Televison & Video Logo
RAYMOND KIDDER Posted on Jul 14, 2019
I HAVE A SONY LN46A WHEN I TURN IT OFF THEN ON IT TAKES ABOUT 30 MINUTES FOR THE TV TO BE ABLE TO BE WATCHED IT SQUEELS COLOR LINES KEEPS RESETING GOES ABSTRACK THEN CLEARS UP AND WORKS FINE TILL I MAKE A MISTAKE AND TURN IT OFF AND GO THROUGH IT ALL AGAIN PLEASE HELP ANYONE.
  • Patrik Parker Jul 14, 2019
    Hi RAYMOND KIDDER, I want to help you with your question, but I need more information from you. Please Call customer Support Call 1 8O5*465*751O Toll Free 24x7
5 Related Answers
Anonymous
  • 217 Answers
  • Posted on Aug 03, 2008
SOURCE: vertical colored lines no picture.
if the tv is less than a year old , call 1-800-SAMSUNG for warranty repair, the lcd panel is bad
Anonymous
  • 1139 Answers
  • Posted on Dec 16, 2008
SOURCE: samsung plasma ppm42s3 , picture wobbling,sometimes screen goes blank
Hello arunaik_6,
This looks as if a component has become thermally sensitive. The best way to find this is to use component cooling spray. It looks as if the problem is localized to the tuner section. Take the back off of the TV and turn the TV on, wait until the problem occurs and lightly spray the tuner section with the component cooling spray watch for any reaction, then if this does not work spray the Microprocessor and the LVDS section and watch for a reaction. The set should go back to normal when it does that section is the problem, try to localize the problem to one component. Then replace that component.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
vic richards
  • 75 Answers
  • Posted on Mar 12, 2009
SOURCE: TV only shows line across middle of screen.Still have audio.
Sounds like you have bad solder joints on the vertical ic which should be numbered IC501 on the board.also there are capastors that coud be going bad but i would look for bad solder joints on ic frist.
The capastors numbers on board are C502 / C516 also need to check R 483 which is a resistor.
resolder the ic if you know how to solder. That is a comon problem a lot of tvs out there have. The only thing is the tv has high voltage on it even if it is unpluged from the wall. Some of the capastors hold there voltage for a long time. Be sure and unplug tv before you try anything if you are going to do it yourself and stay away from the capastor in the AC line should be marked 200 V or moor.
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Dec 28, 2009
SOURCE: HELLO. I GOT A LCD TV LTV 32W3. I TURN ON AND 30
I just fixed my today, you need to replace the LCD controller board, there are two versions (V320B1-C, 35D003848) you need to open up the tv and remove the shield cover to get to the LCD controller board, this is a common problem with this model. Look here parts (make sure to get the part number of the LCD panel sticker to match wit the LCD controller): http://www.shopjimmy.com/catalogsearch/result/index/?q=LTV-32W3HD&stock=all
You cam see the one I fixed here: http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Notes: be real careful when you remove the back cover, the side switch assembly is attached to the back panel, so do not pull it off too far, or you will damage the switch assembly!
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Jan 04, 2010
SOURCE: Good picture for 30 minutes then colors change!
Bad LCD controller, see sample here (note, I removed the cover off the board so you can see it): http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Parts: http://www.shopjimmy.com/catalogsearch/result/index/?q=ltv-32w3hd&stock=all
Be real careful when you remove the back cover, the side switch assembly is attached to the back cover, so do not yank it too hard!
2answers
Sony KDL-43W800C 3D LED TV colored vertical lines on the screen.
dear there is a problem in T Con board so please replace the T Con board after fixing it set will become ok
thanks
m Nasir
TX-52F480S lines
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
22helpful
5answers
Different color vertical lines on screen Sony KDF-E55A20
Go to the last page of troubleshooting in the manual and perform the system reset procedure. Basically hold the Wega "arrow up" as you manually switch the TV off. It will automatically switch back on and reset. I had only vertical colored lines on the screen, with audio but no response to any remote control functions. The rest worked perfectly.
1helpful
4helpful
3answers
Vertical color lines
I had the same thing happen to me this morning. I turned on the TV and it had colored vertical lines through the whole screen. I called Sony and they had me unplug the TV for about 15 minutes. This solved the problem. They said the boards just needed to be reset. It fixed the problem and I am happy with my Sony once again.
Green screen with almost horizontal zigzag lines
Is good that you hit it and it reacts,very likely you have loose conections in different places but for the distorted picture you need to check the horizontal driver transformer and flyback after that is corrected you need to check the complete chassis for loose conections.Take your time.Good luck.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
