Question about HP Pavilion s7700n (5584788) PC Desktop
Hp slim line s7700n when turned on beeps
My hp slim line s7700n when turned on just makes a high pitched beeping
Posted by mic4me on
  • mic4me Aug 29, 2009
    thanks krishmaqvan for the info with the hp s7700 it worked great.
  • Nouveau IT, LLC
    Nouveau IT, LLC May 11, 2010
    How many beeps do you hear? (one, two, one long, one short, etc.)
    Thanks
    C2S
Computer hardware and networking support
  • 4,281 Answers
Open cpu cabinet
Refix RAM memory then check.
Pull cmos cell for 10 minutes frommotherbord so all settings defaults.
Also clean dust from all circuit.
Reconnect ATX connector from smps supply to motherbord.
Refix processor fan and processor.
Let me know if you need more assistanse.
Thanks.
Posted on Aug 27, 2009
  • gmtoney Mar 21, 2011
    This worked for my problem... one short beep, one long beep. Thanks so much!!
Anonymous
  • 677 Answers
If its continuous, then its the Ram.
Posted on Aug 28, 2009
Hp altec lansing makes a beeping sound while starting
Try running a registry cleaning program. That should sort the errors out
May 20, 2014 | Acer Computers & Internet
Computer beeps every 30 seconds
It is car brakes. Turn that game off.
OH, I'M JUST KIDDING!
BIOS speaker is broken, and you hear high pitched beeps?
Hmmmmm,..........
CPU temperature in normal............
What is the CPU, and what is the temp? Hey, I gotta know so we are on the same page here, lol!
Me?
Those repeated high pitch BIOS Beep Codes indicate a CPU problem.
I would remove the Heatsink/Fan combo, and replace the Thermal Paste.
(Following Anti-Static Precautions, and cleaning the CPU, and Heatsink, of course)
Also make sure the Heatsink is sitting flat.
Yes, I know what you stated about Speecy, and Core Temp, but I would try it anyway.
Still no?
CPU is sounding Taps, and telling you goodbye.
Regards,
joecoolvette
Jul 29, 2012 | ASUS Computers & Internet
Hp slim line s700n beeps one short, one long when powered on
One Short followed by one long beep is indicative of a Memory problem. Unplug the power from the slimline. Remove the case to expose the inside and wait about a minute to make sure no lights on the motherboard are still on after unplugging the power cord. If you have more than one memory chip installed try removing one of them and sit it aside. Leave the cover off, plug the power cord back in and try rebooting. If it doesn't boot unplug the power cord, wait till all lights on the motherboard are off, then move the memory chip that is already in to the other slot that was occupied by the memory chip you have set aside. Plug the machine back up and try rebooting. If you still have a problem remove the memory chip and set it aside, now do the same thing with the initial memory chip that you set aside (that is trying it in both slots to see if your computer reboots). If you get it to boot successfully, make a mark with an ink pen or felt pen on the chip that is set aside because it is probably bad. You can try placing the chip you marked on back in with the working chip and see if your computer boots. If it does, it simply means your computer's memory just needed to be reseated, if it does not boot you know for sure the marked chip is bad so leave it out and take it (the chip, not the computer) to a repair shop to buy another chip.
Mar 14, 2012 | HP Pavilion s7700n (5584788) PC Desktop
When I talk, my friends complain of a high pitched buzzing. I'm using the Turtle Beach X11 via a wired controller on the Xbox 360.
Same issue here. Can hear the high pitch buzz, and friends complain about it.
I have 2 Turtle Beach X11 headsets, and 3 Xboxes (std, Elite, slim)
Unplug the mic, and no high pitch buzz. Plug it back in, and its back.
Tried all 3 boxes experience same issues
Playing with volume and mic settings doesn't make a difference.
Would love to have a fix for this :-)
Dec 25, 2010 | Voyetra Turtle Beach Turtle Beach Ear...
Hp laser jet all leds on and not working
The surge protector or UPS may not be allowing sufficient voltage through to the printer. HP printers do not have built in speakers of any kind. Because of this, they are not capable of making any beeping or squealing sounds. If any noises such as these are heard then the printer is probably connected to an Uninterruptible Power Supply (UPS) or a backup battery. To verify that the UPS is the source of the noise, plug the printer directly into a wall outlet bypassing the UPS.
The following are common symptoms:
  • High pitched squealing, beeping sounds, or alarms (UPS)
    NOTE: Noise over the phone line can also cause high-pitched squeals and beeping sounds.
  • Inexplicable or false error messages
  • Printer will not "wake up" from sleep mode
  • Printer appears to be DOA
  • Incorrect printout
  • Slower than normal printing
  • The printer control panel display is blank or shows garbled characters
  • Accessories, such as attached copier/scanners, do not function properly
  • Monitor loses power or shuts off
  • Computer reboots when job is printing
  • Job only prints half way, causing a paper jam
If it is necessary for the product to be connected to the above-mentioned devices, consider the following items:
  • There are many UPS configurations and load conditions that can affect proper printer operation. Depending on these configurations or load conditions, printer functionality cannot be predicted.
  • No damage to current HP LaserJet products will occur, but, depending on their particular UPS configuration, the printer may or may not operate properly.
  • Printing while on a UPS battery backup is not recommended because of the large power requirements of HP LaserJet products.
  • If the HP LaserJet printer is not operating properly and power line conditions are suspected, try a different circuit (a different wall plug located away from the current one), or try removing it from the UPS.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 24, 2010 | HP LaserJet P2015n Printer
Hello, i have a slim line s7700n and i have a problem. The screen wont turn on and it displays no input signal. I dont know if its the monitor or the computer?
1. You could have a faulty video graphic card on the mother board.
2. Your display or LCD screen has a bad power supply adapter or not get power at all.
3.Your display has a bad inverter board and needs service. I cannot tell not being able t o see the devices physically.
4. A computer tech can determine this with a few simple isolation test such as disabling the video card and using a know good one in the pci or AGP slot and connecting the monitor to it.
I hope this helps. Have a good day.
Aug 10, 2010 | HP Pavilion s7700n (5584788) PC Desktop
Hp pavilion723a when starts emits high pitch beeps and wont boot
These beeps are telling you that there is something wrong with the hardware. It means something has failed and will most likely need replaising. The certain amount of beeps will tell you the exact piece of hardware, count of beeps and phone hp and they should tell you whats wrong with it and if its repairable.
Good Luck
Aug 28, 2009 | HP Computers & Internet
Hp laptop's charger brick is making a repeating, high pitched beeping sound. how do i make it stop beeping?
You replace it. There is nothing an untrained person can fix inside one of those power supplies. And you should replace it soon. You do not want anything shorting out inside there and causing a fire.
Jul 10, 2009 | HP Pavilion zd7000 zx5000 zv5000 presario...
Beep from computer
My lap is also dv6000 and i have no symptoms like that.
it seems some thing is going wrong inside. As your lap is under warranty you should contact your service centre, it will be free.
Thanks
Iqbal
Apr 06, 2008 | Acer Aspire One PC Notebook
HP Pavilion s7700n (5584788) PC Desktop Logo
588 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Toby Lee
Toby Lee
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
