Question about LG Washing Machines
Plz help my LG fuzzy logic keep showing PE - LG Washing Machines
Posted by Shireema Dyason on
robert
  • LG Master
  • 2,536 Answers
PE= pressure error. A water level error. Check hose to pressure sensor. Is it connected? Does it have a hole in it? Otherwise replace pressure sensor.
Posted on Jul 17, 2019
5 Related Answers
Anonymous
  • 33 Answers
SOURCE: WHAT IS THE SOLUTION ON ERROR MESSAGE PE IN MY FUZZY LOGIC WFT601
There is a round clean out door accessed from the front of your unit. Some models you have to take the lower panel off entirely to clean it out. It unscrews and probably there is anything and everything you can imagine clogging the pump inlet....thus the error message "PUMP ERROR" THe unit's error code may manually have to be deactivated in the control panel to reset the unit to normal operation.
Posted on Nov 30, 2008
Raquel123
SOURCE: I have an LG fuzzy
My lg making strange sound had 3 half years keeps coming up L E on screen
Posted on Mar 29, 2011
Jacques De Meyer
  • 500 Answers
SOURCE: What is the problem if
Pressure Switch faulty.
Replace with P/N: 6501EN1001A
Reply if you need directions for removal & installation.
Good Luck!
* If you found this solution helpfull, please rate with 4 thumbs up & a testimonial.
Posted on Apr 08, 2011
taverner_pau
taverner_pau
SOURCE: i have an lg 8.5kg fuzzy logic that keeps coming
My Fuzzy Logic 8.5kg keeps on saying de
Posted on Jul 31, 2012
Danny
  • 160 Answers
SOURCE: Hi ihave a lg fuzzy logic wf-1022tp top loader.
You have a problem with the pressure switch (water level sensor).
Either a faulty switch, blocked air chamber or hole in the pressure hose linking the chamber to the switch.
Thanks
Posted on Jul 14, 2014
Error Code PE
go to the manufactures website and download the user manual and check in trouble shooting guide eric
Jan 19, 2018 | LG Washing Machines
Fuzzy logic washing machine 12.5kg. What does PE code indicate?
PE pressure level switch error. This monitors the water level. It has a tiny hose connected from the drum. Could be blockage in the hose.
Feb 16, 2016 | LG Washing Machines
LG Fuzzy logic PE error
Pressure switch may be faulty.
May 15, 2015 | LG Washing Machines
Fault PE....How do I replace the pressure sensor on an LG fuzzy logic 5kg wf-t502 top loader and where can I purchase this part?
PE Means pressure sensor error this spares is very rare to defect 1st check full pressure sensor the wiring harness any damage or wire cut means the error will show in display
Mar 26, 2015 | LG Washing Machines
How do I fix PE Error code for LG Washing machine fuzzy logic
PE means pressure error. The water pressure sensor is reporting too much water in tub. It can be bad sensor or too much water is really in the tub. Too much water is caused by water not being pumped out. Kinked line. Bad pump. Etc. or inlet valve not shutting off. Does it seem that there is too much water in tub? If water level seems good and if tub fully drains, the water pressure sensor probably. Good luck.
Mar 03, 2015 | LG Washing Machines
What is a PE error on LG fuzzy Logic? beeping at the same time
Pressure switch fault......could be just blocked pipe!
locate pressure switch under top cover....far right corner, disconnect thin rubber pipe and blow through it to clear any blockage......might be lucky!
Oct 19, 2014 | Washing Machines
Hi ihave a lg fuzzy logic wf-1022tp top loader. When I switch it on it says PE pings whole time please HELP
Thanks
Jul 14, 2014 | Washing Machines
Washing Machines Logo
41 people viewed this question
Top LG Washing Machines Experts
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
