Question about Refrigerators
Help my 330a hailea chiller not cooling fan works
Help my 330a hailea chiller not cooling fan work compressor starts then cuts off after twenty seconds then I've changed the small round thing on compressor and the square bit with small wired top hat thing that connects to comp still the same any help Thank
Posted by Nigel hudson on
Thefozz Inyourass
    New Friend:
  • 6 Answers
You need gauges to check the freon charge while it's short cycling, could be restricted or low on charge! You might try cleaning the coils and see if it's an air restriction, you have a safety device causing it to shut down and most the time on those its bc they are interchanged!
Posted on Jul 13, 2019
5 Related Answers
the dr
joey shearer
  • 447 Answers
SOURCE: Side by side stopped working but clicling noises every second two.
Ok the motherboard is malfunctioning. Ive observed this exact problem before. Replace the board and all will be normal again. If you keep lettig it click and click it may finally kill that relay that you descibed to me or even worse the compressor itself.
Posted on Dec 02, 2007
Anonymous
SOURCE: BEKO TZS490
AS A FRIDGE ENGINEER I HAVE COME ACROSS THIS PROBLEM BEFORE IT COULD BE A LOSS OF REFRIGERANT ALTHOUGH THIS WOULD STEADILY WORSEN IN USE,MORE LIKELY THERE IS A BLOCKAGE IN THE SYSTEM STOPPING THE REFRIGERANT REACHING ALL THE PIPEWORK THE CHEAPER FREEZERS USE THE SHELFS AS PART OF THE FREEZING SYSTEM.
THE ONLY SOLUTION IS A COMPRESSOR CHANGE AND REGAS (COSTLY IF NOT COVERED BY WARRANTY/GUARANTEE ETC)
IF FREEZER IS MORE THAN 5 YRS OLD BEST TO SCRAP IT UNFORTUNATELY..
Posted on Dec 19, 2007
Anonymous
  • 67 Answers
SOURCE: 2004 gmc sierra 5.3. AC not working AC Compressor fuse blowing
UNPLUG THE A/C CONNETOR ON THE A/C COMMPRESOR. REPLACE THE FUSE AND TURN ON THE SWITCH. FUSE OK . REPLACE THE COMMPRESSOR AND THE RECIVER DRIER.
Posted on Apr 17, 2009
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: AMA BX21 7 years old
Look inside the fresh food compartment. Behind the temp. control cover is a defrost timer. Yours may have a small opening that you can put a pencil eraser in and turn clockwise. When you do that the refrigerator should begin cooling again. I will be here to help you get your refrigerator going with diagrams and part numbers, Thanks, Sea Breeze
Posted on Apr 20, 2009
ifixalot4her
  • 46 Answers
SOURCE: rv rooftop a/c duo-therm quick cool
compressor locked up replace unit
Posted on Aug 01, 2009
My Daewoo freezer is not working since yesterday, we tried to change the fuse but it just works for 15 seconds then,it stops we don't know why can you help please?
I would think that the compressor is either overheating, or faulty and cutting out on a Thermal overload cut out device fitted to the compressor.
If it is overheating, then it could be due to several problems:
1] Ventilation to the compressor is poor, or blocked.
2] compressor Cooling fan failed ( not fitted on all models)
3] Condensor blocked ( Not fitted on all models) This looks like a small car radiator in the compessor compartment (if fitted?).
Turn the fridge off, and leave it for up to 2 hours to cool, once cool, ensure that the ventilation is good around the compressor compartment, and try it again. If it starts and runs as normal it may have just overheated. If there is a fan fitted in the compressor compartment, then observe if it is working or not when you turn it back on.
If the compressor cuts out again, as you have described, trhen it is more than likely that the compressor has failed and needs replacing.
This is not a job that a novice can do, and will be expensive to have replaced by a Refrigeration engineer.
I hope this helps?
Feb 22, 2016 | Daewoo Refrigerators
I have a Samsung rs21!!! it wont cool in either compartment. when I plug it in the compressor fan does a quarter turn then stops. the compressor runs for about 30 seconds then cuts out? any ideas plea
most likely the start relay on the compressor that changes from start windings to run windings. the compressor will run for about 30 seconds on start windings then click out on internal thermal overload.
this can be confirmed by turning it on and letting it do the 30 second run then when it stops just wait and see if it cuts in and tries to run again (usually takes about 5 min) the second time it cuts in it wil most likely not run for as long (usually about 10 seconds). if this is what it does get a new compressor start/run relay.
as for the fan flick it with your finger and see if it spins freely.
Jun 05, 2014 | Samsung RSA1SHPN American Platinum Inox...
Tru mug chiller won't get cold
Is the compressor running? Is the condenser clean and the fan running? Is the fan inside running? Is there ice on the coil? Those are the first things I would check after I check to see that the plug has power and the temperature control is turned on.
Mar 29, 2014 | True Glass Chiller T-24-GC
This compressor is in my aquarium water chiller. When I plug in the chiller, The compressor starts then goes off. a few seconds later it starts again then goes off. It continues to do this. I have changed...
The Freon is probably a bit low. When the compressor draws from the low side the extreme low pressure trips the low pressure switch, shutting down the compressor. With compressor off the pressure equalizes the low pressure switch opens and the compressor switches on. murf427
Aug 02, 2012 | Panasonic QA125K29CAU6 Refrig...
My True beer cool stopped cooling last night what should I do ?
That is a broad question. Lets do a checklist. When you plug the unit in the compressor behind the grill on the front should come on and the fan in front of the compressor should come on. The radiator in the compressor compartment needs to be clean from all dust and grease. Many times this is overlooked and can cause real problems by letting the compressor overheat. Now look inside and find the fan cover. It hangs from the inside top of the cooler. It should also be running. If either fan is not running the unit will not cool. Sometimes there is an obstruction, such as someone pushing a six pack up against the fan cover and pushing it into the fan. The fan down by the compressor is sometimes blocked by the cardboard shroud that is built around the fan. Also in a few cases rodents have gotten caught in that fan. If everything is running, you will have to look deeper into the compressor compartment. There is a screw in the front of the radiator that hold the compressor unit in the cooler. Unplug the unit from the wall. Remove that screw and slowly and carefully pull the compressor unit towards the front of the beer box. It will slide almost all the way out. You will see a coil of copper tubing at the back of the compressor that allows enough slack in the lines to slide this unit out. When you push this unit back in it helps to have someone behind the cooler to pull back on that coil as you push the unit back into the machine so it does not get crimped. With the compressor unit pulled out, plug it back in at the wall. If your compressor is running and you have proper amount of refrigerant, the small copper tube from the compressor to the radiator will get very hot, enough to burn your finger, after two or three minutes. After 10 minutes the larger copper line that is usually enclosed in a rubber sheathing should get cold. One way to know if you have a burned out compressor is to listen to the compressor and fans when you first plug into the power outlet. A bad compressor will usually try to start for 2 or 3 seconds and then click out. While it is trying to start the fan will slow down because the compressor is pulling way too many amps and is pulling power away from the fan until it clicks out again. If you can hear the compressor come on and run but it makes no heat to the radiator, you probably have a refrigerant leak. Your freon is gone or almost gone. If it was a slow leak you would usually notice that the cooler does not seem to cool like it once did. If it was working good and suddenly stopped cooling, the most likely problem is a bad compressor. Changing a compressor is usually beyond the average do it yourselfer because it requires welding the unit in place and gauges and a supply of refrigerant which is almost impossible to get without a liscense. Let me know what you find out.
Oct 13, 2010 | True TD-65-24 Commercial Refrigerator
Compressor fan cycles on and off .1986 carrier mo#38eh0363300l
Usually compressors cycle on and off due to the low preasure switch which disconects the compressor when their is a freeon leak. Put the gages on it and see if the preasures are correct.
Jun 26, 2009 | Carrier 38CKC036 Air Conditioner
Compressor not starting
Most likely it is a small round overload found next to the wires going into the compressor. If that one seems ok then the next thing I would check is the capacitor. Might need a start assist.ce5a8bd.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 10, 2009 | Dometic Rooftop RV Air Conditioner
York screw chiller R-22
hi! there;
there are several causes we can consider in tripping of unit on auxillary sensor.the sensor device was designed to cut off source at specific limit of time or load.the over load sensor device was equipted to the main source specially on cmpressor of chiller to protect of burning the motor.
common causes of tripping off unit
1.high current on supply source.you can check this on one common line of compressor.using clamp ammeter.what ever reading you got when unit is running,compare this on rated current on manuals if high ampere was registered.ther is an overload supply the over load sensor will activate and cut off your unit.
a. source of overload is due to obstruction on refrigeration system,filter dryer are clogged,excessi9ve oil on high side.
b. themostat not cycles on,due to poor condensing fan, dirty condenser fin tube,or condeser insufficient cooling effect.
c. bearing,lubrication are not maintained usually on compressor on open type unit,
2. electrical wire and electronic control board short circuited.
a.sometime relay malfunction on cantactor w/c the supply souce intermittent either on one line supplying compressor,the compressor will suffer,it will just hum and trip off,
b.busted capacitor will trip off your unit,due to in the absence of starting motor.
this are common ways unit trip off, so regards and have a nice day,and one thing more don't forget to rate me, thank's
Apr 08, 2009 | Heating & Cooling
I purchased a water chiller from you the other day for my father, I set it up at his house and within 30 minutes the light came on to say it was at temperature, I have one of these and thought this was...
it sounds like compressor ain't running check to see if any wires during the move got loose.
2nd if you checked the first, and looks o.k. you have a possibly defective relay/overload.
if you change it and still no cooling well your compressors bad.
hope to be of some help.
Apr 21, 2008 | Refrigerators
Clicking noise from compressor and fan runs 24/7
check the grounds to the ref. also check power to the ref. but it sounds like you have a floating ground the only thing else to mke comp.cycle is the relay which is on the comp. itself
Jan 08, 2008 | Kenmore 53092 / 53094 Side by Side...
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
