Question about Kenwood Food Processors
How do you open a Kenwood Patissier MX270 Food Processor
Posted by Geoffrey Harris on
No turning of motor in my Kenwood MX270 Patissier
Follow the power, start looking wherever the power stops. Sometimes it can help to reverse phase & neutral to track where the power stops from the other side too. You are only doing this for testing purposes and need to put it back as it should be when you're done.
Dec 08, 2014 | Kenwood MX270 Patissier Food Processor
My Kenwood MX270 patissier doesn't work anymore. I've opened it and checked the brushes (still enough length) ; micro switch also is working. Which component on one of the two prints are suspicious?
Brushes are long enough but it there enough pressure on them to press against the armature? What about the armature? Did you use a meter to check the windings?
Dec 07, 2014 | Kenwood MX270 Patissier Food Processor
Moter is working but dooh hook not working
hi if you still have problems email me and i will try and talk you through,
it may be the belt (teeth worn out) or the pulley (same problem).
the info given in your post is very vague.
if its the teeth on either the belt or pulley there is a simple fix.
remove bottom of base with screwdriver there should be screws under the feet of machine. use a bike valve screwdriver to remove the two remaining screws(depending on make and model)
remove belt, put RUBBER BAND
Jan 24, 2013 | Kenwood MX270 Patissier Food Processor
How do i open the kenwood fp370 food processor
Try to open this web address:
http://ecx.images-amazon.com/images/I/91BZWe69vqS.pdf
And you will find some basic tips to open and use this food processor.Thanks
Jun 01, 2012 | Kenwood Food Processors
I need a service manual for the MX270. Don't know how to open the machine.
I am trying to open a Kenwood p?tissier MX270 s?ries to hava a look inside.
How do I remove the top to get access to it please?
Kind regards,
Sam,
Jan 03, 2011 | Kenwood MX270 Patissier Food Processor
Food Processors Logo
150 people viewed this question
Top Kenwood Food Processors Experts
ThaMp3Doctor
ThaMp3Doctor
Ross Keen
Are you a Kenwood Food Processor Expert? Answer questions, earn points and help others
