Televison & Video Logo
Question about RCA Televison & Video
I have a portable RCA portable DVD player that works fine then stop. Same place on dvd that is find in other players
The DVD i is new.
  • Patrik Parker Jul 14, 2019
    Hi Anonymous, I want to help you with your question, but I need more information from you. Please Call customer Support Call 1 8O5*465*751O Toll Free 24x7
5 Related Answers
Anonymous
  • 513 Answers
SOURCE: reading but DVD is not spinning in portable dvd player
Some suggestions assuming you know you're using good discs, and have this problem with more then 1 disc. In anything that requires you to open the player and play around in it, I also assume you're not too akward with electronics, and out of warranty: spindle motor problems - you could either fix that by changing the motor, or occasionaly by dropping a little bit of 3 in 1 oil on the shaft. Just dont start it as a hobby if you can still go complain at the store... Good luck
Posted on Jan 30, 2006
Anonymous
SOURCE: Need new car adapter for RCA portable DVD player DRC630N
mine broke when it was new. i opened the cig lighter end and found broken wire. soldered it on and taped up the missing chunk of plastic. worked ever since.
Posted on Mar 29, 2008
petraman7
Scott Frye
  • 1175 Answers
SOURCE: my portable dvd player shows no disc when i put my dvd in player
Hi....
Very lightly clean the laser lens ( looks like a very small eyepiece)
with 91% or better alcohol on a swab. Then very lightly dry it off.
Also..have you tried another DVD or CD in it?
Check for dust or debris in where the laser pickup is
Posted on Feb 25, 2009
Anonymous
  • 15 Answers
SOURCE: rca portable dvd player model drc6318e doesnt not
first you must check if your portable loads cd or mp3. If it loads cd or mp3 the defect is lens and this should be replace by an expert. If both cd,mp3 and dvd didn't load you check first the ribbon wire for signs of disconnection and foldings and then replace it. If still your portable didn't work the most probable defect is MPEG board.To distinguish if MPEG or lens defect in lens shows malfunction such as not reading dvd but reading mp3 or cd, unwanted stop of play even with a good dvd.
Posted on Jul 11, 2009
Anonymous
  • 17 Answers
SOURCE: My sony portable dvd player stopped working. The
If the DVD is connected to the TV properly using the yellow, white & red AV cable and the TV is switched to AV and there is still no picture, plug the yellow lead from the back of the DVD player into the green socket. If you see a black and white picture now the DVD output is on Progressive Scan mode. See user manual to turn off Progressive Scan mode.
Posted on Aug 31, 2009
I need warranty for portable dvd player from walmar
As far as I can tell this product hasn't been sold in years. If you bought it new and recently ask Walmart for warranty info. It would have had a 90 day or 1 year warranty when new.
3helpful
4helpful
Rca portable dvd player model drc6318e doesnt not load dvd. says no disc. how do i fix that?
Portable dvd player
Polaroids are well known for this issue you can try to replace video cable if that doesnt work if still under warranty send it in if not you will need to make a video rca repair
c.
Portable dvd player problems help!
It appears that the connectivity or processing for display is the culprit. Please refer to our experts to solve the problem.
I have this RCA portable dvd player, that you put in the car and it was working fine last month, but when I turned it on today, its not working. I do not know how to fix it.
Does your DVD player have a reset button on the back or on the inside of where you put your DVDs in? See if it resetting it helps.
2answers
Craig portable dvd player
I have this same DVD player and had the same problem. I have recently discovered that when we open the flip top, one of the "joints" that keeps the flip top attached to the player kind of pops out? We had to snap it back into place after opening the DVD player. Our light still does not come on but the player does work. Just a suggestion!
RCA Portable DVD palyer
only thing you really can do is open it and check the fuses.
Top RCA Televison & Video Experts
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
