out motor, can also get a tech to turn it off for ever, not really that important.
Copier wants me to install new black toner cartridge after I installed new one.
for e-studio 350 check if the developer tank unit auger broken or harden with moistered toner hope will lead u to the solution
2answers
Dear sir, my toshiba e studio machine some time showing "dispose used toner" . I thing that means tonner is finished. there have 4+1 toner which we need to replaces Idon,t know. Please help me
Dear,
your copier e-studio 350 some time showing '' dispose used toner'' It dont mean you install new toner... its mean you dispose used toner box.. Dear open the copier frant cover
and dispose used toner white box...
Thanks
Best Regards,
I would like to change the toner how to change it machine is toshiba e studio 45
You have to purchase genuine toner catridge from toshiba dealer . after purchasing the toner
1) Open the front toor
2) Toner catridge is there on above of the drum unit, there will be lock for toner catridge cover on the machine, it needs to be opened
3)Rotate the toner catridge in clock wise and pull the catridge ,it will come out
4)Insert the new catridge and rotate clockwise at a time it will get enhance with toner motor
5) close the toner cat cover, front door, TURN ON the machine it will get rotate for few seconds (adding toner) then it will becomes ready
Top Toshiba Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
