Crafts & Hobbies Logo
Question about Crafts & Hobbies
Why is the green light on my Lionel controller blinking?
I inherited a Lionel Union Pacific Express Set. Put it together and not working except the train moved for a second. But the controller light that I think should be a solid green (and is for a sec here and there) is blinking. Does this indicate a problem must be with the controller? Thank you
Posted by Dianne Werdon on
  • Patrik Parker Jul 14, 2019
    Hi Dianne Werdon, I want to help you with your question, but I need more information from you. Please Call customer Support Call 1 8O5*465*751O Toll Free 24x7
5 Related Answers
Anonymous
  • 2418 Answers
SOURCE: The Cw 80 watt transformer
If you have a volt meter you can check the rails for power, Check the transformer wiring to the first rail connection and then along the rails for loss loose connection(s). If you have power to the rails it is an issue with the Engine, Check any brush or rail riders (connections) for a bent or broken tab. If for a temp fix in a broken connection tab or brush you can use Tin foil. Hope this helps.
Posted on Dec 25, 2010
Anonymous
SOURCE: New Lionel Polar Express train set-up issue. The
My son just got this train and we are having the same problem. Taking the last car off solved the problem for us. I think it has something to do with accessories and the transformer voltage output (See page 14 and 15 of the instructions).
I have still not determined why it won't run with the final car but am assuming it has something to do with the lights on the cars pulling too many amps and not enough left to run the train. I will let you know if I find a solution. If anyone else knows how to solve the issue, any assistance would be greatly appreciated.
Thanks
Anonymous
SOURCE: i just set up or thomas lionel train. and the
If you can pull the roof off of Thomas there is an on/off switch within the cab. I don't know if you tried that at all..just a thought..
Posted on Apr 23, 2013
Bill Boyd
  • 53816 Answers
SOURCE: How can you tell if the remote control is working for Lionel Holiday Tradition Express Train?
turn your cell phone on to camera
point the remote at the lense and press the button
if it is transmitting you will see a white dot appear on the screen of the camera
Posted on Dec 12, 2017
Testimonial: "Has to think a moment before I thought of Camera Lenz! LOL I didn't see the dot. Thank you! Now to find someone to repair it!"
mccluskey1
NOEL
  • 8603 Answers
SOURCE: How to repair a remote control for a lionel Holiday Teadition Express Train.
hi Pkragan.
all i can find is the manual so not sure if this will be of any help to you.
Lionel Holiday Tradition Express Owner Manual Troubleshooting
Testimonial: "Thank you for the reply. I have the manual. It really is a skimpy manual that repeats the obvious to many of us. Have a great day. Phil"
The wheels on Lionel The Polar Express LionChief 2-8-4 don't move, or are stuck.
Please make sure that the wireless controlloer power switch is set to "on." Please also give the train a new command. If it does not start to run, either your engine or remote need repair and you would need to reach out to Lionel by calling 1 (586) 949-4100.
Thank you.
The 3rd passenger car has short in it and causes green light on cw80 to blink. Checked wires and contacts on trucks can't find problem.
Lionel uses insulated wheels on there power pickup trucks , one side will have insulation bands and one will not , insulated bands need to be all same side on same truck , lead end is different than tail end this is how it picks up power from tracks , sometimes trucks axles get popped out in playing and maybe don't get popped back in the same way , also its possible for insulating bands to get holes in them from use , a dot or two of black latex paint fixes these up (don't paint entire wheel)
Led blinks when train put on track
I am assuming you are using the Lionel CW80 power source. If so, the blinking light might indicate a partial short or a problem with the motor. The reason I believe that is that the CW80 has an internal fuse, which will blow for near shorts/shorts. A stalled motor i.e stuck drive gear, can cause excessive power drain although not enough to blow the internal fuse and also cause the engine not to move. Also, If the engine has the neoprene belt on one of the drive wheels it might have come off and is jamming the running gear or wheel. I believe the Polar Express only has one neoprene belt.
Blinking green light
Check to make certain that the batteries in the remote are good. Make sure that when using the remote, you orient the antenna in an upright position and are within 6 to 8 feet of the locomotive.
If the train has been running successfully and the problem has only just started, clean your wheels and the pick up roller on the locomotive removing any fluff etc. then clean the track. If the loco is still not working contact the Lionel Service Department on
586 949 4100 or use their website contact service. Contact Lionel Trains
Put smoke fluid in the wrong place on Lionel polar express train, got all the controls wet on main engine
Remove the shell. Soak up as much as you can. Leave out to dry or use a hair dryer on low until controls are dry.
Holiday Tradition Express, engine tender not working. Contacted Lionel Trains, they have no replacement parts or service available.
Best bet is to search the internet for Lionel replacement parts. Try to include as much information in your search.
5helpful
2answers
Lionel Polar Express Berkshire Locomotive will only go in reverse
No doubt the transistor in the motor controller inside the engine is shorted TIP31C Q6 If you have the skills you can repair the unit. Parts are cheap, like 50 cents. Expense is shipping. Have repaired at least one that had the probblem you describe
good luck
Top Crafts & Hobbies Experts
ADMIN Andrew
ADMIN Andrew
Tom Chichester
Carolyn Rogers
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
