Nintendo DS Lite Console Logo
Posted on Aug 27, 2009
Hinge and Top screen of my Ds lite is broken.... T-T
My Nintendo Ds lite's top screen is really bad....it has just colored vertical lines all the way down. sometimes it changes but it's always fuzzy where i can't use it. Also the hinge is broken. The bottom tough screen is scratched too but i'm not worried so much about that, if i can get that fixed then ok, great but i'm waaaay more worried about the top screen. ummm...well Thanks to anyone that can help me with this cus i really want to play my Ds :(
Anonymous
Level 1:
  • Contributor 27 Answers
  • Posted on Aug 27, 2009
Anonymous
Contributor
Level 1:
Answers
27
Questions
0
Helped
13059
Points
63
You would need to replace the top screen ebay has them cheap
top lcd item no. 380136107562
a replacement shell can be bought for around £10 +
depending on what design you would like
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Sep 07, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
704
Points
11
Call the number back of your ds the will fix the ds or send a new ds if it can'be fix
Ds lite top screen
Yes its fixable but it depends on what has broken.
There are two possibilities the small barrel hinge has broken, this is just a case of fitting a new one by opening the case, unscrew the light and gently pulling the top of the case away till you can change the barrel hinge.
The other one is the case has broken and is not holding the barrel hinge, can bodge it with some glue sometimes but most often you need a new case.
DS Lite Top screen is all white after replaced for new one
you should use a crystal casing because every time you open the ds the wires get messed up or put some thing on the hinge so the ds hinge will not get loose.
1helpful
Nintendo ds lite top screen has lines
sounds like possibly the ribbon, should get it checked incase it dies for good.
4helpful
3answers
Broken nintendo ds lite hinge. Do I send it away for repairs or get a new console?
Nintendo will fix the hinges depending on a few things, first thing would be to determine how the hinges were broken. The hinges are tested before they leave the factory, the only way that they actually break would be because of physical damage/impact. Physical damage is not covered under the manufact warranty so you would get a discounted price depending on if your under warranty or not. Regardless giving them a call and having their techs fix them will be the best bet, not only because you know it will be fixed right and your warranty will start over the day it gets repaired.
Nintendo ds lite not turning on
see if you need new carger or if it needs new batteries
Nintendo DS lite - dropped
Might be worth taking it into a phone repair shop to see if they can replace the LCD screen. (yes, a phone repair shop - a lot of them do portable console screens too!) If they can't do it, it's probably unfixable realistically.
Ds lite hinge broken right h/s (looking at it)this has affected the top screen any ideas please
Hi, it sounds like when the hinge has got damaged, so has the top screen ribbon on the left as its easily ripped. Would need a replacement case and top screen, can recommend here for both: www.console-spares.co.uk, hope this helps.
2answers
Nintendo ds lighing probs
Mommyturtle, i suggest that you send it in. This will ensure that you get your DS back without loss on your part. But, if you would like instructions on how to fix your unit (This will void any warranties on your unit), please email me at [email protected] and I will step you through it.
Green screen
There is a ribbon that connects the top screen of the ds to the motherboard. It is possible that this ribbon became damaged when the hinge broke. A possible fix would be to replace the upper screen. Hope this helps.
6helpful
3answers
DS Lite has red lines in top screen?
It could also be running fluid from the screen's gel padding. I doubt that, though... It's best to buy or order a replacement screen. It's actually not too expensive and is not too hard to DIY. The problem with that, is it's really easy to accidentally break something while opening up a DS, especially the DS lites. Another problem is, you need a triwing screwdriver to open up the DS, which can only be found online. So, if you don't want to buy anthing online, you should just ask gamestop or something to repair it for you. It'll come at a price though...
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
