Question about Technics SL-1200MK2 Turntable
One of my technics' 1200 turntable's tone gets too high
One of my technics' 1200 turntable's tone get really high (alvin & the chipmunks sound) as I increase the pitch control... My other turntable's speed increases and keeps the pitch in tact..but the other one's tones is much from the other when they are set to a higher pitch. I tried adjusting the pitch knob inside the turntable but didnt seem to work. HELP!!!!
Posted by cummingseric on
  • cummingseric Aug 28, 2009
    Thanks! Is the pitch the gain the blue dial inside the turntable? )The one where you take the platter off thenthe plastic covering to get to it?) If so I tried that already. So i guess maybe a new pitch control?
    Ok, got the rubber bottom off, looking at the pitch control slider and I can't seem to find anything that looks like a pitch gain.
dwilliams376
    New Friend:
Before you try doing all this work to it you should just check your software. Im guessing that your using scratch live. If you are then chances are that your pitch lock might not be on, on whichever deck you have the problems with. try that first before u waist money trying to fix it.
Posted on Mar 01, 2013
Fla-Hosting.net
    Scholar:
  • 77 Answers
This appears to be a slight difference with the manufacturing lots that your turntable came from Technics (Panasonic). The pitch control is to set the speed for the varying AC Frequencies (Hz) available in the world. Set the speed for the Hz your local area electricity provider uses 50HZ for 50Hz and 60Hz for 60Hz. Once the "Pitch control" is set for the local Hz don't bother playing with it unless you want the interesting sounds from the turntable. As your other turntable's speed is increasing, the pitch is increasing as well but your ears haven't noticed the different tones since they are lower in Hz. I.E. the male Bass or Alto voice is lower in tone than a female Soprano voice, and when you speed up the two differing voices the one noticeable higher is the Soprano.
Posted on Sep 18, 2009
Anonymous
  • 515 Answers
You can try adjusting the pitch's gain, which is located on the pitch control circuit board. Only problem is that you'll have to take apart your turntable in order to get to that section (its on the bottom).
If that does not work, your pitch might be bad, or one of the main circuit drive IC's might be bad.
Hope this helps some.
- OPTiC
Master Tech, 1200s.com
Technics Parts : DJ Repair
Posted on Aug 28, 2009
  • Anonymous Aug 28, 2009
    There is another gain control on the pitch control circuit board. But
    the only way to access is to remove the rubber base, from the bottom of
    your turntable. You'll need to do this to replace the pitch control.
    - OPTiC
    If you remove the pitch control assembly - 2 screws which hold it down, and drop it out, you'll see the potentiometer for the pitch gain. Looks just like the one on the main PC board.
    - OPTiC
Do you have alvin and the chipmunks chipwrecked?
You seem to be far too fixated on animated chipmunks, try using a peer to peer downloading service to search and acquire your desired movie: such as bit torrent, and then take your attitude elsewhere.
Jun 25, 2014 | Majesco Alvin and the Chipmunks 3:...
Just got this and set it up. Sound is high pitched, sounds like alvin and the chipmunks are singing.
It sounds like it's running too fast! If it is a belt drive model you must have got it set up wrong.
Sep 16, 2011 | Crosley Cr6005a Turntable
I have a technics 1200 mk5 and when i put a record on the volume is low no matter how high i pt it up in the mixer. When i use it with serato it works fine. What can be the problem?
Years ago, Radio Shack sold a turntable with the same problem. The fix was to purchase a pre-amp to go between the turntable and the tuner/amp. I think this had something to do with a magnetic vs. ceramic cartridge?
Dec 14, 2010 | Technics SL-1200 Turntable
Distorted sound on Technics SL-1200/1210
You could be getting acoustic feedback from the speakers to the TT's. Lower the volume or somehow isolate them from room sounds and vibrations.
Jul 05, 2010 | Technics SL-1200 Turntable
Pitch Control Problems
More than likely the pitch needs to be calibrated. Although not very hard, I would suggest getting this done by a professional, as it does require opening up your turntable.
Here are instructions - TECHNICS PITCH CALIBRATION
If you cannot perform this, then find yourself a good technician who knows what they are doing.
If this does not work, more than likely either your pitch control, the pitch gain, or one of the IC's need to be replaced - at this stage, only a qualified service tech can help you.
- OPTiC
Master Tech
Digital Analog Therapy
Technics Repair : Technics Turntable Parts
Aug 28, 2009 | Technics SL-1200 Turntable
Buzzing from one Technics MK5 1200
More than likely your RCA's need to be replaced. There is no need to open it up, as the ground wire rarely every comes loose. It's held down by a screw & soldered to the circuit board. Unless you pulled on the ground wire.
There are only 3 issues which can cause this:
1) Technics Tonearm - Check the 4 prongs inside the tonearm. Make sure they are all clean (shiny gold), and all protruding the same distance. There are springs behind these prongs, and often times they do come loose over time or overtightening.
2) Technics RCA Cables - This is more than likely the culprit.
3) Cartridge/Headshell - swap out with your good unit. If it works, then your good. Just replace cartridge
With the exception of #3, the other 2 will require assistance from a qualified service technician, otherwise you could cause more damage to your turntables.
- OPTiC
Technics Parts : Technics Repairs
Jun 16, 2009 | Technics SL-1210MK5 Turntable
Distorted sound (voices sound like "Alvin and the Chipmunks"
Have you tried another set of speakers? If not I would do so cause your speakers might have just gone bad!
Mar 22, 2009 | HP Pavilion a1730n PC Desktop
Technics SL-L3 turntable no sound until warm up
either the cartridge is bad in the phonograph tone arm.  Or the pre-amp in the stereo is bad...remember that the turntable is the only accessory that uses the pre-amp input on the stereo.  I'm betting the pre-amp is bad.
Mar 10, 2009 | Technics SL-1210 Turntable
Technics SL-1200MK2 Turntable Logo
1,199 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
