GE Profile Advantium 30" Built-In Single Electric Wall Oven - White-on-White Logo
Posted on Aug 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ge profile wall oven - f7 but I fix with eraser trick - now the clock can't be reset and the 4 does not always work on the keypad
Anonymous
Level 3:
  • Master 725 Answers
  • Posted on Sep 21, 2009
Anonymous
Master
Level 3:
Answers
725
Questions
Helped
406790
Points
1785
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Ge profile performance double oven. getting an F7
F7 is a stuck keypad/button.
Push all buttons at random several times each. This will sometimes un-stick a stuck button.
If that does not work the keypad control will have to be replaced.
Jan 16, 2010 • GE Ovens
F7 error built-in oven
F7 is a stuck keypad error. Sometimes you can push every pad at random several times each to unstick the keypad.
If that fails the ERC(clock) will have to be replaced.
F7 error code
Hi
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
check out more detail here
http://www.fixya.com/howto/h155060-dreaded_f7_error
hope this helps
3helpful
3answers
F7 code keeps flashing on upper oven, nothing on keypad works
A function pad is probably stuck.
Push all buttons several times each. Often this will clear a stuck pad.
If that does not work replace the clock.
F7 code keeps flashing, nothing on keypad works. I can use second oven with the dial and also my counter range top but the F7 won't go away, nor the beeping. I can push the start button or stop and F7 will...
After much searching, I have found that you have a faulty keypad.
The recommended solution is to unplug the oven, or shut it down at the fuse box, and then remove the faceplate where you can then remove the keypad, and clean the connectors with an eraser, as well as the ribbon that connectes the keypad with the oven.
I hope this helps out.
F7 Failure Code
Hi markw421,
No you do not need to pull the entire oven. If I knew the model number I could give you specific instructions. You can go to www.partselect.com and put in your model number and you will find diagrams that will help you open up the beast.
Regards,
Powerman
1helpful
JKP18 WALL OVEN IS A PIECE OF JUNK
http://www.fixya.com/howto/h155060-dreaded_f7_error    Go to the above link.  I will fix it.
1helpful
4answers
GE Profile JGB97 Self Cleaning Oven Controls won't work
You have a problem that may be solved with my solution to the Dreaded F7 Problem. Even though you don't have a F7 error on the display the symptoms are all the same. You can find my fix at the following links.
I have shared this with more than 1550 folks and most report success. This problem often develops after a self clean cycle.
I hope it works for you too. Please let me know at the following:
[email protected]
Good Luck,
Charlie Popeck,P.E.
Consulting Engineer
Feb 06, 2008 • Ovens
Ge profile double wall convection oven
My solution for the F7 problem may work for you. It won't cost you anything to try it. It is simple and free. You can find it at the following link:
Please let me know if this works for you. You can email me at:
[email protected]
Good Luck,
Powerman
4answers
F7 code
GE, F7 is a stuck or shorted keypad. You can unplug the keypad ribbon cable from the main board and try to clean the ends with an eraser. See if the code comes back. Catriver...post back.
Top GE Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a GE Oven Expert? Answer questions, earn points and help others
