Question about Asko Dishwashers
Reset code for Asko Asea Dishwasher 1502 - Door will not open! What is the problem?
Posted by Milford Patsel on
5 Related Answers
asea1502
SOURCE: My Asea 1502 Dishwasher gets
Further to my problem with my 19 year old ASKO ASEA D1502 Dishwasher .
I found a Use & Care Guide online at the ASKO site:
http://www.asko.com.au/downloads/manuals/
(It is an 8MB PDF, only 20 pages scanned)
The manual says flashing lights in the combo I had indicate heater fault.
Manual has good test procedure and I followed that and it showed that the Heater is OK.
Machine works through full cycle but flashes at the end.
It is an old machine so I suppose I just live with it unless anyone has any suggestions.
Posted on Apr 24, 2008
jonniewalker
Starnley Johnwells
  • 1031 Answers
SOURCE: Asko door latch stuck
The only way is to pull out the dishwasher ,unhook the latch and then unscrew the door panel.your dishwasher is installed with 2 screws to the underside of your countertop. its tricky but youll have to remove them adjust to leveling legs down this will give you more room to get some head bit in ther to remove the screws if its out then slide the d/w foward ,remove the strike plate door will open then you can get your dishes out first
Posted on Sep 20, 2008
John Bloomfield
  • 534 Answers
SOURCE: I need a users manual for the Asko Asea 1403
Free manual available at :- http://www.asko.com.au/support/manuals/
go to above then search for 1403.
Posted on Jul 14, 2009
Anonymous
  • 52 Answers
SOURCE: Stuck in the dry cycle
defect in main panel .....call for service ...
Posted on Jul 25, 2009
jyackle5
Jyackle5
  • 8197 Answers
SOURCE: manual for Asko ASEA 1400 dishwasher
You can get the manual on the link below. It is uper right corner next to the man under the pdf. You will have to click on the stars to download.
http://safemanuals.com/user-guide-instructions-owner-manual/ASKO/1400-_E
Good Luck and please rate 4 thumbs up for the freee answer
Posted on Apr 24, 2010
Hi - I have the Askko asea 12002 and the machine won't empty water and therefore door won't open. How do I get around this. I need to get the clothes out ASAP.
Remove outlet hose at back of machine and drain into a bowel or bucket the door will then open. Check your filter is not blocked and also the pump
Jul 29, 2010 | Asko Washing Machines
Manual for Asko ASEA 1400 dishwasher
Apr 24, 2010 | Dishwashers
Jul 25, 2009 | Dishwashers
Asko 1503 error code
Hi, Sounds like a bad door switch. Here is a site that may help you. error codes... ttps://removeandreplace.com/2015/12/22/asko-dishwasher-error-codes-how-to-clear-what-to-check/ch.
Feb 10, 2018 | Dishwashers
Sep 20, 2008 | Asko D1706 Built-in Dishwasher
1502 NO POWER TO PANEL
The wiring diagram is INSIDE the metal casing behind the lower kick panel. It is a paper schematic that details the wiring of the dishwasher. Mine was pretty water logged and crusty. Just unscrew the kick panel. It should be right behind it
BTW: Ours also lost power to the panel last week. It's interesting that the production date of our Asko is from 1988. Exactly 20 years. Asko's warranty is also exactly 20 years. Coincidence? Don't bother trying to replace the board. Asko discontinued it and it is no longer available.
May 18, 2008 | Asko Dishwashers
My Asea 1502 Dishwasher gets most of the way through a cycle then stops with lights flashing. It is empty of water. What is the problem?
Apr 23, 2008 | Dishwashers
Asea (Asko) Cylinda 12000 Washing Machine Spin Problem
No reset. Carbon brushes are worrn out. Consider changing the bearings while you have the motor apart. Se http://www.nettoparts.co.uk/shop/frontpage.html for spares.
Best regards, Dag Gulbrandsen, Norway
Apr 02, 2008 | Asko Washing Machines
Dishwashers Logo
156 people viewed this question
Top Asko Dishwashers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
