Question about RIM BlackBerry Storm 9530 Smartphone
I can not receive incomming blue tooth on my blackberry 9500
I have a blackberry storm 9500 phone, i only just got it secondhand it was on vodaphone but was unlocked to any network, the problem i have is that i can bluetooth pictures and files out but i can not receive incomming bluetooth pictures and files, can you help me with this problem
Posted by leslie241 on
Anonymous
To send and receive files between two BlackBerry smartphones using Bluetooth® wireless technology, complete the following steps:
  1. Enable Bluetooth technology on the BlackBerry smartphones. For instructions, see the Turn on Bluetooth technology section of the BlackBerry User Guide.
  2. Make the BlackBerry smartphones discoverable. For instructions, see the Make your BlackBerry device discoverable section of the BlackBerry User Guide.
  3. Pair the BlackBerry smartphones. For instructions, see the Pair with a Bluetooth enabled device section of the BlackBerry User Guide.
  4. Set the Trusted field to Yes on both BlackBerry smartphones by completing the following steps:
    1. In the Bluetooth application, highlight the BlackBerry smartphone and press the Menu button.
    2. Select Device Properties.
    3. Set the Trusted field to Yes.
    4. Press the Menu button and select Save.
  5. Send and receive the transfered file.
On the recipient's BlackBerry smartphone
  1. On the Home screen of the BlackBerry smartphone, select Media.
  2. Select a media type (Music, Video, Ring Tones, Pictures).
  3. Press the Menu button and select Receive using Bluetooth. The File Transfer dialog box appears, followed by a prompt to Save or Cancel the file.
  4. Select Save to save the file to the current location, or select the folder icon to save the file in a different location.
On the sender's BlackBerry smartphone
  2. Select the same media type selected on the recipient's BlackBerry smartphone.
  3. Press the Menu button and select Send Using Bluetooth.
  4. When prompted to select a BlackBerry smartphone, select the recipient's BlackBerry smartphone.
from :http://www.blackberry.com/btsc/search.do?cmd=displayKC&docType=kc&externalId=KB05409
[email protected]
Posted on Sep 24, 2009
Anonymous
  • 4 Answers
Try going into Media, pictures, app button, "receive using bluetooth". If this doesn't work, try pairing with the other device first, then do the above again.
Posted on Sep 16, 2009
wwlvictoria
    Renaissance:
    An user who is expert in 3 categories / brands.
  • RIM Master
  • 1,001 Answers
Small and Simple: Its outline feels like a mini iPhone 6, petite and charming, it doesn't need much space in your car; Simple design, easy operation, you can get away from complicated operation of some other Bluetooth receivers. Amazon com Charm sonic Wireless CSR4 0 Portable Bluetooth Receiver...
Posted on Dec 23, 2016
rabiu ssale
    New Friend:
If you have a problem with your blackberry phone. ask a question or send email-[email protected]
Posted on Mar 17, 2011
I need to unlock my blackberry storm 9500 from vodafa
Every BlackBerry has "Subsidy code" or "Sim lock code". To remove BlackBerry subsidy code or sim lock a special Blackberry IMEI Unlock Code is needed. By entering Blackberry 9500 Unlock Code on your BlackBerry you can use your Blackberry with any GSM and SIM card around the world. Blackberry Unlocking is simplest way to remove any or carrier restrictions from your Blackberry. Remote IMEI unlocking is the safest and fastest way to unlock a cell phone.i hope this will help you :)Good Luck.
Oct 06, 2011 | RIM Research In Motion Blackberry Storm...
I have a blackberry storm 9500 phone, i only just got it secondhand it was on vodaphone but was unlocked to any network, the problem i have is that i can bluetooth pictures and files out but i can not...
That isn't a problem when your done with the pairing you should go to media and press the bb button their you will find recieve ussing bluetooth , you should do the same thing evry time you recieve a file or picture ,.
Sep 06, 2010 | RIM Research In Motion Blackberry Storm...
How to unlock a blackberry storm 9500
Every BlackBerry has "Subsidy code" or "Sim lock code". To remove BlackBerry subsidy code or sim lock a special Blackberry IMEI Unlock Code is needed. By entering Blackberry Storm 9500 Unlock Code on your BlackBerry you can use your Blackberry with any GSM and SIM card around the world. Blackberry Unlocking is simplest way to remove any or carrier restrictions from your Blackberry. Remote IMEI unlocking is the safest and fastest way to unlock a cell phone.i hope this will help you :)Good Luck.
May 20, 2010 | RIM Research In Motion Blackberry Storm...
Blackberry storm 9500, blacklisted network
Unlock it and move to another network, if your blackberry is not unlocked, you can unlock it in http://blackberrymep.com .
Mar 15, 2010 | RIM Research In Motion Blackberry Storm...
I cant get my blue tooth to connect to my blackberry
MAKE SURE THE BLUE TOOTH HANDS FREE OR ANY OTHER DEVICE IS IN PAIRING MODE. ( THE PIN TO PAIR A BT HANDSFREE LL BE 0000 )
ALSO FOR INCOMING BT BEEP RECEVING
FROM MEDIA. CLICK MENU AND SELECT. RECEIVE VIA BLUE TOOTH.
Feb 24, 2010 | Cell Phones
My blackberry was unlocked however has gone to the reset screen a few times brought it to a tech guy after using it for a month the screen went blank there is still light in the phone but no sign of...
Try to reinstall your blackberry software since unlocked blackberry storm 9500 software usually has previous network configuration. But to make sure what exactly your problem you can bring your phone at local mobile repair shop and asking them to check your phone.
Nov 25, 2009 | RIM Research In Motion Blackberry Storm...
Blue tooth connection passkey
Most Bluetooth devices uses '1234' or '0000' as the default passkey. Since you tried using '0000', you may wanna try using 1234.
Have a great day!
May 22, 2009 | RIM BlackBerry Storm 9530 Smartphone
Can I download orange setting to my Blackberry storm 9500
http://www.business.orange.co.uk/servlet/Satellite?pagename=Business&c=OUKPage&cid=1044137040845
go to the website
Apr 07, 2009 | RIM BlackBerry Storm 9530 Smartphone
RIM BlackBerry Storm 9530 Smartphone Logo
1,368 people viewed this question
Top RIM Cell Phones Experts
Ekse
William Norris
William Norris
Muntejaya Ginting
Muntejaya Ginting
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
