Question about The Health & Beauty
Im looking for the wiring diagram for a rascal scooter
Posted by Brian Lowry on
5 Related Answers
Anonymous
  • 253 Answers
SOURCE: need a wiring schematic for a rascal scooter
hooperimports.com/showpages.asp?pid=1013
they have wiring diagrams and information on how to wire chinese import engines and for more info contact http://tinyurl.com/m7ghqz
Posted on Jun 19, 2009
Paul B
  • 61 Answers
SOURCE: Rascal mobility scooter will now only go backwards
On some scooters it is possible to change the polarity of the motor. If its a two brush motor (most are) you can just swap the red and black wires around in the connector plug for the motor. Make sure you get the right wires if you do this but I have to point out that there is obviously a problem with the scooter and I would strongly advise you to get it looked at by your local dealer as the problem is potentially serious and may cause other problems aswell. I cant really understand why it would only go backwards. May be a throttle pot problem or main controller fault. Either way, as I said, best get it looked at as even if you do swap the wires, it is most likely that the scooter will only travel forward at the usual speed for reverse, normally 2mph! Hope this helps...
Posted on Mar 19, 2010
Anonymous
  • 177 Answers
SOURCE: wiring diagram for sc234ala mobility scooter
Hi. Do you need a basic wiring diagramme for the lights, motors etc. or do you need one for the controller? What faults do you have?
Fisher and Paykel sold their mobility scooter business to Plega Healthcare in Australia. Plega now no longer suport the mobility scooters.
We have some parts left in stock, and were an authorised service agent for these machines.
No one was ever supplied with a circuit diagramme for the controllers.
We do have all the service manuals here and have a full set of the fault codes.
You can email us at [email protected]
Good luck. Neil.
Posted on Jul 24, 2010
John Fourteen Six
  • 2418 Answers
SOURCE: I HAVE A RASCAL MOBILITY
I do not know of a Scooter graveyard, but I will look for one. I found a site that sells many different types of 24volt battery chargers. If you have a special port on the scooter and you still have your old charger you can cut off the end of the bad charger and wire it onto a new battery charger. Now as with most lead/acid battery's any charger with a built in volt/amp regulator will work.Your old charger spect's are for a 4amp max rating, Any constant 2.5amp or better should recharge your battery's overnight. I am sending you a link to a site called Battery Stuff.com where you can find a 24volt charger for as low as $89.oo, Now I understand this may be a bit out of your range, but a new battery charger for a laptop computer will run about $115.oo. So for a Heavy Duty scooter that is not to bad. Plus it may out last 2 sets of battery's. Now use this site as a reference and maybe you can find one you like local. Hope this helps Fixya up.
Posted on Apr 12, 2011
gopakumarg43
  • 76823 Answers
SOURCE: Rascal 240 scooter Battery charged ,scooter
Hello
There is an overload protection switch in it. It will look like the the protection switch that can be seen under the mixes. The picture of the overload protector is added here. Its press button will only seen outside. Just putsh it once and check. The motor has carbon brushes inside it to get armeture contact. If these burshes are worn out, the motor won't turn, and the scooter won't move. There will be two of them in opposite directions. They are replacable parts. The picture of it is also given here. Check these first. If you need anymore assistance from me, feel free to get me by FixYa.
gopakumarg43.gifgopakumarg43_0.gif\
OK
Posted on Aug 05, 2011
2answers
Does the owners manual have a wiring diagram in it for the rascal 230 electric scootetr
Hi marilyn, Sadly no mobility scooter manual will give you such information, i willing to help , what do you want to know ? faulty lights , thinking of fitting a new controller ?
Regards
Rob
1helpful
2answers
I need a. Wording diagram for my rascal 200 mobility scooter. Where can I find one downloadable?
go google --type in schematic diagram for rascal 200 mobility scooter and if there is one you will see it as a pdf version download
Where can I get a wiring diagram?
I may have one around here. need to look.
Any part in particular? was thing about adding an Auto Go section to the app.
Scooter Doctor App
my email is on there ask more stuff
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
LOOKING FOR A WIRING DIAGRAM FOR RASCAL SCOOTER 600T
go to http://www.strege.com/BlueDoc click on rascal then click 600
2helpful
2answers
Rascal 230 wiring diagram
Check the multi pin connector on tiller and where it connects under the seat between the batteries. Most common problem.
2helpful
2answers
Wiring schematic rascal 600 24v electric
hi, firstly what controller is fitted (curtis) ? then i can give you a ideal controller wiring schematic but you won't get hold of a Rascal one..
Regards
Rob
www.gewizrepairs.co.uk
Rascal 600T Scooter FIX IT Manual
There is an owners manual available which has a troubleshooting guide at the following: http://manuals.monsterscooterparts.com/mobility/Rascal/manual-rascal-600-t.pdf
If you have a good relationship with a local dealer they may be able to copy and provide you with one.
Electric Mobility, the manufacturer, in my experience will not provide one to you.
Rascal 600 wiering diagram
Hi Carol, I have lots of Rascal answers at my link, also check the Rasca pics, the is a Diagram there. but if you have a specific problem you can post there or here, we will do are best for an answer. Scooter Doctor App
Open Questions:
Health & Beauty Logo
Top The Health & Beauty Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Paul Carew
Vernon Taylor
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
