Question about Garden
1971 yamaha 360st dirtbike Why will it not start?
Getting spark and gas Has started once or twice briefly
Posted by Valerie... on
Michele Collins
Air filter is probably clogged.
Posted on Jul 14, 2019
5 Related Answers
SOURCE: getting spark ,not getting gas
The valve is open. Is it working? Check for flow through the petcock and then out the fuel hose. Next check to see if fuel is making its way through the carb and down the throat of the intake manifold. If you are getting gas to the carb, but do not smell gas fumes coming out the exhaust after you have cranked and cranked, the problem is most probably one of the little idle jets on the carb or the float needle and seat. either you can rebuild the carb or the shop can. The spareparts aren't expensive, but it will feel like you were workin on a 40 rolex, with all those teeeeny parts! Unless you are major short of bucks.... todashop, todashop, todashop we go! (su nt to the theme from the Lone Ranber or the William Tell Overture, depending on whether you are highbrow or lowbrow)
Posted on Apr 08, 2009
Anonymous
SOURCE: yamaha warrior won't start
a yamaha warrior isnt a 2 stroke. they make a street bike nad a four stroke quad. Check your carburator. check your spark plug and check your stator. it may be very minor considering it was running fine then just went out. no noise or anything. you would have heard something if you broke something internal.
Posted on May 21, 2009
Anonymous
  • 7 Answers
SOURCE: my 2002 yamaha blaster will not start.
Check that you are actually getting spark to the plug first. If you're getting spark, check your timing. I would say these would be the easiest 2 areas to start with. If both of these are good, it could be anything in your wiring, or your CDI box. Good luck!
Posted on Jul 08, 2009
czaa
Arnie Burke
  • 6480 Answers
SOURCE: 98`350 yamaha warrior elertic start
may want to chec fuse-sometimes a normal lookin one is bad-test inspect wiring in ignition system for corrosion-cuts plug wire could be bad or connect
Posted on Aug 20, 2009
Skuly
  • 37 Answers
SOURCE: 1971 yamaha 175 motorcycle electrical problem
ill do a list of things that can help or be the problem.
1) Pull the coil off and wire brush down all the bare metal. then do the same to the frame where it bolted on. Make sure there is a grounded wire that bolts back onto the coil if there was one, Replace the wire end for the ground peice.
2) Pull off the spark end cap and cut the wire down a few mm until you see new wire then screw it back on. (if its NGK)
3) follow the wire from the kill switch and make sure it isnt grounding out.
4) Hotwire - find the kill switch and unplug it. if this doesnt help unplug the ignition key wiring. on older bikes it will work for ignition but not lights for the key part. if this helps you need a new Ignition barrel / Kill switch.
5) check your wiring harness make sure it isnt grounding anywhere exept where its ment to.
6) make your your engine to CDI is plugged in and has no oxide in it
7) try and find somone with a running bike the same as yours and borrow there CDI, if this helps you need to buy a new CDI or check yours for wiring shorts.
hope this helps if not buzz me ([email protected])
Posted on Feb 17, 2010
My 1971 JD 2520 was starting, running for about 5 minutes, then just dies. Not missing out at all, just dies. Now will try to start but doesn't. Help!
Hi Stacy:
I'd be suspicious that it's not getting fuel, but considering the age of the machine............ probably time for a methodical maintenance check.
Spark plugs (if gas). condition and check for spark.
Did this only happen once, or if you leave it for a while, will it start again and then die?
You may be able to find a forum of owners of these machines.
Here's a link that may assist.
https://www.google.ca/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=1971+JD+2520+owners+forum
Cheers
Jul 13, 2016 | John Deere Garden
Can't get spark to the plug on my 1971 Yamaha 250 dirtbike, what can I do?
that bike is simple and not much can be wrong, check the coil, the wire where the plug goes, check the points, service manual
www.manualsonline.com/mfg.name/make/model/starter_problems
www.ask.com/1971yamaha250/fix_start_issues/
Apr 21, 2015 | Yamaha Motorcycles
1971 yamaha r5b 350, i have spark and i have fuel flow, will not start, wont even turn over ????
don't know how you know you have spark if it wont turn over, but if it is elec start jump strait to starter. if it is a kick start and wont turn over ,motor locked up. need more info to really help
Oct 09, 2013 | Yamaha Motorcycles
I just bought a 1988 yamaha virago 750 and it was stored outside covered for over 4 yrs.Cleaned carbs and gas tank,put new plugs in,new fuel lines and checked fuel filter is ok. I have spark,compression...
good start on cleaning things BUT, you should replace pump. the pump will have the same gum **** the tank did. you can unhook lines and turn over to see how much fuel you get
Jun 14, 2011 | 1988 Yamaha FZX 750
What would cause a Honda 100 dirtbike not to start
About 10,000 different things. Give more detail. Is there good gas? Does it have electrc start? Is the battery good? Does the starter crank the engine? Is it getting ignition spark? What was the last thing that happened before it quit running?
Feb 15, 2011 | 2001 Honda CM 125 C
Yamaha banshee will not start
Did you accidentally cross the spark plug wires?
Other wise its going to be hard to diagnose,
Do you have plenty of compression,
Are you getting gas to the spark plugs?
Is the air filter clean/new?
You will need a factory service manual to diagnose further if all the above is ok
Jun 19, 2010 | 2008 Yamaha Yamaha G5
How do you change the sparkplug?
I have a suzuki 2005 dirtbike 250 4 stroke I can't find my manual anyone have that i can download or do you know where the spark plug is? it won't start
Apr 15, 2010 | 2004 Yamaha YZ 250 F
Motorcycle/dirtbike/ttr225/starting problem. Is not getting gas to sparkplug.As long as i put gas in sparkplug hole motor fires until burns gas out.
sounds like your pilot jet may be clogged, or your needle valve is stuck shut, remove the float bowl and check it out. (the pilot jet will be the smallest one, and the needle vavle will be attached to the plastic float assembly.
Apr 07, 2010 | 2002 Yamaha TT-R 225
Dirtbike wont start what could be the problem
recharge or. replace your battery; the battery needs a huge amount of amperage to turn over the engine but less to fire the ignition
Aug 02, 2009 | Honda CRF 250 R Motorcycles
I have a 1992 yamaha wr 500cc dirtbike i parked it and itwontrun
Hello there>>Get your self a new set of plugs and you'll be good as new...Sounds like the plugs got fouled.Have a great night
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
Apr 03, 2009 | 2005 Yamaha WR 450 F 2-trac
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
