I put water in my ice maker and got some ice
Refrigerators equipped with ice makers have a tube that runs out the back of the fridge. This tube needs to be hooked to a pressurized water source. This will be automatically regulated by the ice maker then. You are not supposed to pour water in to the ice maker manually. I know it may be difficult to find a close water supply by your fridge, but it really needs to be hooked up that way to work correctly.
If you have any more questions, please get back to me.
Please give positive ratings, they are important..
SOURCE: Ice maker not working
I replaced both silinoids and the ice maker. The ice maker will freeze water but not fill with water. My refridgeratoor is an a Amana
SOURCE: Water not flowing into ice maker
yes there is a problem with the water valve or the fill tube that puts water into the ice maker is frozen not letting water into the ice maker
SOURCE: Ice maker leaks water into Ice bend. When it cycles I can watch it drip water from the ice maker.
not familuar with the brand but sounds like one of 2 issues
if it is overfilling making ice cubes larger than normal, adjust the ice maker fill time if it is possible
icemaker fills and cuts off but water valve seeps water after the fill causing the water overfill
one of the 2
I have a whilpool Model # ED5FHXC001A side by side Energy Saver refridgerator. It was purchased late in 2006. It's not making and dropping ice. Any ideas what the problem may be? Thanks
If your ice maker has stopped producing ice completely, check these, in this order:
In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
your solution was very good,i am getting close. i have a old line running to back with a cutoff valve maybe i will check the line, Thank you!
