Question about Minolta Office Equipment & Supplies
Minolta 206 not going to power saving mode - Minolta Office Equipment & Supplies
Posted by Sanjeev Sharma on
1 Related Answer
Anonymous
  • 2961 Answers
SOURCE: monitor keeps going to power save mode
the settings should be the same as your notebook power saver settings or you will have to check extended monitor in your graphics card properties in control panel.
Posted on Sep 26, 2007
What is a service code c2558 mean on my copier? konica minolta bizhub 206
Its a black unit error code
It means the black toner is not supplying to d developer you can reset error code by logging in d service mode
Konica minolta 206 call c3452 - Konica Minolta Office Equipment & Supplies
FIXING HEAT UP ERROR
RESET BY OFF AND ON BY HOLDING UTILITY BUTTON OR RESET BUTTON
How to reset M1 call service on bizhub 206
Go to service mode and clear the counter
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
My bizhub c300 goes into pause. then i go push resume and then it goes into pause again.
Increase its power save time.Go to utility/Counter, then press check details, then select administrator mode, then enter password 12345678, now in copier setting or in system setting increase the power save time of your machine.It will not resume again.
C-206 Our printer has just come up with this fault code. It is a C300IF Help what has gone wrong?
c-206 this code means third tray lift up abnormality. call technical service representative.
5helpful
5answers
Go to meeting cannot locate folder to install to
I have this same problem. Its not an issue of permissions as neither my user who has Administrator rights locally and my domain admin account get the same message. I also tried deleting the GoToMeeting folder outright and still get the same error. (although it does re-create the folder for me)
Toshiba E Studio 35 copier goes to power save
Hi:
Hold down the 0 and 8 keys while turning on the copier. Keep on holding down the keys until the screen shows a adjustment mode screen. Once it does this key in 205 then you should see a numeric value. Input 15 and press start to lock it in This will change you power saver mode to 60 minutes. Next enter code 206. Key in 19 and press start. This will change your sleep mode to 240 minutes. These are the setting that are most generally used when these copiers are initially set up. Then just turn the copier off and back on. I hope this resolves your problem.
Good Luck
Andrew
1helpful
Energy saver mode
Yes you can change the power save mode. I don’t remember from where you can change it. but its easy for you if you get the all operation manual list form the printer, get the setting page from printer by pressing the menu from your printer then you will get all commands so then you can change all settings of your printer.
Top Minolta Office Equipment & Supplies Experts
Daniel Blask
Daniel Blask
Mehandi Husain ...
George Mclaughlin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
