Question about LG Dishwashers
I have a LG Dishwasher LD 14AW3 it fills and runs for about 30 min. It then appears that when it tries to rinse it cannot get water and flashes "1E". I disconnected the unit and when I moved it out of its position water was leaking from the bottom of the unit. after cleaning out the inside filter & the hard water filter I re-connected and found it worked. I ran a dishwasher cleaner through it at high temp. After a few loads the problem has come back. It is now located in MY garage waiting for me to explore and find the problem. Does anyone have some ideas. I should be able to do the repair being a power tool service agent but a dishwasher is a little different. Thank You, Darren Kennedy
Anonymous
Found a leaking component that was causing the foam float located and attached to the inlet valve to shut down the water inlet and the water inlet Solenoid was also sticking. I found out this simply by tapping it while it was trying to get water for rinsing.
Posted on Aug 28, 2009
Washer from flashing 1E & leaking
LG Washing Machine Displaying Fault Code IE or 1E WM2016CW WATER INLET ERROR // Water not entering washing machine correctly
The manufacturer has assigned this error or fault code to indicate that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Aug 02, 2015 | LG WM2016CW Front Load Washer
Ld 14aw3
Most dishes in any dishwasher are still wet when cycle is finished. The heat built up in the dishes during the washing cycle is what causes the water to evaporate when the machine stops.
If you want to accelerate the evaporation, simply open the door very slightly so that as the hot air escapes it causes the dishes to dry quicker.
Aug 04, 2014 | LG Dishwashers
LG dishwasher LD-14AW2 starts up & tries to drain for about 2 mins & then the alarm comes on. The wash, rinse & dry lights are flashing. The hose is raised and not blocked because we can blow...
Hi Jeff - am not too savvy with LG - am a Electrolux/Miele serviceman is it possible to gain access to the drain pump from inside the unit? I think it does sound like there is a restriction somewhere perhaps the pumps not running freely.
To check you pour water inside , take the drain hose , operate machine to see how good the flow of the drain is, rule of thumb if you cover the outlet no flow then the problem.
hope this is a start..
Jun 17, 2011 | LG 24 in. LD-12BW5 Free-standing...
Getting error code 0E on LD-14AW3 model dishwasher after 2 minutes. Checked drain hose and water seems to be coming out but won'y go any further in cycle Also makes a loud humming noise when running.
To little info, but looks like pipe is much to low. Not getting the opportunity to fill up properly.Raise it higher.(Im asuming that you can hear the drain pump run and water is being pumped out as wall.
Aug 09, 2010 | Dishwashers
Dishwasher won't run much of the cycle.
LG dishwasher 2009 lds4821bb, water does not heat up anymore. thanks
Jan 26, 2010 | LG Dishwashers
Bottom spray arm on our LG dishwasher LD-14AW3 won't spin.
sounds like no water going into the machine. you may need a water inlet valve.
Nov 07, 2009 | LG Dishwashers
I have a lg dishwasher ld-14aw1over flow
On an LG LD-14AW1, three is a float sensor on the left hand side of the dishwasher, behing the water outlet port.
It is the sensor that tells the dishwasher to stop filling just before the wash or rinse cycle begins.
A service call is needed or post back here is you want help replacing it.
Apr 09, 2009 | LG 24 in. LD-12BW5 Free-standing...
LG DISHWASHER LD-12AW2
ae unknown code,,,but ie that means uinit is taking to long to fill,,your inlet screens are clogged or the water pressure is to low...kinked hose...onthejob
Jan 19, 2009 | LG LDF6810ST Stainless Steel Built-in...
LG DISHWASHER LD-1204W1
Try turning your tap off a bit till the noise stops but the dishwasher still fills, it can just be due to a bit too much pressure on your water valve.
hpe this helps
Apr 01, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Dishwashers Logo
190 people viewed this question
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Bill Johnson
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
