SOURCE: Jenn-Air single electric wall oven #JJW9530DDS
try to open the door see if the door latch is extended if it is locate the light switch on the oven cavity and hold it in then hit start then cancel or stop the latch rod should go back
SOURCE: lofra five burner gas cooker, oven door not closing properly,
I had the same problem and took the door apart. The hinge has a spring inside which is held in place by a long rivet. The metal of the rivet is too soft and it bends and snaps. You cannot get a replacement hinge anywhere. I even tried Italy and France. Lofra won't speak to you by e-mail or phone. The next thing that happened was the element disintegrated in the ovan. These are the worst cookers on the market.
SOURCE: Oven Door will not close properly
Don't buy Bosh. This is a common problem with them and they are not interested in a fix (ie a thinner door seal would help or adjustment to springs...
SOURCE: Ilve oven door adjar with a gap at the top
Yes but try removing the door usually a small lever on the hinge or just lower the door a bit and lift it off. Then put it back on and make sure it sits back down into the hinges. We had one that did the same thing and the door was just a bit out of the hinge.
