Washing Machines Logo
Madeline Cole Posted on Jul 13, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It won't spin out the water on the final rinse cycle
Maytag bravos xl mct top load model won't spin out the rinse water
Kenneth Simmons
Level 3:
  • Maytag Master 1,239 Answers
  • Posted on Jul 13, 2019
Kenneth Simmons
Maytag Master
Level 3:
Answers
1239
Questions
Helped
753087
Points
4061
5 Related Answers
Anonymous
  • 1294 Answers
  • Posted on May 18, 2007
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
jonniewalker
Starnley Johnwells
  • 1031 Answers
  • Posted on Sep 21, 2008
SOURCE: Whirlpool top Loading washing machine won't spin on spin cycle
If the washer won't finish a spin cycle, it probably means that your timer went bad or stalled. You can take the control panel off and look at the contacts for scorching or corrosion.
Anonymous
  • 63 Answers
  • Posted on Nov 14, 2008
SOURCE: Maytag legacy series washer top load-squeaky during wash and rinse
very possible if squeaks in agitation top springs that hold tub needs greased under spring & plastic shield under spring. had same problem on big front loaders whirlpool
fixrguy
  • 415 Answers
  • Posted on Aug 20, 2009
SOURCE: Maytag top loader on final spin cycle leaves the clothes soaked
how much water is in the bottom of the tub and is it louder than normal if so could be small droplets of water leaking from tub seal if not the pump is restricted by something and req replacement
Anonymous
  • 109 Answers
  • Posted on Aug 23, 2009
SOURCE: I have a GE top load washer model G157. When I
timer is bad
Maytag Bravo MCT Top Load wont spin out at the end of the cycle, I then have to use the drain and spin cycle and it will spin out.
Please try clearing sequences by rotating the cycle dial counter-clockwise a bit before starting a new cycle. The reset should then allow your newly chosen cycle to work.
Thank you.
I need reset instructions for bravos mct model mvwx655dw1
How do I reset my Maytag washer to factory settings?
The easiest way to reset a Maytag washer is to disconnect the power to the washing machine for three minutes. Disconnecting the power allows the electrical charge to dissipate from the washing machine, which allows it to reset. If the reset fails, unplug the washer again, this time leaving it unplugged for ten minutes
https://danmarcappliance.com/washer-repair/how-to-reset-a-maytag-washer/
https://www.applianceblog.com/mainforums/threads/maytag-mvwx655dw1-stops-during-wash-rinse-spin-cycle.65341/
Maytag bravos mct washer keeps filling with water on drain and spin cycly
Sounds like the electronic shut off valves are not working or the main board is not communicating correctly with those valves
1helpful
first thing to do is a reset. unplug it for 5 min and plug back in to see if it resets to factory settings.
1helpful
Maytag Bravos XL HE Leaks Adjacent to Bleach Dispenser, how do I fix this?
Fill it with water by hand and see what happens. Tape paper towels in the suspected area. Makes it easier to see. Part 2 ans: so the water is over powering the drain...that sucks. You are right, the valve is probably letting too much water out. I don't know if it is adjustable but I do know it'll probably cost a lot for an itty-bitty brass valve. If money is not a problem replace the valve. If you are a DIY'er, I'd try to use some sort of clamp on the hose leading into the dispenser and close it just enough to slow the flow down. Another idea is to open the drain up by cutting away some of the screen if it has one. A better source than me is to go to repairclinic.com and email them. They have a lot more experience than me. I did appliance repair as a side to handyman for 20 years & fixed just about everything for 50. I never had any formal training.
2answers
Why is my maytag bravos mvwb750wq washer so loud on spin cycle?
Is it moving around? I am guessing not so guess would be the drum is out of balance.
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
