Question about Tornados As Seen on TV Tornado Can Opener
My tornado can opener has stop cutting please what should I do.I have changed my battery but still not cutting
Posted by Samuel Sarkodie on
Hello, I have a Turbochef tornado oven, while operation i am getting a Fault code Close door and keeps on coming while closing the door with a beep . Can you please try to resolve the error and solve. Your...
DISCHARGE HIGH VOLTAKE CAPACITOR.
IF YOU DON'T KNOW THEN STOP HERE.
open left side pannel
check that the primary switch where the door lathes is closing the switch
if not then adjust it
if it is closing the switch then use multimeter and check the continuity test (hint mesure its resistance)
and if switch is bad then replace it
thanks
please rate my work
May 12, 2011 | TurboChef TORNADO Electric Oven
Engine cutting out
not sure why its doing that,but you can try bumping your idle up a little and see if that helps.
Nov 27, 2008 | 2008 Benelli Tornado Tre 1130
Tornados As Seen on TV Tornado Can Opener Logo
Top Tornados Cooking Experts
Tom Chichester
ray gallant
ADMIN Canada
ADMIN Canada
Are you a Tornados Cooking Expert? Answer questions, earn points and help others
