Health & Beauty Logo
Question about Pocket Health & Beauty
My digital pocket scales read zero even with weight on them?
Posted by Kelli Ibbotson on
Jamiu Sulaimon
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 21 Answers
  1. Clean the Scale. Make sure that the pocket scale is completely clean. ...
  2. Reset Scale to Zero. You want to reset the scale so that it is at zero. ...
  3. Find the Calibration Weight. ...
  4. Find Nickels for Great Substitute Weights. ...
  5. Calibrate. ...
  6. Check the Calibration.
Posted on Jul 17, 2019
5 Related Answers
Anonymous
SOURCE: conair scale ww36gd err reading
I have a WW36DG digital scale and most of the instructions are the same, so far as I can see. When you tap on the scale, 888.888 appears. It is just seting itself. If you step on the scale before it reads 00.0 it wil give you a Err signal. If you stepped on the scale after it read 00.0, and an Err signal appears, either your battery is very low or it is malfunctioning. it does have a 10 year warranty on it. For the person wanting to set the scale, here are the directions. Good luck.
Customizing Your
Weight Watchers® Body Fat Monitor
1. Tap center of scale platform with foot to activate digital display (display will
flash).
2. Wait for "0.0" to appear in display window.
3. You are now ready to input your personal data. Firmly press the SET button
located below the display.
Enter User Number
• P-01 will flash in display window
• Press UP or DOWN arrows to select your individual user
number (Ten user numbers available: P-01 through P-10)
• When selected user number appears in display, press SET
button to save user number
• The scale is now ready for you to enter your height
Set Height
• "Ht" (height) will flash in display window
• Press UP or DOWN arrows to scroll to your height measurement
• Press SET button to save height
• The scale is now ready for you to enter your age
Set Age
• "Age" will flash in display window
• Press UP or DOWN arrows to scroll to your age
• Press SET button to save age
• The scale is now ready for you to enter your gender
Set Gender
• The gender icons will flash in display window
• Press UP or DOWN arrows to select male or female icon
• Press SET button to save gender
• The scale is now ready for you to weigh yourself and to
determine percentage of body fat
Posted on Jun 26, 2008
Anonymous
SOURCE: weight watcher scale not calibrating weight correctly
Press the scale once with your foot. All screen options should display to initialize and then go to 0.0. Now step on the scale. It should read out your correct weight. If not, first remove and replace the battery for reset. If still not, replace the battery. If still not it's ready for return or replacement. Hope it works! Dave - CA
Posted on Aug 25, 2008
Anonymous
SOURCE: Conair WW41 Scale
To totally reset the scale and remove any old data in the users take battery out for 2 hours.
To use the USER functions:
Tap scale to turn it on
When you see "0.0" press
Press SET button. "P-1" will appear and blink
Use UP/DOWN button to select a user number
once desired user number (1-4) appears press SET button to confirm
when 0.0 appears step on scale this will enter your starting weight
press SET to confirm
scale automatically sets a goal weight of 10% below starting. you can raise or lower it by using arrow buttons-Press SET to confirm
Tracking weight
tap, see 0, select user number. Scale displays start weight, then goal weight then 0.0 and you weigh yourself. In the smaller windows it will display last weight and the difference between current and last weight then diff between current and start then diff between current and goal
Posted on Dec 04, 2008
Anonymous
  • 67 Answers
SOURCE: Fluctuating weight on Digital Scale from one minute to the next..
i believe that, like most electronic scales, the first time you get on the scale you must step off to allow it to zero itself. Then step back on to get your correct weight.
Posted on Jul 28, 2009
mhkamran
Hasan Khan Amran
  • 184 Answers
SOURCE: PROBLEM WITH WEIGHT CALIBRATION
Calibration procedure for Robinair AC machine.
NOTE:FOR SCAL CALIBRATION YOU SHOULD HAVE 9KG/20LB OF WEIGHT.From main menu go to change default (press 8787 for old type machine or 5454 new type machine)
then press enter/start key.after enter to default nenu you have to select calibrate scal option.press again enter/start key then follow the on scree message.once you done so,press stop/exit key to complete the prcess.
Posted on Aug 18, 2009
On a Taylor 9857 bathroom scale I get 0000 display even after changing batteries What might be wrong?
FAQs - Scales
I received my scale and my first weight reading was really wrong. What happened?
The scale may need to be initialized. This process is necessary because the scale was moved during the shipping process. Initializing the scale "re-seats" the internal parts allowing the scale to find the correct "zero." Here is how to initialize your scale:
  1. Place the scale back on a hard surface floor.
  2. With one foot only, place just enough weight on the scale for the display shows zero's or dashes. Once you see zeros or dashes remove your foot.
  3. Wait for the scale to turn off again.
  4. Step up onto the scale for a weight.
Or, your scale may be on an uneven surface or on carpet. Be sure to place your scale on a hard, flat surface to get an accurate weighing.
2answers
What does it mean when my us-magnum 1000xr pocket scale says rCAL and keeps flashing 500.0
You need to send it out to the manufacture and have it recalibrated. Hence the code RCAL.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_c087e4b7d13c0163
My scale reads full when i turn it on whats wrong
Most scales will have what is called the "TARE" button... push the "TARE" button when nothing is on the scale and it should 'zero-out.'
Once it is zeroed, it should give honest weight readings.
Model WW710. Why is operation erratic?
Only thing you can do for the erratic operatic is check the condition f the battery, If that is not it then the scale is fubar.
How do I fix a manlloro digital pocket scale when it reads HHH?
I thinkn there is a reset button to press with no weight on the scale if I remember correctly. Might have to calibrate with the test weight too if the calibration is messed up (not likely though).
4helpful
2answers
How to calibrate 1000xr us-magnum digital scale
magnum 1000xr pocket scales turns on calibrates goes to different modes but wont show the weight when object placed on the scale,a lock appears in top left of window, is scales broke or do i have to make lock symble dissappear?
8helpful
I have lost my instructions for my Salter glass bathroom scales 9103. I have a EE on the digital mode what does this mean and what can I do to fix it so the correct weight shows
The scales display EE as they are reading a negative weight.
With the scales switched OFF place 2 glass plates on the scales and press ON.
The scales should now display 0g.
If this doesn't work add more weight and try again.
There is also 4 screws on the underside of the scales which hold the weighing bar in place, if you loosen the 2 smaller screws this should relieve some of the stress so less weight is needed to zero the scales.
Top Pocket Health & Beauty Experts
Brian Lee
jws1013
Are you a Pocket Health and Beauty Expert? Answer questions, earn points and help others
