SOURCE: Emerson Quiet Kool 6GC53 Air Conditioner
Chesapeake, given your symptoms you'll be looking at installing a new Selector Switch. But, before you go there... UNPLUG THE UNIT OR SHUT OFF THE BREAKER!!! Your selector switch does two things at a time, It energizes the fan motor (which it IS doing) and energizes the compressor at the same time. The voltage to your compressor goes from the wall into the selector, out of the selector, through the temp control then to the compressor. When the temp control is satisfied, it interrupts power to the compressor. The click you hear is the temp control being NOT satisfied and trying to send power to the comp. But if there is "no power" to send (i.e., the selector switch has failed)the compressor won't know to engage. Remove the front panel and filter. Remove the control box housing. Remove the knobs from the controls. You will now see the selector switch. Remove the 2 screws that fasten it (don't remove the wire yet!) and install the new switch. Then, one wire at a time, remove the wires from the old switch and install them on the new one. ***If you have an OHM meter, check the temp control before ordering a selector because this may be the problem and NOT the selector! To do this... remove the 2 wires from the temp control, set the control to "coldest". Then with your meter, test OHM's between the terminals. If you see "zero" OHM's, it's good. If you see no change in your meter, it's bad and THIS is the source of your problem. If you don't have a meter... you can test using this procedure... cut a 6" length of wire and strip the ends to about 3/8", twist the copper ends tightly. Remove both wires from the temp control, then insert one end of your jumper wire into one terminal and the other end into the other terminal. Make sure the "jumpered" wires are away from anything metal!!! And plug the unit back in. Now turn the unit on. If the unit fires up? It's the temp control, If not? it's the selector switch. Here's a link for parts...http://www.repairclinic.com/0080.asp
SOURCE: Wifi configuration
go to xda developers.com they will help you right away. There are so many connection configurations on this phone its amazing, I love mine.
SOURCE: htc shadow smartphone wifi driver problem
Try one of these sites:
www.allshadow.com
www.modaco.com
www.freddiereyes.com
Good Luck!
SOURCE: No cool air. Thermostat AUX light turned on
I suggest you call a qualified service repair man. There are as many ways to connect a heat pump as there are people doing them. Nothing is standard industry wide that has anything to do directly with color codes, so it would be meaningless to go into them here. The terminals may be adapted to standard but but the thermostat manufacturer may not follow any terminal designations.
However you may just have an extra wire touching one of the terminals inside the thermostat. You can check this by removing the cover. Look where the wires attach to the terminal screws on the thermostat. Sometimes a new service person cuts the insulation back too far here or in the outdoor or indoor units and a "whisker" from one wire can touch the other terminals. A whisker is not the normal case try and move it away from another terminal if its is touching there. However, you may have jumpers in place especially if you have W, W1, W2... at any of the 3 sections, meaning the outdoor, indoor and thermostat.
If you can tell me the terminal designations R,Y, W1, W2, E, G, O, (B)... at the thermostat and the color thereon each, then at the indoor unit terminals or wire designations and the color there, then
at the outdoor unit and the color thereon each terminal or wire designation there. I might be able to help if
the above whisker check you don't find anything.:
SOURCE: Elekta Window Air Conditioner, Thermostat won't cut off.
Good morning, I'm using Elekta window A/C 1.5 ton and I'm using this for almost three years and now there is eritating sound while the A/C is running. Could you please advise what is the problem?
BR/Art
