Question about Maytag Washing Machines
My maytag 2000 series washer model MHWE251 powers up fine but wont start when start button pressed. If I hold down tell start button it beeps 3 times but doesn't start.
I've made sure the control lock wasn't on and reset the machine by unplugging for 60 seconds.
Posted by Stacie Schock on
Sharron Krieger
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 156 Answers
Unplugging for 60 seconds good. Then after you plug back in, literally slam the lid shut (then open) 7 times. This makes the washer reset. Sounds weird, but works.
Posted on Jul 14, 2019
5 Related Answers
Anonymous
  • 619 Answers
SOURCE: Maytag washer not reset after power outage
The magnetic switch was stuck due to power outage / contactor are spark connect the contactor stuck together .Magnetic switch to replace.
Posted on Jan 09, 2008
Anonymous
SOURCE: Maytag quiet series model #:MDBH950AWB
The dishwasher lights are all blinking, it starts randomly, like one in every 50 times you press the buttons. I have unplugged it to reset several times. Nothing is working. I'm looking for a solution to blinking lights and it not starting. is there any other way to reset the controls????
Posted on Jan 21, 2008
Joe Povoas
  • 111 Answers
SOURCE: Control Lock light is on. Cannot get it off. cannot run washer
To unlock the controls Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
Posted on Jun 18, 2009
witamoto
Wilton Itamoto
  • 20 Answers
SOURCE: Whirlpool Duet HT WFW9200SQ Ser CST50067K7 Power Problem
I have the same problem. Did you ever find the solution to this problem?
Posted on Nov 03, 2009
VtToolMan
Mark
  • 704 Answers
SOURCE: Can't start the dishwasher, lock button is lit up.
Hello Albert, On the Jenn-Air dishwasher you have, you have to hold down the "Heated Dry" button for 3-5 seconds to unlock the control panel.
This should unlock the controls so you can again use the dishwasher normally.
Since you''re likely going to have this dishwasher for some time, I've included a link where you can download a free owner's manual for it.
I would print out a copy for your future use and reference. I also have a file on my computer that I title "Home Appliances and Equipment" which is where I download and save an electronic copy so I always have a backup copy saved, since manuals aren't always readily available on the web, as the appliances get older.
http://www.jennair.com/assets/product/6_920374_A.PDF
The info on locking and unlocking the dishwasher can be found on page 13 of the manual.
I hope you find this Very Helpful and best regards!
Posted on Nov 23, 2009
Testimonial: "Thanks for the detailed info about my question, VtToolMan, I greatly appreciate it. However, I tried to unlock it that way, but it didn't work. "
MAYTAG 5000 SERIES WITH STEAM WASHER WONT START
the lid isnt being detected as closed
the switches have a fault in them
Dec 05, 2014 | Maytag Washing Machines
I have a ps3 slim but it wont ley me get past the error code 80010002
Please follow the instructions below to start up your console in safe mode.
You can do this by: Putting the unit into Stand By. (solid red light on the power button)
- Press and hold down the power button once in standby for 3 beeps including the initial one when you first press the power button.
- Once you hear the third beep the unit will power off into standby mode again, when it does, release the power button.
- Then press and hold it down again, this time until you hear 2 quick beeps in a row, usually the 3rd and 4th beeps.
- Once you hear the quick beeps release the power button again and you will be presented with a message telling you to plug in your ps3 controller, do this.
- You will have 6 options appear on the screen. Please be aware that choosing some of these options can cause you to lose data on your machine.
From here, please choose option 4 ( Rebuild database ).
Nov 21, 2014 | Video Game Consoles & Games
Start button want stay on
this is most likely to be upper control board/located in the top of dryer
Feb 18, 2013 | Maytag Neptune Washer
I have a maytag front loader 4000 series and the control lock light keeps flashing and wont go off..
press and hold the lock button down for 3 seconds and it should unlock. if it does't then the electronic control is malfunctioning.
Jul 16, 2011 | Maytag MAH6700AWW Neptune Front-Load...
My PS3 wont start games when im signed in on PSN
HI I HAD THAT PROBLEM SO I ASKED THE EXPERT..HE SOLVED MY PROBLEM! BASICALLY THERE A CORRUPTED DATA ON YOUR COMPUTER WHICH NEEDS FIXING.
QUICK STEPS: PLEASE NOTE YOU MAY LOSE YOUR SAVED DATA SO BEST TO BACK UP SYSTEM TO A USB FIRST.
ONCE YOU BACKED UP YOUR SYSTEM FOLLOW THIS STEPS ONLY IF YOUR SURE. THIS WORKED FOR ME, IT WORKS 90% OF THE TIME SO I WAS TOLD BY THE EXPERT. REALLY DEPENDS ON HOW MUCH DATA HAS BEEN CORRUPTED.
QUICK STEP:
  • TURN PS3 TO STANDBY BY PRESSING THE BUTTON THATS ON THE CONSOLE..HOLD THE BUTTON,YOU WILL HEAR FIRST BEEP THEN ANOTHER BEEP 5SECONDS LATER, THEN THE THIRD BEEP. HOLD BUTTON DOWN UNTIL THE LIGHT TURNS RED THEN MOVE FINGER.
  • NOW SWITCH ON PS3 HOLDING POWER BUTTON ON THE CONSOLE..HOLD THE BUTTON DOWN YOU WILL HEAR FIRST BEEP THEN ANOTHER BEEP 5 SECS LATER, THEN TWO BEEPS TOGETHER.LET GO OF BUTTON WHEN YOU HEAR TWO BEEPS.
  • IT SHOULD SAY SOMETHING ABOUT CORRUPT DATA. AGREE TO IT. SOON YOU SHOULD HAVE A 6 OPTION MENU COME UP.
  • PRESS NUMBER 3...RESTORE SYSTEM FILES
  • IT SHOULD THEN RESTART COMPUTER.
  • NOW TRY PLAYING YOUR GAME ONLINE.
  • ITS MEANT TO WORK AS IT DID FOR ME.
IF IT DOESNT WORK THAT MEANS THERES ANOTHER PROBLEM. I WOULD ADVICE YOU TO ASK THE EXPERT. THEY TELL YOU STEP BY STEP, THEY FIXED MINE IN HALF HOUR. ITS WORTH EVERY PENNY.IF THEY SOLVE YOUR PROBLEM THAT IS! HOPE THIS HELPED YOU GUYS...GOODLUCK!
Jul 30, 2010 | Sony Playstation 3 (PS3) Console
It is beeping "Error" with 5 beeps
5 beep error means that the waste ink tank is full. You can reset the counter to make it print by doing the following: You have to be exact. If you make a mistake in any of it, just go back to the beginning and start it all over.
1.Unplug the power cord from the printer
2.Hold down BOTH the POWER and RESUME button at the same time and then plug the power cord back in. Keep holding down the buttons until the printer finishes its powering up noises.
3.After the printer is quiet, release the POWER and RESUME buttons. Then hold down the RESUME and CARTRIDGE buttons at the same time with one hand, and press the POWER button with the other. KEEP HOLDING DOWN the RESUME and CARTRIDGE buttons until you hear 2 beeps. They will come quickly together and one beep will be longer than the other. Listen carefully, as they are not very loud.
4. Once you hear the 2 beeps, release both buttons.
5. After both buttons have been released, then press the CARTRIDGE button 15 times. You will hear a beep each time it's pressed.
6. After you finish pressing the cartridge button 15 times, then press the RESUME button one time. The printer will beep and shut off.
7. Turn the printer back on by pressing the POWER button. The printer will work fine now. The waste ink will have been reset to 50% full.
Sep 29, 2009 | Canon BJC-85 InkJet Printer
Stops drains and bleeps with only spin light illuminated
It sounds like you need to re programme the
machine.
With the machine plugged into the wall and
turned on and the headset turned off this is what
you do.
Push and hold down the start button, while doing that you need to then push and hold down the power button.
Hold them down for about 5 seconds, during
which time you may a series of up to 3 beeps.
Then release the buttons.
Turn the machine off and then on again followed by the start button. Allow the machine to then run the complete cycle.
This should correct your problem, if this doesn't then you may need to then look at replacing the computer panels.
Jun 13, 2009 | Fisher and Paykel GWL11 Top Load Washer
Smart Drive 601 does not drain
with the machine plugged in and turned on but not powered up this is what to do
press and hold down the start button, then press and hold down the power button (hold down for 5 seconds) the washer may beep up to 3 times during this process
next remove fingers from buttons, then turn off machine with the power button, then turn on again and only press the start button this will now reprogram the computer
let it run untill end of cycle and this should fix prob
Jun 11, 2009 | Washing Machines
PROBLEM COPYING WITH MY ALL- IN- ONE
This message is inbuilt into most Canon printers, there is spongy thing in the printer which when fills up fires the message (it's mostly a counter in the printer, which can be reset more later...), per Canon this can only be dealt with in a lab but some of the more adventurous have tried cleaning it by themselves. Note that in a lab they won't clean it, it's a part that needs replacing and it might cost around $60. In most Canon printers there is a reset procedure that can reset the error and allow you to print some more before handling it again. Following are the reset procedures for some of the Printers: (not that F60 isn't listed here) Canon GENERIC "S" SERIES RESET CODE Waste Ink Counter Reset. (1) Turn off the printer. (2) Press and hold the RESUME button, then press and hold the POWER button. (3) Release the RESUME button, Next press and release the RESUME button two(2) more times in succession. Note: you are still holding the POWER button). The printer's carriage will "reset" or move momentarily. If the above was properly performed the printer will enter the "Service Mode". (4) Press the RESUME button 4 times, this will select the clear waste ink counter function. The lamp will alternate (change) color with each key press. 1. Service/Factory test printout, including ink sensor check. 2. EEPROM - Info printout. 3. EEPROM - Initialization. 4. Reset the Waste ink counter. 5. Printer model setting. (More selections beyond this point - However it is best leave them unaltered - You have been warned!) After selecting the desired mode (eg 4), press the POWER button to "set" the change, and return to the top of the function selection menu. Press the POWER button again to restart the printer. ++++++++++++++++++++++++++++++++++++++++++++++++++ Canon PIXMA iP1000 Waste Ink Counter Reset Manual for Service mode 1. Turn off the printer. And disconnect the printer cable. 2. Press and hold the POWER button, turn on the printer. 3. The indicator (L.E.D.) should be green. 4. Press and release the RESUME button , the indicator (L.E.D.) should be orange. 5. Press and release the RESUME button again, the indicator (L.E.D.) should be green. 6. Release both buttons. ++++++++++++++++++++++++++++++++++++++++++++++++++ Canon PIXMA iP1500 Waste Ink Counter Reset. Manual for Service mode 1. Turn off the printer. And disconnect the printer cable. 2. Press and hold the POWER button, turn on the printer. 3. The indicator (L.E.D.) should be green. 4. Press and release the RESUME button , the indicator (L.E.D.) should be orange. 5. Press and release the RESUME button again, the indicator (L.E.D.) should be green 6. Release both buttons ++++++++++ ++++++++++ ++++++++++ ++++++++++ ++++++++++ Canon i320, i255 Waste Ink Counter Reset. Step 1 : Manual Temporary 1. Unplug power and USB. 2. Open door and hold power button. 3. Connect power. 4. Close door, then release power button. or Step 1: Manual Temporary 1. Turn off the printer. And disconnect the printer cable. 2. Press and hold the POWER button, turn on the printer. 3. The indicator (L.E.D.) should be green. 4. Press and release the RESUME button , the indicator (L.E.D.) should be orange. 5. Press and release the RESUME button again, the indicator (L.E.D.) should be green. 6. Release both buttons. step 2 : Software for Permanant 1. Reconnect the printer cable. 2.Open General Tools software and select (USB PORT) 3 .Choose (SET DESTINATION 1) And it should be reset. Remark "After service mode Pls use software for permanent reset" ++++++++++ Canon i850, i950, S600 Start with the printer OFF 1. Hold down RESUME and then hold down POWER 2. release RESUME 3. press RESUME twice, then release POWER 4. Let green light blink until printer is done futzing Select function with RESUME press POWER to execute: presses - light color - function Number of presses - light color - function 0 presses - green - Test print (or exit service mode on i960) 1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960) 2 presses - green - EEPROM initialize 3 presses - orange - Reset waste ink counter ++++++++++ Canon S450 Printer 1: Power off printer 2: Hold Resume button then press and hold POWER, the beeper will sound once. 3: Hold POWER and release RESUME 4: Press RESUME twice 5. Release Power button 6: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange. 7: Press Power to set data ++++++++++ Canon BJC 1000 Serie 1: Remove Cartridge 2: Unplug the AC Power Cord 3: Hold down the RESUME button 4: Release RESUME after plugging in the AC Power cord. 5: Press the RESUME once within 5 seconds and release the RESUME . 6: Press and HOLD RESUME for two seconds or more and release it. 7: Press and HOLD RESUME for two seconds or more and release it. 8: Unplug AC Power Cord to set data. ++++++++++ Canon BJC-2000 BJC-2100 Serie 1: Remove the Cartridge 2: Unplug the AC Power Cord 3: Close Front access panel 3: Hold down the RESUME/RESET button and plug in the AC power cord 4: Release RESUME/RESET after plugging in the AC Power cord. 5: Press the RESUME/RESET once within 5 seconds and release the RESUME/RESET . 6: Press and HOLD RESUME/RESET for two seconds or more and release it. 7: Press and HOLD RESUME/RESET for two seconds or more and release it. 8: Unplug AC Power Cord to set data. ++++++++++ Canon BJC-210 BJC-240 BJC-250 BJC-255 BJC-265 Canon BJC-4100 BJC-4200 BJC-4300 BJC-4400 BJC-4550 BJC-4650 Unplug Power Cord Hold POWER and RESUME buttons Plug in Power Cord Release buttons Open front door of printer Hold the CARTRIDGE and RESUME buttons Press POWER Release all buttons after the beeps Press CARTRIDGE once Press RESUME ++++++++++ Canon BJC-5000 1: Power off printer 2: Press and hold RESUME then press POWER, The indicator will start blinking. 3: While the indicator is blinking , Press RESUME twice then Wait until the printer beeps to indicate service mode 5: When the indicator lights steady GREEN, press RESUME four(4)times. The indicator should be GREEN. 6: Press Power to set data Service Test Print 1: Power off printer 2: Press and hold RESUME then press POWER, The indicator will start blinking. 3: While the indicator is blinking , Press RESUME twice then Wait until the printer beeps to indicate service mode 5: When the indicator lights steady GREEN, press RESUME two(2)times. The indicator should be GREEN. 6: Press Power to Print Nozzle Print 1: Power off printer 2: Press and POWER, until the printer beeps and release. Demonstration Print 1: While the printer in ON , , Press and hold RESUME until the printer plays a melody of beeps. ++++++++++ Canon BJC-5100 Self Test Switch Printer off. Hold Power for 1 beep. Waste Counter Reset 1: Power off printer 2: Press and hold RESUME then press POWER, The indicator will start blinking. 3: While the indicator is blinking , Press RESUME twice then Wait until the printer beeps to indicate service mode 5: When the indicator lights steady GREEN, press RESUME four(4)times. The indicator should be GREEN. 6: Press Power to set data Service Test Print 1: Power off printer 2: Press and hold RESUME then press POWER, The indicator will start blinking. 3: While the indicator is blinking , Press RESUME twice then Wait until the printer beeps to indicate service mode 5: When the indicator lights steady GREEN, press RESUME two(2)times. The indicator should be GREEN. 6: Press Power to Print Nozzle Print 1: Power off printer 2: Press and POWER, until the printer beeps and release. Demonstration Print 1: While the printer in ON , , Press and hold RESUME until the printer plays a melody of beeps. ++++++++++ Canon BJC-3000 BJC-6000 BJC-6100 BJC-6200 S400 S450 F300 F600 F620 Canon BJC-7000 BJC-7100 BJC-8000 BJ-F800 i6500 1: Power off printer 2: Hold Resume button then press and hold POWER, the beeper will sound once. 3: Hold POWER and release RESUME 4: Press RESUME twice 5: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange. 6: Press Power to set data ++++++++++ Canon BJC-600 BJC-600e BJC-610 BJC-620 1: Unplug Power Cord 2: Hold POWER and FF and Print Mode buttons 3: Plug in Power Cord 4: Release after the beeps ++++++++++ Canon BJC-50 BJC-55 BJC-80 BJC-85 M40 M70 1: Unplug Power Cord 2: Hold POWER and RESUME buttons 3: Plug in Power Cord 4: Release buttons after the printers starts up 5: Hold CARTRIDGE and RESUME 6: Press POWER 7: Release all buttons after the beeps 8: Press CARTRIDGE 16 times 9: Press RESUME 10: Unplug the Power cord ++++++++++ Canon BJ-30 BJC-35v BJC-70 F14 Error Reset 1: Unplug adapter 2: Hold POWER 3: Plug in ADAPTER 4: Release POWER after printer starts 5: Hold FF and MENU and press POWER 6: Release after beeps 7: Press <> Cartridge until 1A is displayed 8: Press ONLINE 9: Press POWER to shutoff printer 10: Unplug printer then re-plug printer ++++++++++ Canon BJ F900, F890, F700, F500, S900, S820, S750 and S520 Turn off the printer. Press and hold the RESUME button, then press and hold the POWER button. Release the RESUME button, then press and release the RESUME button two more times in succession. (youre still holding the POWER button during this). The printer mechanics will move momentarily. You are now in Service mode. Pressing the RESUME key will select a function; for example, pressing RESUME 4 times will select the clear waste ink counter function. The lamp will alternate color with each key press. 1. service/factory test printout, including ink sensor check 2. EEPROM info printout 3. EEPROM initialization 4. Clear the waste-ink counter 5. Printer model setting. (more selections beyond this- leave this alone) After selecting mode, press the POWER button to commit the change, and return to the top of the function selection menu. Pressing the POWER button again turns off the printer for a resta ++++++++++ Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA IP3000 above, 1. Turn off printer 2. Hold down Resume button and press Power button. 3. Keep holding down Power button and let Resume button go. 4. Press Resume button 2 times then let BOTH buttons go. 5. Green lights will flash and then stop blinking. 6. When green lights are solid, press the Resume button 4 times. 7. Press the Power button and the printer should turn off, if not, press the Power button once more. 8. Your printer should respond as normal. +++++++++ Canon S900, S820, S750, S520 Turn off the printer. Press and hold the RESUME button, then press and hold the POWER button. While still holding the POWER button, Release the RESUME button, then press and release the RESUME button two more times in succession. The printer mechanics will move momentarily. You are now in Service mode. Release the Power Button. Pressing the RESUME key will select a function; for example, pressing RESUME 4 times will select the clear waste ink counter function. The lamp will alternate color with each key press. 1. Service/factory test printout, including ink sensor check 2. EEPROM info printout 3. EEPROM initialization 4. Clear the waste-ink counter 5. Printer model setting. (more selections beyond this- leave this alone) After selecting mode, press the POWER button to commit the change, and return to the top of the function selection menu. Pressing the POWER button again turns off the printer for a restart. ++++++++++ Canon S9000 Turn off printer Hold down Resume button and press Power button. Keep holding down Power button and let Resume button go. Press Resume button 2 times then let BOTH buttons go. Green lights will flash and then stop blinking. When green lights are solid, press the Resume button 4 times. Press the Power button and the printer should turn off, if not, press the Power button once more. Your printer should respond as normal. +++++++++ Canon MPC190 Reset Waste Ink 1) Enter SERVICE MODE. By pressing Menu Copy Scan Copy Copy 2) Select TEST MODE. 3) Select [8] PRINTER TEST in TEST MODE. 4) Select 3. [EEPROM CLEAR]. 5) Select 0. [INK COUNT]. 6) Press the [Set] key. 7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Jul 26, 2006 | Canon MultiPASS F60 All-In-One InkJet...
Washing Machines Logo
75 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
jdthefixer
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
