Question about Asko Dishwashers
Is there a reset code for Asko Asea Dishwasher?
Posted by Milford Patsel on
2 Related Answers
John Bloomfield
  • 534 Answers
SOURCE: I need a users manual for the Asko Asea 1403
Free manual available at :- http://www.asko.com.au/support/manuals/
go to above then search for 1403.
Posted on Jul 14, 2009
jyackle5
Jyackle5
  • 8197 Answers
SOURCE: manual for Asko ASEA 1400 dishwasher
You can get the manual on the link below. It is uper right corner next to the man under the pdf. You will have to click on the stars to download.
http://safemanuals.com/user-guide-instructions-owner-manual/ASKO/1400-_E
Good Luck and please rate 4 thumbs up for the freee answer
Posted on Apr 24, 2010
Asea 1302 dishwasher blows fufe during rinse cycle
Hi Gordon
I would check the fuse closely.
Did it blow with splatter
or was it like a melted wire.
This is the difference between momentary overload
or dead short.
Replace the fuse with a slightly higher amp rating (say 5) to see if a dead short is happening.
Sometimes motors get loaded momentarily and draw slightly more than the fuse rating.
If it continues then the motor is drawing too much.
Eg. water in the windings or windings insulation breakdown.
Contact an electrician to do a current load with an AC Ammeter.
Or take it to a service agent.
Good Luck
Mar 01, 2016 | Asko Dishwashers
Asko 3122 wont drain
I think I have replied to this already. Filters or drains might be clogging up. Clean dishwasher using Finish dishwasher cleaning kit.
Nov 27, 2012 | Asko D3122XLSS Stainless Steel Dishwasher
Manual for Asko ASEA 1400 dishwasher
Apr 24, 2010 | Dishwashers
All the lights are flashing on Asko 1805 dishwasher
Hi, You need to absorb the water in the overflow basen of the Asko dishwasher's and then push and hold a button to reset the error code...flashing LED's or turn the power off momentarily. You need to remove the lower kick plate and get to the basin with a wet-dry vacuum or sponge etc. Good luck. Let me know if I can assist you further. Thanks for visiting fixya and if you found this solution helpful please rate it accordingly. Macmarkus :)
Apr 08, 2010 | Asko 24 in. 1805 Built-in Dishwasher
No water to dishwasher and plumbing is fine
check the flood control switch and inlet valve..be sure the float is on under the bottom rack
Aug 17, 2009 | GE Nautilus 24" Built-in Dishwasher
Asko 1503 error code
Hi, Sounds like a bad door switch. Here is a site that may help you. error codes... ttps://removeandreplace.com/2015/12/22/asko-dishwasher-error-codes-how-to-clear-what-to-check/ch.
Feb 10, 2018 | Dishwashers
My Asea 1502 Dishwasher gets most of the way through a cycle then stops with lights flashing. It is empty of water. What is the problem?
Further to my problem with my 19 year old ASKO ASEA D1502 Dishwasher .
I found a Use & Care Guide online at the ASKO site:
http://www.asko.com.au/downloads/manuals/
(It is an 8MB PDF, only 20 pages scanned)
The manual says flashing lights in the combo I had indicate heater fault.
Manual has good test procedure and I followed that and it showed that the Heater is OK.
Machine works through full cycle but flashes at the end.
It is an old machine so I suppose I just live with it unless anyone has any suggestions.
Apr 23, 2008 | Dishwashers
Asea (Asko) Cylinda 12000 Washing Machine Spin Problem
No reset. Carbon brushes are worrn out. Consider changing the bearings while you have the motor apart. Se http://www.nettoparts.co.uk/shop/frontpage.html for spares.
Best regards, Dag Gulbrandsen, Norway
Apr 02, 2008 | Asko Washing Machines
Dishwashers Logo
229 people viewed this question
Top Asko Dishwashers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
