Question about Maytag Washing Machines
Maytag centennial 400Xw3 smoking during spin cycle
Clothes still damp after full cycle, rearranged sheets, set washer on Drain and Spin cycle, washer started smoking. Unplugged, replugged to unlock lid, unplugged again, removed clothes, no water left in washer. Washer stopped smoking after a few minutes. Appears to be a direct drive, Maytag model MVWC400XW3 Centennial
Posted by Greta Shannon on
4 Related Answers
Ian Greenland
  • 351 Answers
SOURCE: Admiral AAV8000AWW washer - clothes are wet after spin cycle...
may be a loose belt or a partial blockage somwhere.
Posted on Mar 08, 2008
Anonymous
  • 639 Answers
SOURCE: washer spin cycle
Dear Friend,
ngfam1 here for you!
I am happy to be of assistance!
If it's reduced from hoe it used to do it, then you must call service before there is any more damage.
Some washers can leave the clothes damp or slightly wet but not dripping!!!!!!!!!! Thats a malfunction!!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. Please give me a good rating here in fixya.com before you sign out!
Posted on Aug 28, 2008
richroth
Richard Roth
  • 9472 Answers
SOURCE: Washer immediately goes into wash cycle when
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Posted on Jan 26, 2011
iam6fan
Chris Huff
  • 6289 Answers
SOURCE: Maytag Centennial washer agitates when
Kim Chasse is correct.
Posted on Oct 17, 2018
Maytag centennial washer - not draining on some settings
Check outlet hose for kinks or restrictions. Make sure the outlet hose is free to expel water at full volume. Make sure the outlet hose is not mounted to high. Check pump impellor has all it's vanes intact. Check for coins in all hoses & pump.
Dec 21, 2013 | Maytag Centennial 3.2 cu. ft. SuperSize...
Why is Maytag Centennial 3.2 cu. ft. SuperSize Capacity Plus Top Load Washer shaking during spin cycle
check to make sure it is sitting level on the floor and one leg adjuster hasnt backed in making it shake. But even when you stick cloths in evenly they can bunch up during cycles.
Jan 02, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
Damp clothes at end of spin cycle
Time to check out and clean your filter...........
Mar 01, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Rattling noise during spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Washing Machines Logo
96 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
