Question about Kenmore Refrigerators
Can I replace the temp control thermostat on a kenmore freezer model 2539287413 by myself? Without a service tech?
Posted by Teresa M Edington on
Tom Chichester
    Top Expert:
  • Kenmore Master
  • 56,017 Answers
Depends upon your skill and experience in making electrical repairs.
Posted on Jul 13, 2019
Testimonial: "That much is a given. But I have not tried to access the old part yet as the new part is SUPPOSED to be ordered and I might get it someday. Someday. In the meantime the freezer still runs on 'quick freeze'. I just have to stay on top of it and keep it running. No place to keep the contents. Since I cannot shut it down...what I want to know is how hard is it to access the part? Installing a switch is nothing..getting to it is something."
5 Related Answers
Ron4705
SOURCE: The thermostat is out on my Kenmore 14.8 cu ft freezer
I asked a local repair shop. Just pull ******* the sensor wire and it will slip out of the tube through which it runs. Run the new wire which is attached to the new thermostat thru the same tube. Prior to purchasing the thermostat, I tested with a ohm meter for continuity ( there was none) and jumped the attaching power wires. The compressor ran verifying the problem with the thermostat. Thermostat cost $47.00.
Posted on Jun 08, 2008
Anonymous
SOURCE: Kenmore SR1087 Freezer Door will not close without lifting
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
check this site out. I have the same problem but I don't have to lift the door to close yet....
Posted on Aug 10, 2008
Anonymous
SOURCE: Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Posted on Nov 23, 2008
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: New replacement thermostat needs calibrating on my Kenmore oven
There is no real way to calibrate the thermostat. Most ovens have the same problem. By lowering the setting slightly will help get a closer temperature. Sometimes similar thermostats are substituted and may not be exactly the same as the original that came with your oven. Hope my trying to answer your question was helpful, Thanks, Sea breeze
Posted on Mar 27, 2009
Anonymous
  • 531 Answers
SOURCE: refrig/freezer thermistor temp/resistance chart needed
by model# you can get it not all carry the same (temp)
Posted on Apr 07, 2009
Kenmore chest freezer model 34hl408101-20000 no power
Sounds like the thermostat has failed & needs replacing.
Nov 13, 2013 | Kenmore Refrigerators
My Hotpoint Side-by-side temperature flucuates(model #HSS25GFTA). Items in freezer melt at times and then re-freeze. Same is noted for the fridge. Service tech added freon; however, problem continued. ...
You are correct on your evaluation of the " tech " the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature .
Sep 23, 2010 | Hotpoint HSS25GFT 25.0 Cu. Ft....
REFRIDGERATOR SIDE DONT KEEP COLD, BUT THE FREEZER DOES? WHY?
This symptom can be caused by many different failures, defrost system failure,( defrost heater,timer,thermostat), something blocking air transfer path to the fresh food section such as: ice build up, damper door not operating, main thermostat, check all these or have tech come in and check.
Good luck !
Mar 17, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The refrigerator ignores temperature setting.
Hello, This problem is going to be the cold control/thermostat, this part can be located in the control console inside the fridge bhind the freezer temp control knob (can also be found sometimes in the freezer depending on type/model) The reason your food in the fridge is freezing is because the thermostat controling the freezer temp is not shutting down and the air being blown into the fridge is too cold. Replace this cold control/thermostat and you should be fixed. If you have any other questions or concerns please feel free to comment again and give me some time to respond. Good luck! Mike
Sep 08, 2009 | Kenmore Refrigerators
Kenmore Coldspot EM5119829. The Freezer works
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
or..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 03, 2009 | Refrigerators
Kenmore elite, two doors. pull our freezer below. ref.not cold even at #7 setting (coldest). Freezer is working
OR..
Aug 21, 2009 | Refrigerators
Refrigerator side temp keeps dropping below freezing.
Set the freezer temp control to MAX cold and see if it improves.
If not replace the off/on thermostat.(cold control)
May 24, 2009 | Kenmore Refrigerators
Freezer temp
No, these fluctuations are a sign of a unstable control unit. test the control unit for its operational value and , replace the thermostats as well.
May 22, 2009 | Kenmore 64722 Top Freezer Refrigerator
Kenmore freezer model 253.26072100
Hi David,
I would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Aug 21, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore frostless 19 temp. control knob
i've pulled up the service diagram for it and there's no thermostat or temperature control but there's a limit sensor inside the freezer I'm sure that such sensor is failing and when it defrosts, it stays on to long, and the whole 15 min defrost cycles goes on causing the freezer to warm up, delaying the freezing process. I'm almost sure that the limit is going.
Jun 10, 2008 | Kenmore Freezers
Refrigerators Logo
100 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
John Tripp
John Tripp
gbob59
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
