Could have clipped the low voltage wire outside with a weed wacker, could have blown out the run capacitor or lost a major component! If the unit is buzzing when you turn it on but nothing's running (compressor or fan)then you have a failed run capacitor! The list of things it could be are endless without more info
SOURCE: where is the fuse on a Frigidaire GLMV169D
This problem is almost certainly caused by the thermistor failing. The thermistor is located at the
air outlet of the unit. This is a thermal resistor that cuts off the electricity to the unit if it overheats. Sometimes it can fail from age.
Go to;
http://www.appliancepartspros.com/
and enter your unit number. You can even get diagrams in the left-hand corner screen.
Replace with same value thermistor.
Also see if a mini manual in hidden behind the control panel.
SOURCE: Hi, Our Fedder's AC suddenly stopped working.
If this is a digital read out system,the circuit board has gone out in the unit behind the control panel.
SOURCE: I have a 2005 Pilgram 27 foot 5th wheel. My Duo
It's obviously on the 12voltDC circuit of the AC unit. Sounds like thermostat, or a relay in control box is faulty or bad connection. If you remove cover on ceiling assy., you should be able to hear it in the control box. There should be a model number on the ceiling assy., get back to me with that number and I can better pinpoint which relay. Also, try moving all thermostat buttons and temperature controls back and forth quickly to see if it may clean off a dirty circuit in thermostat as well. Make sure your AC hydro breaker is off when working with ceiling assy. just to be safe.
SOURCE: Model GSI-26 suddenly stopped cooling
It sounds like your compressor is having a hard time starting. Take your model number to an appliance parts store and ask for a compressor start relay. It plugs directly into your compressor and is easily replaced. Remember to unplug the refer first.
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Thank you. It makes no noise at all went I turn it on . Nothing. The fan doesn't kick on. It's like it's not getting power at all. I know I'm not giving enough info on it. But I really know nothing about AC units. Thank you for your response.
