Question about Pride Health & Beauty
Mobile turns then makes a chattering noise like there are gears slipping, how do we repair it???
Posted by Cecilia Hayward on
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: Kneading Blade chattering
I had the same problems with another manufactures model. I found that the bread pan needs to slot in the machine only one way. The pan will fit in the machine with the handle both vertical and parallel to the front. However to stop the clacking noise I found that one way in the machine..it makes noise, the other way it doesn't. You'll have to try. If it makes noise, open the lid and turn the bread pan 45 degrees in either direction and secure it back in the breadmaker then close the lid. I hope this helps. If it does, remember how the pan is in the machine for next time to avoid the noise.
Posted on Jan 18, 2009
Anonymous
  • 98 Answers
SOURCE: differential chattering or grinding niose
hello i will help u.there is an additive you can add to the differential to stop this problem.you can find it by going to a good auto parts store.But otherwise your noise is common.and not a major problem.
Posted on Mar 10, 2009
tombones
  • 3567 Answers
SOURCE: feels like gears are slipping with any kind of power
If you are hearing a bad grinding noise then Stop riding the bike NOW. If you continue to ride, or run the engine, you will only do more internal damage and make the repair cost higher. Chances are you have a bent shift fork and the noise is the engaging dogs on the slider gear grinding the side of a fixed gear because the bent fork is preventing full engagement.
The entire engine comes out of the frame and gets completely torn down. The top end comes off, the case covers come off, the clutch, shift shaft, kick starter, flywheel and electrics all come off. Then the case is split to gain access to the gears and shift drum. The gears and shift drum now get removed and now the fork can be replaced. If a gear needs to be replaced because of a broken teeth, replace also any gear the teeth mesh with. A few special tools are needed. Sorry for having to give you the bad news.
A “very helpful” rating for this answer? Thanks!
Posted on Jun 14, 2009
iambanshee74
Kori Policy
  • 3489 Answers
SOURCE: 2005 hyundai accent is making a chattering sound
quality is definately an issue. there is no reason for them to be worn out or making noise. upgrade your pads from the dealer and have your rotors turned.
Posted on Jan 07, 2010
Donald Fox
  • 170 Answers
SOURCE: makes a loud whining noise and is slipping when
Verify that your trans fluid is at the correct level. When if at all was the trans last serviced?
If fluid is low, try bringing it up to proper level with Valvoline ATF+4 fluid. You need to used either fluid from a dealer, or the valvoline brand which is approved by Dodge.
Posted on May 19, 2010
2003 ford sport trac front grinding noise from drivers side when sharp left turn
go to the magicmechanic website and send him this--hes the best there is and will rply
Jan 19, 2015 | 2003 Ford Explorer Sport Trac
When I turn the wiper motor on in my 95 Ford F150 it makes a hard chattering noise. Is the motor, or the switch bad?
The motor. Gears in it making the noise. Switches don't have gears, they are electrical.
Dec 12, 2014 | Ford Cars & Trucks
Ect power transmission problems
ECT?
why not just state the symptoms.
there are over 50 A/T transmission problems, automatic,
it is auto right and not stick, we dont know,, cant see car.
slips?
shift late ,root soon, too rough??
will not move in any gear.?
down shifts wrong?
makes noise,?
OD dead.?
lockup TCC dead or chatter.?
the FSM lists this huge list of symtoms.?
they are notorious for them. unlike m/t
Feb 09, 2014 | 1996 Toyota Camry
Depending on the quality of pad used you may get some noise from the brakes mainly squeaks. Grinding or chattering is unusual though. Id take it back to the place that installed the pads/shoes and have them check it out again. Do you get a vibration while braking?
Jan 07, 2010 | 2005 Hyundai Accent
What are the symtoms of a bad clutch switch
If the engine revs up more than normal and your not gaining speed then the clutch is slipping.If you shift down to pass and then try to accelerate and the engine revs up but you don't gain speed,the clutch is slipping.If with the park brake on you can let the clutch out without stalling you need a clutch.If it makes a tinny sound when the clutch is pushed,you need a trow-out bearing
Oct 26, 2009 | Ford Ranger Cars & Trucks
98 4L60E first gear chatter intermitent,stall speed feels higher
ten k latter the slipping is worse and so is the chatter Its no longer intermittent. I have concluded that the band is slipping and thats one of the noises. time to pull it and go through it. you .cant tell me this is the only one out of some quarter million units produced over 98 and 99 with this model trans..
also trans parts usa has the converter for 120 and all there other parts are the best price i have found in months of looking and pricing and the shipping is fair ...
Mar 13, 2009 | 1998 Chevrolet Blazer
Jan 02, 2009 | Sunbeam 5891 Bread Maker
Health & Beauty Logo
62 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
