SOURCE: Fujitsu wall mounted air conditioner leaks into the room
Make sure the unit is level, this is very important. Check for blocked drain tube, which runs from the bottom of the drain pan under the cold coil to the outside. Clear tube with a piece of coathanger wire, be gentle.
SOURCE: air conditioner remote
- check if the battery is still good
- check if the receiver of the unit is clean and no obstruction.
- Some of remote control have a reset switch, every time you change it with battery you have to reset it.
- Some of remote control have A and B selector at board and remote control, check this if they set at the same frequency.
- To check if the remote control still working you have to test your remote control to other unit with same model as yours. If its not working then replace your remote control. But if its working then you have to replace your receiver board.
- Some remote control have to be reconfigure so you have to read your manual.
SOURCE: Westpoint split air conditoner remote contol unit
1.model no.
2.capacity of yr unit.
3 brand name.
mailme [email protected]
i can send to u
SOURCE: Fujitsu wall mounted air conditioner.
during Cooling and Dry modes, if the unit is used under conditions of
lower temperature (18C) the heat-exchanger may freeze, leading to water leakage and other damage.
If the unit is used for long periods under high-humidity conditions, condensation may form on the surface of the indoor
unit, and drip onto the floor or other objects underneath. (About 80% or more)
Increase Temp to 20 and also run coil dry cycle,
