Question about Measuring Tools & Sensors
Code e37 on a electrical multi tester megger 1502 wat does it mean
Posted by Tony Joyce on
3 Related Answers
jalamb
Aashish Chaudhary
  • 105 Answers
SOURCE: Error code e37
check the web roller or its sensor,
in heater section thats it
Posted on Aug 30, 2009
Paul
  • 35 Answers
SOURCE: where do i get a manual for megger cm500
Go to this link to download the manual for your tester
http://www.biddlemegger.com/biddle-ug/CM500_UG.pdf
Posted on Jun 11, 2011
Vuk B
  • 717 Answers
SOURCE: i have fluke testers but no manual
www.fluke.com - you can find manuals there
Posted on Jan 02, 2012
What is Error code E78 in Megger MIT510/2 5 kV
Send unit to service centre, you cannot repair it, all boards in the unit can cause E78
Jan 28, 2016 | Megger MIT510/2 5 kV Insulation Resistance...
HOW TO RESET megger MIT510/2 MANUAL NSE?
nSE means "No Specific Error".
The recomendation is return your devise to workshop
Jun 12, 2014 | Megger MIT510/2 5 kV Insulation Resistance...
Megger MTI 1020/2 I got E79 in screen what dose it mean thank you
I checked the user manual and could not find an answer to your question. Try calling this service center:
Megger
4271 Bronze Way, Dallas,
Texas 75237-1019 USA
T +1 800 723 2861 (USA ONLY)
T +1 214 333 3201
F +1 214 331 7399
E [email protected]
Mar 15, 2011 | RTO Megger 10 Kv Insulation Resistance...
The fuse blew on the Motor Control. I replaced it and it blew again, then I unplugged the motor and replaced the fuse and it did not blow. Could that mean the motor is bad?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} It certainly sounds as though it is motor related. First check the carbon brushes if they are worn down replace them. Then the commutators on the armature (The little copper segments that the brushes rub on as the motor turns) if one of these have lifted or become dislodged you will need a new motor. It could also be wiring related so check all the wires and make sure they are sound and not shorting out on anything. As the fuse has blown twice check all the tracks on the module and timer to be sure they are still OK. If you have a Megger then do a resistance test to be sure there are no other short circuits in the system. Really any electrical testing should be done with a test meter such as a Megger, although for continuity testing a multi meter is fine. If you have never done any testing with a meter use this link to show you how
http://www.selfix-uk.co.uk/Megger.html
Mar 04, 2010 | Washing Machines
Blows breaker after 10 mins tech says dryer ok eletrcian says wiring and breaker ok
Did you dryer tech use a Megger or a High Voltage tester to check for leakage to earth or neutral on the machine ?
Normal Ohms meters are a waste of time in this situation
Oct 15, 2009 | Whirlpool LER4634J Electric Dryer
Measuring Tools & Sensors Logo
170 people viewed this question
Top Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
