Question about Proscan Televison & Video
I can not find a remote for Model PLDED4018. Any suggestions?
Posted by Russ Anderhalt on
  • Ladmoultan
    Ladmoultan Jul 24, 2019
    Hye every one
    I am doing work for making cash more than $ 15k to $ 18k . plz check this link.
    HERE ?????? . www.green.jobs67.com
Denon amplifier (AVR-3801)
I'll let you know if there is a replacement remote available for your model.
Apr 11, 2008 | Televison & Video
I have an Emerson TV Model # EWT19S2 and I don't have a remote for it, I am trying to get a Philips SRU2103S/27 universal remote to work but cannot get it to work any suggestions Tks
I have an Emerson TV Model # EWT19S2 and I don't have a remote for it, I am trying to get a Philips SRU2103S/27 universal remote to work but cannot get it to work any suggestions Tks? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:[email protected],we sincerely hope we can help you!
you can also check this boards whether suit you:
1942LGR3P 715G1813 1 Philips ADTV1942LGR3P Power Supply Backlight Inverter
Nov 25, 2012 | Philips SRU2103S-27 Remote Control
When I connect my Sony Google TV to my SANYO TV through a HDMI cable, it does not work. Please any suggestions? SONY TV model = Sony RMVZ320 Remote Control SANYO model = SANYO MODEL DP50747 ed it int
First of all, be sure that your SANYO TV is on the correct input for the HDMI port you're using. If that checks out, you might check to see that another device (e.g. blu-ray player, laptop, cable receiver, etc...) works with the SANYO TV using that same HDMI cable and port. If it does work, perhaps your Google TV box is set for a higher resolution than your SANYO TV supports.
Aug 11, 2012 | Sony RMVZ320 - RM VZ320 Universal Remote...
The remote for my radio/cd player won't work any longAny suggestions? The model is: jWIN JXCD3250 Classic Style CD/AM/FM
Remove the batteries, clean the battery terminals with rubbing alcohol and Q-Tips and replace the batteries with new ones, if no! I would suggest you have someone look at it, usually find bad solder connections that need touch up.
Feb 13, 2012 | Jwin JXCD3250 Classic Style CD/AM/FM...
Lost remote, can't get tv to receive air, stuck on CATV. Any suggestions other than trash?
do google search for that remote you should be able to get it for about $35.00. If you do not have the model of the remote search for the model number of the tv with the word remote.
Dec 06, 2011 | Axion 16-3350 LCD TV
Have one for all urc 8910b02 remote need program code for panasonic home theater system model number sa-ht940
Difficult, suggest you go on line to the company, enter details as now and hopefully it will list the code.
Another suggestion there is on the web? several websites with listings of codes for various remotes, sorry not able to include web details, only found by searching myself once for a remote code.
May 24, 2011 | One For All URC-8910 LCD Remote Control
Locked t.v. (sva c86b model) cant open without remote is lost
You did not remark which make and model TV you are referring to, but most universal remotes can control most multiple devices: TV, VCR, DVD, Stereo, Satellite Box, etc. I would suggest getting one of these as buying an original remote would most likely be a lot more expensive. These remotes include instructions and program codes to enter for programming all your devices.
Hope this helps!
Dec 07, 2009 | Televison & Video
Obtaining remote control code...
Universal remote controls come with user manual and the additional code list which you can find the list of devices that can be used with the remote control, It depends on the remote control model that you have, each model has own specific quantity of supported devices and codes. If you are able to provide exact model of your Universal remote control we can check for you, Or simply you can search online <universal remote control model> + code
Good Luck
Jul 25, 2008 | Directed 434MHZ Remote Control
Televison & Video Logo
268 people viewed this question
Top Proscan Televison & Video Experts
matt martin
matt martin
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
