Question about Radio Communications
Isound twist M#1692 charged all night, when switch on the center indicator button keeps flashing red & blue and sounding a tone, ideas?
Posted by joe enners on
5 Related Answers
Anonymous
SOURCE: kds55a2000 red light flashing
The SONY Owner's Manual for the KDS55A2000 does not state what the 4 times blinking Power LED means.
However, my Sony Extended Care Service support insists that the projection lamp is the cause for the 4X blinking LED
Power light.
I do not agree but am forced to buy a replacement lamp (not cheap) to prove that the problem is probably the fan, as the TV Technician states elsewhere in these FixYa support questions and answer
Posted on Nov 29, 2007
Anonymous
  • 3 Answers
SOURCE: Power Button Flashing Red
Try unplugging the entire unit and letting it sit for 5 minutes. See if this helps. If not, you need to do a complete reboot, which will cause you to lose your settings, but will probably solve your problem. To do a complete reboot, you will need to hold down two of the front bottons on the front panel. I'm not sure which, so either consult your manual or see other posts here which describe the reboot process for Denons. Hope this helps.
Posted on Jan 05, 2009
Anonymous
SOURCE: controller not working
I had the same problem, so I called customer service and had me do this:
1) with the USB cable plugged into the controller, power down the ps3 and turn the on/off switch in the back to "off".
2) hold your thumb down on the front button (where you normally can turn it on) while turning the switch on the back to "on" again. keep your thumb or finger on the front switch.
3) You will hear the normal "beep" that you usually hear when the PS3 boots up, but after a few seconds later, you will hear a secondary beep. Remove your thumb or finger after this second beep and the PS3 will reset itself after a few seconds. I have a projector connected to it, so I had to set the display screen back to HDMI afterwards, but when I disconnected the USB cable the controller worked wirelessly again. The customer service rep said that this allowed the controller to pair with the PS3 again. Note: You probably do not have to have the controller plugged into the USB cable at all while doing this. I just happened to have it plugged in. Hope this helps.
Posted on Jul 02, 2009
Anonymous
SOURCE: Flashing Red, Green White & Blue
See: http://www.fixya.com/support/t143027-turn_off_cylces_colors
Posted on Jan 09, 2010
1SKS
SOURCE: Bluedio T9 Bluetooth won't charge
Well... I've got the n65, and this is the third time I've gone to charge it. Solid red, won't turn on no matter how long its been plugged in, can't find the manual, this fixya page is the best result online...so my solution is to stop by the local cell-phone accessory shop to buy something new.*
*Results may vary. :^s
Posted on Feb 24, 2011
Have plugged in over night and will not charge
Make sure charger is getting power and that it is putting out rated power. If all check out then the batteries have died and need replacement.
May 21, 2015 | iSOUND 1690 TWIST WIRELESS SPEAKER &...
Isound will not connect
Just hold the Bluetooth bottom while trying to connect to phone
Nov 28, 2013 | iSOUND 1690 TWIST WIRELESS SPEAKER &...
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
HOW DO I TURN IT OFF AT NIGHT? IS THERE A SLEEP MODE?
Here are the steps to turning your headset on and off.
indicator glows blue. You will hear ascending tones.
indicator glows red. You will hear descending tones. When power is off, indicator stays off.
Good luck from Headsets Direct - 800-914-7996.
Aug 12, 2011 | Plantronics Explorer 230 Bluetooth Headset
How do I turn it on. Is the red showing or not showing
To turn the Explorer 240 Bluetooth headset on, press and hold the call control button until the indicator glows blue. You will hear ascending tones. The headset will then show intermittent flashes of blue. You should only see a red light when powering the headset off or if you are charging the headset you will see a solid red light. User guide is included in this link.
Plantronics Explorer 230 User's Guide
Aug 03, 2011 | Plantronics Explorer 240 Bluetooth Headset
After i try to turn it on, I get 1 blue flash and 3 short red flashes and it wont turn on.
When you turn on your headset, the blue light indicates it's on and
the three red flashes indicates a charged headsets. If it's not
turning on after that, try resetting the headset (turn off and on).
Turn it off by pressing the call control button until the indicator
glows red (you'll hear descending tones). Once off, turn it on in the same way (you'll hear ascending tones).
Jul 08, 2011 | Plantronics Hama Voyager 520 Bluetooth...
My plantronics explorer 260 won't turn on. Also when I go to charge it the charging light stays on for about a few min. and then shuts off but i still can not turn it on. Please help
Here are a few steps to review before coming to the realization that your battery could be wasted. Give them a try and see if it helps any.
1) While your headset is charging, the indicator glows red. When your
headset is fully charged, the indicator turns off.
2) Turn off the headset: Press and hold the call control button until the indicator glows red. You will hear descending tones. When power is off, indicator stays off.
3) Turn on the headset: Press and hold the call control button until the indicator glows blue. You will hear ascending tones.
Feb 24, 2011 | Plantronics Explorer 232 Bluetooth Headset
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
They Won't Charge!
Try to press the power boton in the same time you plug the charger, after this action mine is working and charging perfectly, maybe this is the "reset" solution... Hope this helps you.
Nov 17, 2009 | Motorola Mobility S9 Headphones
When connecting up to charge red light comes on 'power on' button on front and no charging happens - any ideas? thanks
What does indicator light mean?
  • Steady red light: Battery is charging.
  • Steady green light: Battery is fully charged.
  • Flashing red light: Battery needs charging.
  • Flashing green light: The music receiver is switched on.
  • Flashing red/green light: The music receiver is available to be added to your phone.
Aug 24, 2009 | Sony Ericsson T303 Mobile Phone (Shadow...
Radio Communications Logo
138 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Are you a Radio Communication Expert? Answer questions, earn points and help others
