Question about Radio Communications
Bc125at. I want to enter a frequency, just to listen, not to program. For instance, monitoring my flight...controller gives pilot new frequency...I want to tune to that freq without storing ir
Posted by Robert Fourt on
5 Related Answers
Anonymous
SOURCE: IR frequency determination
The remote could be using RF, which is why your Niles equipment cannot handle it. There is no way to duplicate the RF or convert it to an IR signal.
If the remote is using IR, make sure the batteries are full and the light is low when you are learning the codes with tne Niles equpment. There is no way if it's IR that the freq is > 100.
Posted on Apr 23, 2008
LVT7857
Larry Tezekjian
  • 117 Answers
SOURCE: SONY CDX-SW200 only tunes into odd frequencies?
Not unless he unit is capable. I know that Cadence made their decks with this feature, and I haven't seen anyone else as of a year ago.
Posted on Jan 28, 2009
Anonymous
  • 96 Answers
SOURCE: Toshiba 2100TB tuning without the remote control
If you are sure, that there's no way to do it manually on the TV, there are only two solutions: buy a new remote control according to your TV set model (sometimes it's hard to find) or buy a universal remote control
Posted on Jan 30, 2009
Anonymous
  • 12 Answers
SOURCE: I get an error when I try and enter certain freq. Any idea why?
you have to push the program button before you put the frequency in and then press enter
Posted on Feb 06, 2009
TOLhamRadio
John
  • 509 Answers
SOURCE: Yaesu ft230R. I haven't used
You have to ADD a PL Tone board. There should be a front panel switch that says TS that is the on/off power to the connector. There is a connector inside for +12VDC, switched ground and Encoder input. Look online for the schematic, or contact CommSpecialists for the sheet that lists the colors of the wires on the connector and where you connect them when you add a CTCSS Tone board.73's
Posted on Mar 27, 2009
HOW DO I GET MY POLICE SCANNER BC125AT UNIDEN TO SCAN ALL CHANNELS
You read the manual and you watch the videos
Search Results
[PDF]BC125AT Owners Manual
www.cabelas.com/assets/product_files/.../636073_uniden_bc125at_owners_manual.p... other than as described in this manual could invalidate your warranty and ... Thank you for purchasing a Uniden BC125AT Handheld Scanner. The scanner ... without tedious and complicated programming. The scanner gives you direct access to over 40,000 exciting frequencies. Use your scanner to monitor: • Police. • Fire/ ...
Uniden BC125AT Scanner - Uniden Support
unidensupport.com/Find-Your-Product/Scanners/BC125AT Top Questions for the BC125AT Scanner. How to install the programming software for the BC125AT - See Youtube.com video. How to Program the BC125AT - See Youtube video and written instructions below. Driver Installation Instructions for the BC125AT. How do I fix my audio cutting In and out? Turn off Close Call ...
BC125AT Owners Manual - Uniden Customer Support > Home
info.uniden.com/twiki/pub/UnidenMan4/BC125AT/BC125AT.pdf No information is available for this page.
Learn why
UNIDEN BC125AT OWNER'S MANUAL Pdf Download. - ManualsLib
https://www.manualslib.com > Brands > Uniden Manuals > Portable Radio > BC125AT View and Download Uniden BC125AT owner's manual online. Handheld Scanner. BC125AT Portable Radio pdf manual download.
How to Program Frequencies Into a Uniden Bearcat Scanner ' Chron ...
smallbusiness.chron.com > ... > More Business Planning & Strategy Radio-frequency scanners check for active radio communications in your immediate area. They're commonly purchased by hobbyists, but they also have many business applications. For example, warehousers can use them to monitor communications between warehouse staff, truckers and security guards. Frequencies ...
Programming the Uniden Bearcat BC125AT - YouTube
? 6:51
https://www.youtube.com/watch?v=Seg_rhILSRs Jan 19, 2014 - Uploaded by K4DPS
Basic steps on programming a channel into the Uniden Bearcat BC125AT.
HOW to PROGRAM the UNIDEN BC125AT POLICE SCANNER the ...
? 8:22
https://www.youtube.com/watch?v=K7VIE7LJshU Oct 27, 2016 - Uploaded by ASMR NATURE SONGS
UNIDEN BC125AT SCANNER - How to program software the EASY way. !!!LIKE & SUBSCRIBE!!! CHECK OUT ...
BC125AT - The RadioReference Wiki
wiki.radioreference.com/index.php/BC125AT Contents. [hide]. 1 Features; 2 Owner's Manual; 3 Firmware Updates; 4 Hidden Menus & Features; 5 Related Pages; 6 Reviews, etc; 7 Supporting Software; 8 Yahoo Groups and Mailing Lists (software and receiver support); 9 BC125AT Scanners for Sale ... Uniden Bearcat BC125AT police scanner manual Google Search
Jan 07, 2018 | Uniden Radio Communications
I cant seem to be able to program a frequencies into my scanner. I have a list of local frequencies but the numbers are to large to enter into the scanner to accept. it only holds up to six numbers but...
Frequencies in the range you mention may be part of a trunked system that your scanner cannot follow, but you can still enter and monitor the frequency. Yes, your BC340CRS will handle frequencies with up to five decimal places, as long as the last two digits are 25, 50, 0r 75 (see page 16 of the BC340CRS Owner's Manual). The best programming instructions for your scanner are also in that manual. If you don't have a copy, you can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC340CRSom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
Mar 01, 2011 | Uniden BC340CRS Base Scanner
How do you program a certain frequenceny and then make it the only one being monitered
To program a frequency into the scanner:
- Power the scanner ON.
- Press the HOLD key.
- Enter the number of the channel that you wish to program.
- Press the FUNC and PGM keys. The channel number will display.
- Enter the frequency, including the decimal point.
- Press E to store the information in the scanner.
To monitor a single frequency:
- Press HOLD.
- Enter the channel number of the frequency.
- Press HOLD again.
Need the manual for your scanner? You can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC92XLTom.pdf
Bill B.
Nov 14, 2010 | Uniden BC92XLT Handheld Scanner
I have a Uniden Bearcat 140 10 channel scanning radio and need to know how to program it. Can you help? The Model is BC 140 and the serial # 73061234 It was my dads and he passed on and I want to...
Your scanner is a basic 10-channel "oldie" and it's fairly simple to program and operate. To enter/program a known frequency:
- Power the scanner On
- Press MANUAL to stop scanning
- Press MANUAL repeatedly to advance to the channel that you wish to program
- Enter the desired frequency, including the decimal point (e.g., 156.225).
- Press E to enter the frequency into memory
Press the MANUAL key to advance through the channels, and press SCAN when you're ready to listen.
For a comprehensive database of active frequencies in your area, visit:
Bill B.
Oct 20, 2010 | Uniden BC244CLT Base Scanner
Please tell me how to program in my county scanner frequency numbers .
To enter a known frequency into your BC92XLT:
- Enter the number of the channel that you wish to program (1 through 200)
- Enter the frequency, including decimal point (e.g., 155.455)
- Press E to enter the frequency into the scanner's memory.
More detailed programming instructions can be found in the factory user's manual which you can download and print, at no cost, here:
Bill B.
Oct 08, 2010 | Uniden BC92XLT Handheld Scanner
I have a kenwood tk 360 how can i use it to talk to other kenwood radios and what is the monitor switch?
The TK-360 is an 8-channel commercial/business radio that's available with a wide variety programmed frequencies, and operation requires a license. Unlicensed operation could interfere with authorized users and carry a heavy fine/penalty. The MONITOR switch lets you lock onto and listen to one of the programmed frequencies even when you have not specifically been called. You can identify the programmed frequencies by using a frequency counter or a scanner with the "Close Call" feature.
Dec 08, 2009 | Cars & Trucks
Programming
No problem!
First if you don't have an owner's manual you can download a copy free HERE
Be sure to read all of it...it's got great info to get you comfortable with all the controls of your scanner.
Secondly you'll need local radio frequencies for your area.
Do a google.com search enter "radio frequencies" and also the name of your city, county and state.
You'll find people may have posted lists of frequencies for your area.
Print out the lists and then by following the step by steps in the owner's manual, enter each frequency into your scanner .
Once you've got them entered... you'll be ready to scan!
For understanding the 10-code language used, do a google search for "10-codes" and you should be able to find a list of definitions... They'll also use alot of local abreviations for street names and locations and those will be understood more as you listen to your local calls for a while.
good luck and have fun...and be safe.
k
Jul 09, 2009 | Radio Shack Pro-82 Scanner
Wanted manual realistic 2010scanner
The realistic 2000 series scanners do not have a "VFO" (variable frequency occilator) in the true meaning of the sence. This basicly means that they can only scan the channels or memories that you have programmed.
You can however set a low frequency (like 144 Mhz) and a high frequency (like 145 Mhz) and the scanner will "bounce" between the two, picking up anything in between.
Do you have the operating manual? If not, here is a copy
Turn on your Pro-2010 by rotating [VOLUME] clockwise. (When first turned on, your Pro-2010 may start scanning).
Rotate [SQUELCH] fully counterclockwise. You'll hear a rushing noise from the speaker. Slowly rotate [SQUELCH] clockwise until the noise just stops.
You're now ready to start entering frequencies.
Programming Frequencies
Before programming frequencies, make sure your Pro-2010 is turned on and the SQUELCH is adjusted.
Suppose you want to program Channel 1 to receive 162.55 MHz. Here's how you would do it:
1. Press [MANUAL] and select channel 1. You can do this in two ways:
press [MANUAL] continuously until the Display indicates Channel 1 or
by pressing [1] [MANUAL].
2. Press [PROGRAM] to enter the programming mode.
3. Enter the desired frequency. In this case, press the [1] [6] [2] [.]
[5] [5] keys. Check the display to make sure the frequency it shows
is the one you meant to program. If it is, press the [ENTER] key.
4. To add more frequencies, just press [PROGRAM] to advance to the next
channel and follow the steps above.
5. If you ever want to change the frequency entered for a specific
channel, just enter the new frequency "over" the old frequency using
steps 1, 2, and 3.
Make a mistake while entering the frequency? Just press [CLEAR], enter the correct frequency and press [ENTER]. If you're entering a new frequency in place of an old one, the old frequency won't be "erased" when you press [CLEAR]. It will remain stored on that channel until you correctly enter a
new frequency and press [ENTER].
You'll hear a "peep" sound as you press the various keys. This lets you know the key has been properly "entered" into your Pro-2010.
Using the Scanning Function
Your Pro-2010 will automatically scan all the channels you've programmed and stop whenever it finds a signal. To scan channels, just press the [SCAN] key.
To stop scanning, just press [MANUAL] and you can select specific channels
you want to listen to.
IMPORTANT! Your Pro-2010 won't scan unless SQUELCH is set to the point where no sound is heard if a signal isn't being received.
Delay Function
When your Pro-2010 is scanning, it will stop whenever it finds a signal on a channel. As soon as the signal ends, the scanning function will resume. Most communications heard will be two-way. To make sure you don't miss any replies, press [DELAY]. This will cause your Pro-2010 to stay on a channel for two seconds after the end of a transmission, giving you time to hear any reply. To release the Delay function, just press [DELAY] again. The Delay indicator will show on the display when the Delay function is used.
Lockout Function
You may want your Pro-2010 to "skip over" certain frequencies while it's scanning (such as continuously transmitted weather broadcasts). To "lock out" such channels, follow these steps:
1. Press [MANUAL] to stop scanning. Continue to press [MANUAL] to
advance to the channel you want to lock out.
2. When you reach the channel, press [LOCK OUT]. The display will show
[o] to indicate this channel will be skipped over during scanning.
3. To release the lockout, press [MANUAL] to stop scanning. Advance to
the channel that is locked out and press [LOCK OUT] once again. [o]
will disappear from the display.
If you use the lockout function on all channels, scanning will be impossible - you'll only be able to change channels using [MANUAL].
Speed Selection
Your Pro-2010 will normally scan channels at a rate of four channels per second. If you press [SPEED], channels will be scanned at a rate of nine per second. Press [SPEED] again to return to a rate of four channels per second.
Priority Function
You might want to scan other channels yet not miss a call on a channel of particular interest to you (police, fire, ambulance, etc.). The Priority function will let you scan other channels - but if a call is received on the Priority channel, your Pro-2010 will automatically switch to the
Priority channel!
1. Only Channel 1 can be used as Priority Channel: Key in the desired
Priority frequency into Channel 1.
2. Priority function works only when the unit is in Scan or Manual mode.
3. Press [PRIORITY] to start Priority function. A [P] will appear on the
display.
4. Press [MANUAL] or [SCAN] to listen to other channels. Your Pro-2020
will check the Priority channel and switch to it if a signal is
received on it.
5. To cancel Priority function, press [PRIORITY] again. the [P] will
SEARCHING WITH YOUR PRO-2010
One great feature of your Pro-2010 is its ability to "search" for frequencies being used. This means you can hear all the action on the airwaves in your area! To use this great feature, just follow these steps:
1. Press [PROGRAM] key.
2. Press [LIMIT] key. Enter the lower limit of frequency range to be
searched (such as 45.00 MHz). Press [ENTER].
3. Press [LIMIT] key again. Enter the upper limit of frequency range to
be searched (such as 46.00 MHz). Press [ENTER].
4. Press either [up arrow] or [down arrow] to start Search. [Down arrow]
will start search from the highest frequency and go down. [Up arrow]
will start from the lowest frequency and go up.
5. You can control the speed of the search by using the [SPEED] key to
accelerate or to slow down the search.
6. Search will stop when a frequency is found with a signal. To restart search, press [up arrow] or [down arrow]. In Program Mode, search range will be displayed each time [LIMIT] is pressed. It is impossible to change the lower frequency only: to change lower frequency you must change higher frequency first. The higher frequency can be changed any time.
Storing Frequencies
If you want to enter some of the frequencies found during search, do this:
1. Press [MONITOR] when your Pro-2010 finds a frequency you want to store.
2. Use [MANUAL] key to select a channel to enter the frequency your Pro-
2010 found. The display will show the frequency currently stored on
the channel, but don't worry - the old frequency will be erased when
you start to enter the new one.
3. Press [PROGRAM].
4. Press [MONITOR] again. The new frequency found during the search will
be displayed.
5. Press [ENTER] to put the new frequency into the channel in place of
the old frequency.
6. Press either [up arrow] or [down arrow] to resume the search. To
return to manual or program operation, press [MANUAL] or [PROGRAM].
To resume the search from one of the limit frequencies, press [LIMIT]
and then [up arrow] or [down arrow].
Error Indications
Sometimes when you try to enter a frequency for a channel or as a search range limit, you may find an ------ on the display. This means the frequency is in error and you won't be able to enter it into your Pro-2010. Such frequency errors usually mean you've entered a frequency outside the ranges your Pro-2010 operates on (such as 225.00 MHz) or you've put the decimal point in the wrong place (14.682 MHz instead of 146.82 MHz). Check carefully to find your mistake and then press [CLEAR]. You can now enter the correct frequency.
Hope this helps,
M3ODQ
Feb 01, 2009 | Radio Communications
Aug 21, 2008 | Radio Shack Pro-82 Scanner
Radio Communications Logo
138 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Are you a Radio Communication Expert? Answer questions, earn points and help others
