Televison & Video Logo
Question about RCA Televison & Video
My RCA reciever quit working power light light so up but no other livhts. Then when I push the power button light goes out on it an then u can push line in , DVD , etc an the little orange light comes on but the blue lights on the front will not light up either. Anyone I need help
Posted by Eddienlisa Pruett on
  • Patrik Parker Jul 14, 2019
    Hi Eddienlisa Pruett, I want to help you with your question, but I need more information from you. Please Call customer Support Call 1 8O5*465*751O Toll Free 24x7
5 Related Answers
Anonymous
  • 47 Answers
SOURCE: SanDisk Sansa E250- Only the blue light comes on? HELP????????????
Try this: Switch your Sansa e250 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the e250 LCD screen displays "Welcome to Recovery Mode" (if the LCD remains black, keep pressing long enough -- about 10 seconds -- then proceed to the next step) 5. Connect your e250 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa e250 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the e250 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa e250 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... or use this Sansa Firmware Updater link: http://www.sandisk.com/Retail/Default.aspx?CatID=1376 Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player (or find the most updated firmware) and format it as well, thereby clearing all possible file/system corruptions that may have occurred. Step 3: When the process is complete, unplug your e250 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your e250 and 90-99% of the time, it would boot up successfully. I hope this helps.
Posted on Apr 24, 2007
Anonymous
  • 5138 Answers
SOURCE: 52 inch rca big screen tv will not come on
ck capacitor cp150 if it is bad replace 2 other caps in same circuit 2200uf 16v -220uf35v cp111 cp114?
Posted on Dec 09, 2008
Jonah Oneal
  • 14092 Answers
SOURCE: Cruise Control quit working on 99 Olds Alero
replace switch.
Posted on Mar 17, 2009
jepito
Kevin Groce
  • 216 Answers
SOURCE: I have a Dell Inspiron 1525 that won't start.
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
Posted on Dec 27, 2009
Anonymous
  • 14 Answers
SOURCE: orange light on lamp icon on Optoma EP732H Projector
This same thing happened to me, I removed the bulb and put it back in, it reset something and I was able to use the projector again.
Posted on Jan 16, 2010
How can I program my RCA universal remote to my element tv , what button to press for the light to blink and the code to put so it can work on my tv
RCA does not have for a code Element TV. With that being said there is a work around:
Turn on your TV.Then push the code search button until the LED still ,when the LED keeps on let go the button now push and release the TV button then push and release the power button until the TV goes off, when the TV turn off stop to push the off button now push the set button the code are already set on the remote control( you might have to push the off button almost 100 times or more until you get the right code for your TV. Best of Luck
2answers
Rca blu ray home theater rtb10220 why did my remote quit working?
Probly moisture damage. Take it apart and check board for damage. U can also smell the board for a burnt smell.
2answers
My rca sound bar is not working
When the power goes out, my sound bar will not work, the blinking lights on the top scroll across and I push all buttons and still no connection.
Have an RCA D52W20 When I push the power button the green light goes on and off about 3 or 4 time and quits never coming on at all.
That could be the CP150 CP120 and CP114 capacitors. You can get the RCA repair kiy by that same name from www.tvrepairworld.com which also contains the repair instruction CD.
Won't turn on! Green light one greenlight off!
Replace the flyback Its the 259296 flyback available from www.tvrepairworld.com the kit contains the flyback, associated capacitors and ful instructions on CD
2answers
Rca rt2870 wont turn on
a fuse may need to be replaced
Reciever wont stay powered on
I fear that there's no easy fix. Sounds like the power supply or the board which controls it is bad. If you're not an electronics repair person, it'll need to go to a repair shop.
1helpful
2answers
Rca412c
THIS WORK!!!!! to make this simpler
1. Hold on TV and POWER simultaneously (light comes on), let go
2. Press POWER then CH+ back and forth (light comes on), when TV turns off
3. press STOP, code is saved!
Top RCA Televison & Video Experts
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
