All the burners are working fine. Only the oven is burning very,very high. We have adjusted according to directionsAll the burners are working fine. Only the oven is burning very,very high. We have adjusted according to directions
You can't post conmments that contain an email address.
If you've converted your Maytag oven to LP (propane) and you're experiencing issues with the oven and broiler not receiving propane and not producing a flame, there could be a few possible causes:
Gas supply: Ensure that the propane supply to the oven is turned on and the gas valve is fully open. Check that the propane tank is properly connected and that there is sufficient propane in the tank. If the tank is low or empty, it may need to be refilled.
Incorrect conversion: Double-check that the conversion from natural gas to LP was done correctly. Verify that the conversion orifices have been installed in the correct locations and that the air adjustment shutters or plates have been adjusted according to the manufacturer's instructions. Improper conversion can result in inadequate gas flow and a lack of flame.
Clogged orifices: It's possible that the orifices, which control the flow of gas, have become clogged with debris or residue during the conversion process. Clean the orifices using a small brush or a compressed air canister specifically designed for cleaning gas orifices.
Gas pressure: LP gas operates at a higher pressure than natural gas. Ensure that the pressure regulator on the oven has been adjusted or replaced to accommodate LP gas. If the regulator is not properly set for LP gas, it may not deliver the correct pressure for proper combustion.
Faulty ignition system: If the oven and broiler are glowing but not producing a flame, there may be an issue with the ignition system. Check the igniter for any signs of damage or wear. A faulty igniter may not generate enough heat to ignite the propane. Consider replacing the igniter if necessary.
If you've checked these potential issues and the problem persists, it may be best to contact a qualified appliance technician or the manufacturer's customer support for further assistance. They can provide specific troubleshooting steps or arrange for a service visit to diagnose and resolve the issue with your Maytag oven.
You need a Gas tech/plumber there urgently!!!! If the gas jets in your oven had not been changed to accomodate LP gas then the orifice on your existing jets are still to large in diameter. In other words your using Natural Gas jets ( lower pressure jets) for Lp which has a much higher pressure than Nat. gas, this can be extremely dangerous, & could cause major problems. Again I strongly suggest you contact a Gas tech/Plumber & do not use your oven until it has beeen checked by a professional.Good luck
HI,
If your able to adjust the orifice hood to the oven, then turn it counterclockwise unit the burner is full and minimal yellow flickering is present. If you go too much, this can be deadly can cause carbon monoxide to admit into the kitchen during use. I have found adjusting while the burner is on is the easiest way to make sure it is correct, use caution....
I hope this helps
you have a bad oven sensor /faulty connection or bad control board.look for probe coming thru inside rear wall.should read 11k ohms cold.go bad a lot part number Hope this helps ,please rate my response :)
the oven flame seems to be to low, that flame most be at least 2 inches long. not counting the sides of flame from one side of the burner to the other, but from where the flame begins at the metal of the burner.
Hi! melisrus If you are using LP, even if you change the regulator settings from Natural Gas to LP Gas, the orifices all need to be changed. The Orifices should have come with the new unit, if not contact Hotpoint. www.hotpoint.com Make sure you order the instruruction manual and this is an Oven with Range Top, you will need orifices for all the burners on the range top. InMrFixIt
YOUR OVEN GLOW IG NITER IS SUPPOSE TO STAY ON THAT'SNORMAL. WHAT YOU NEED TO DO IS CHANGE THE ORIFICES ON YOUR OVEN VALVE BECAUSE YOUR USING LP GAS MOST OVENS COME NEW SET UP FOR NATURAL GAS ALL OF THEM EVEN YOUR COOKTOP
ALSO
